用pads9.3.1 转换已经经过allegro处理后的文件,总是显示. B/ m4 a% U/ L8 z: X
* a& I) I% }! ]8 p" V! S
; x% |! Y4 `3 `
这个文件在ALLEGRO的main out中,是正常的- Y2 D* B3 h& w3 \; l
Command > main out" v8 {) S& j- O! L. c
Please wait...extracting and processing technology file
8 B% U; u s9 s1 y9 CStarting Export techfile...
0 h0 t' T4 V; Y0 y5 Ttechfile completed successfully, use Viewlog to review the log file.9 _* H0 k) j7 k1 i- A
( l; |7 M* u6 l1 LConverting techfile...9 \* f7 c9 I6 `! L6 m; J
Executing command D:/2/1_MGC/Work\techconv.bat
# C( w1 R' L5 q- z% A( {( R* fTechfile conversion successfull!4 g$ `- p5 Q4 x3 \3 s
extracting Layer Stackup
7 H+ a, u& z, V5 _& _; }6 S% Lextracting Design Rules
4 M: X0 a( W& R: \. } ZDeleting Existing Classes File
8 V, Z- t0 y$ yDeleting Existing Props File
9 o7 F5 G; b& W1 u8 ADeleting Existing Board Items File
: r" l7 Z+ y. [4 ] f/ I9 aExporting Electrical Constraints...
8 G. R6 j& b. @: @8 ^6 ?% I$ B) fLoaded existing device file 'D:\2\1_MGC\Work\devices.dml'. s( R" P% d: v8 Z j
Finished loading SigNoise device libraries _ D* ] D3 A$ a* _
deleting old device files5 N7 K* j/ Q% e$ n0 q
extracting device files: I9 Q* E* v; `/ h" g4 l: c
extracting Net Properties
# }1 o0 B! A$ J% Hextracting Board Areas5 e* E% r* L% |, H/ W3 L, n
DCprocessWidthTable - DEFAULT width used8 P4 B6 D7 C" }9 q0 c3 B
extracting padstacks
: i9 ^ G+ o/ Eextracting padstack completed
$ ?, b" H% X' [8 b" ]extracting Placement
H% B& P, ^9 C8 N+ Yleaving placement
: ^, Y& B* ]; Q2 u' dextracting Device Pads
* l; Z; `9 _9 k$ i1 r) a- }devices pads extraction completed
& ], j+ B& T, M6 g' Lextracting Board Areas* h, @" B+ V3 b
Starting report.... s% p5 L a' t J7 L
report completed successfully, use Viewlog to review the log file.
* G; M3 u% k, Sreport completed successfully, use Viewlog to review the log file.
8 I0 m. T8 K4 F" TExporting net information.
7 t0 \8 C6 f) C1 l; I9 c8 SThere are 252 different component properties in this database.; }' g8 z3 O- H) Y+ P
There are 239 different net properties in this database.
+ a( {: v) F- F2 ]6 S+ f: OHierarchical net constraints have been flattened onto individual nets for export.
* z" C% r. i, B! |0 X Differential pair "DIFFPAIR22" has 4 net members. Only one member of each xnet will be written to the netlist.
" w$ N& Y) ~3 p1 a( q3 V1 b Differential pair "DIFFPAIR21" has 4 net members. Only one member of each xnet will be written to the netlist.
2 h8 v2 G J& ?3 ? Differential pair "DIFFPAIR19" has 4 net members. Only one member of each xnet will be written to the netlist.
2 l' E( Z' r, D v q0 V5 k1 aThere is one pin property in this database.) U8 U: U' k0 d3 A8 x& z, W
D:/2/1_MGC/Work/propdelay_raw.tmp has been created.% Z. K5 [$ E/ {+ Q
D:/2/1_MGC/Work/LayoutDB.dfl Output Complete.. e% w: `3 A2 G
Generating Padstack HKP FIle.
