查看: 3069|回复: 23
急!!!大家帮帮忙啊,要去试面了,英文要求有的看不懂啊。帮忙解释下啊。
    2025-11-26 15:15
  • 签到天数: 137 天
    [LV.7]常住居民III
    发表于 2012-7-11 16:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    Education:
    ( N( I; {/ l! O% sUndergraduate Course/Junior College
    8 P# D( Y8 v! i, p* B2 I! F# n: a7 M% s' H' h, j' H
    Responsibilities: 5 \6 j  R( \" H- \5 w5 I/ E+ e
    3 j) u: e/ v4 u6 O! U
    * Co-work with EE, SI, EMC and Power engineer to design
    $ D* M; }- }" Y4 W* `  [8 E* Co-work with manufactory DFM requirement to design
    ; D' Y& e7 Q) x* T7 H" c3 i* Knowing very well the whole PCB design flow. 6 ~$ E! c7 V4 x2 {! B, I4 L  ]
    ( h; s& \& R& E8 l8 ?
    Requirements:
    % _. N% U& _+ B) G5 Z" V: A  v% s2 P" Z- @* j
    * Electronics Speciality.
    * k- w- ?2 l& M* J* Knowing the basic allegro environment system. . `# s2 h& c' S2 B$ {
    * Can finish the whole PCB design lonely ) b1 G8 C* W+ T& v
    * 1-2 years of Layout design experience. : K! x" p7 l5 l" F! l0 r. w
    * Have the good experience in Notebook /server. 6 b& v1 ?5 j# f( N$ O" P" g
    * Knowing the high speed and D/A design. 3 w- i9 M6 X2 `4 K' Z. J
    * Designed the AMD, Intel or NVIDIA chipset
    4 j- S" t7 v7 q' l: [$ K, v* Can use capture check the basic schematic issue when you net in
    . Z5 a) ^" ?( \2 ~* Can use Cam2000/Cam350 to check the Gerber file issue. & A# d% q- }9 F5 I+ r' \" P4 S9 g; t
    * Have a certain concept on Fab
    & z9 F" j; E  {8 J; g% u, q: I. y& T* Have basic Lib creation experience.
    7 B# x) L4 Y& Q2 \% B2 D1 b' u+ G. V& t* }1 D9 Q# S
    其中EE,SI指的是什么意思?DFM,FAB,LIB是什么啊??
    + H2 K, Z/ y. U( ?+ ?. S最好帮我全翻译了。谢谢, 这下真的急等啊。明天去面试啊。。
    5 m) ~  D2 e7 b. l6 e5 g2 g: c+ @( Z" ?$ G' p0 l$ }
    推荐
    发表于 2012-7-12 09:54 | 只看该作者
    ) }2 F' t/ @" w  Q' L4 l+ O1 g* ?1 d1 R1 o* X- e, x2 ^
    ( t) A7 {) `( x4 e) i- X协同电子电气工程师(总工) ,SI工程师,EMC工程师和电源工程师来完成PCB layout。, b$ r0 R- @. C' J' K
    个人见解,请斟酌。
    参与人数 1贡献 +7 收起 理由
    chensi007 + 7 很给力!
    推荐
    发表于 2013-9-30 11:01 | 只看该作者
    sgphoto 发表于 2012-7-13 15:40% ?4 U, h$ x9 B$ \0 v" H
    6 |% b. d% y# b字面意思是: 耐得住设计PCB的寂寞。. G7 U4 c  g9 e' ]# G/ I' L. O
    要求蛮高的阿
    # q. J: q& \3 O$ h- H1 t- R
    神翻译啊,哥们真逗~
    发表于 2012-7-11 16:47 | 只看该作者
    本帖最后由 jimmy 于 2012-7-11 16:51 编辑 + I1 M3 T, R: }1 J' a" Y, |( |
    * C6 v" B& n9 N3 U% d
    EE 不清楚
    1 b* l4 E3 }2 a2 t. F" p, R# ~; `' {8 e+ Z- p
    SI:信号完整性
    9 M2 G$ n0 B- Z! b9 F/ L' m" a& C9 V+ y# X/ Q- [0 Y2 ^
    DFM:design for 工厂.就是指设计要符合制程.
    * p4 V3 [( r$ b
    " D9 v3 j7 \- b" [/ D4 F6 QFAB:不清楚9 ^$ q- `; ]% K9 C4 w6 t1 U3 U
    ' g! ~7 N: _! D+ SLIB:器件封装库。指你要有创建和管理封装库的经验。
    - T2 R( [1 t  I# F; d- e9 L9 K0 g4 W& D$ L$ D" d
    ) j4 f# p5 I( U/ d你要面试的公司估计是电脑周边类的产品,比如笔记本主板,显卡之类的。
    1 H5 p' C% G" y
    3 e& D( p9 o( {0 @  l& ^2 E应该是个不错的外资公司,祝您好运!
    2025-11-26 15:15
  • 签到天数: 137 天
    [LV.7]常住居民III
     楼主| 发表于 2012-7-11 16:53 | 只看该作者
    jimmy 发表于 2012-7-11 16:47
    3 G7 }' X* Y4 J* h* U# KEE 不清楚
    8 {0 [: ^8 w2 S# E/ r6 \
    7 c& N5 ^$ `  y' CSI:信号完整性
    " V. ~9 e) A; C; B4 |
    谢谢了。。
    发表于 2012-7-11 17:00 | 只看该作者
    yangjinxing521 发表于 2012-7-11 16:53
    " v$ K+ u9 Y. [8 b" o( O谢谢了。。
    1 t  w3 w$ D3 ^/ a/ f8 W8 c& G; e对方是用allegro软件的。你不妨到allegro专区再问问那边的高手。
    发表于 2012-7-11 21:38 | 只看该作者
    Thanks !!!!!!!!
    发表于 2012-7-12 09:58 | 只看该作者
    这里的EE是指的mentor Expedition
    发表于 2012-7-12 10:00 | 只看该作者
    FAB: Fabrication  .
    + i# ?- F3 ]& a/ R* q' B) j指的是 pcb 制作
    参与人数 1贡献 +7 收起 理由
    chensi007 + 7 很给力!
    发表于 2012-7-12 10:13 | 只看该作者
    DFM  :可能是工厂制造装配
    发表于 2012-7-12 10:14 | 只看该作者
    Design for manufacturability
    发表于 2012-7-12 10:20 | 只看该作者
    EE:电子工程师(一般公司特指原理图工程师)
    发表于 2012-7-13 15:16 | 只看该作者
    要求你都没有搞懂,估计面试也挺难的
    13#
    发表于 2012-7-13 15:40 | 只看该作者
    3 g( m: Q- g$ j9 a4 E) f字面意思是: 耐得住设计PCB的寂寞。/ K& U. @: d, p* d9 J8 p; i  W
    要求蛮高的阿
    支持!: 0.0
    支持!: 0
    哈哈 公司搞个lonely,啥水平,alone哈  发表于 2012-7-18 18:27
    应该是能独立完成整个pcb设计吧。。。。  发表于 2012-7-17 18:11
    14#
    发表于 2012-7-13 15:43 | 只看该作者
    Designed the AMD, Intel or NVIDIA chipset0 Z1 s' U6 q; J% b4 X. u1 L$ M( q2 p
    设计过AMD, Intel or NVIDIA的芯片组.
    * B; l& }2 ^" ^% T4 y这个要求实在是太高了吧.
    支持!: 0.0
    支持!: 0
    公司巴不得用买米的钱去换买牛的金子...  发表于 2012-7-18 18:31
    15#
    发表于 2012-7-14 10:50 | 只看该作者
    2 V% L1 S. }& R正确的翻译应该是:能独立完成整个PCB设计: H- [0 v1 {7 C
    % o& k9 d# ?8 S$ C
    13楼的真可爱^_^
    GMT+8, 2025-11-28 17:07 , Processed in 0.187500 second(s), 32 queries , Gzip On.