% }5 V, [9 p1 |7 z% i: w ---------------------------
# `- u# s' Q, p/ vCreate .PAD Definitions.
: D4 b) p* A+ V3 y4 VCreate .HOLE Definitions.
1 z+ ~/ I7 D m( vCreate .PADSTACK Definitions.( M5 ]6 l7 y) W' ~
Generating Cell HKP File.% i' I- R f- g9 ?* v* C
9 N2 N7 u+ U/ N3 H6 A5 PInfo: Database transaction started.
: t. q8 [) j. cCell HKP Added temp instance of symbol: "PSW3-RA"3 `9 \1 @- m6 `5 C* x6 b) ^
Cell HKP Added temp instance of symbol: "SDI-5DIP"8 p$ k- S" ^. R: s- O# v" a9 t4 V
Cell HKP Added temp instance of symbol: "SX2-1205"
) C5 y2 h/ \: L8 YCell HKP Added temp instance of symbol: "BGA96-32-1609D") L; P4 v8 E0 q
Cell HKP Added temp instance of symbol: "SL0603A"1 Q- m6 F" A3 l s
Cell HKP Added temp instance of symbol: "SOP16H-26-173B"
$ w* }$ f( c: ~6 F; C" YCell HKP Added temp instance of symbol: "SOP8-50-150"+ N. s. p4 @9 W0 v8 r' N
Cell HKP Added temp instance of symbol: "STFM24-39-630"/ s% q, ^6 L h% }+ u J \$ d+ o
Cell HKP Added temp instance of symbol: "SOP16-26-208-255"
6 a7 x: t& \/ a$ }! _Cell HKP Added temp instance of symbol: "SRN8-0804"
7 G/ D( [( L; b3 k7 {6 p+ Q$ TCell HKP Added temp instance of symbol: "SOP8H-50-155A"2 e* u5 Y0 o5 a- p W, f* T
Cell HKP Added temp instance of symbol: "SCAPC2-280-327"
4 F! K7 }( \" X! ?2 o' LCell HKP Added temp instance of symbol: "PCI36-12V"8 j4 B; g% c4 J1 n; k" O
Cell HKP Added temp instance of symbol: "BGA100-40-1010"' s8 j$ Q. d1 A3 Z/ b. u: i
Cell HKP Added temp instance of symbol: "SOT23-6"" J, m8 P& G8 m
Cell HKP Added temp instance of symbol: "SC1206"% L' \* o+ h6 m% j2 D. o
Cell HKP Added temp instance of symbol: "SOP8-50-150A"2 r: O: i& B; ?
Cell HKP Added temp instance of symbol: "SL1210"
/ C, y. t' W0 d F) k% Z: |3 ?! JCell HKP Added temp instance of symbol: "SDSW8-L"1 r9 _$ z9 K) ]" [, F! u2 O; E
Cell HKP Added temp instance of symbol: "SEN3-100C"$ S/ H2 \ e1 A8 O, s/ g* P/ \
Cell HKP Added temp instance of symbol: "SOD323"4 Q, P7 H( k" T) c5 N
Cell HKP Added temp instance of symbol: "MJ8-SRLFY"
8 c) R9 _ ?: Z3 `* w/ C: pCell HKP Added temp instance of symbol: "QFN64-050-0909LH"
$ l3 @2 i. @6 f! s" n8 c; |7 wCell HKP Added temp instance of symbol: "MLF40-050-0606L"
' q* r4 Z& q$ K: a0 QCell HKP Added temp instance of symbol: "SX4-0705"$ F/ ~* ~6 ?# z* O2 k
Cell HKP Added temp instance of symbol: "SR0805"7 ~' y# Q8 V1 x) K# C* T; c" y6 a
Cell HKP Added temp instance of symbol: "SOP16H-26-173A", @ l( i6 ]! G+ u- Y% ^2 }
Cell HKP Added temp instance of symbol: "QFN-72") t0 B5 p1 {+ I( P1 G
Cell HKP Added temp instance of symbol: "SD2723"! s/ U% H8 v: J' g$ L
Cell HKP Added temp instance of symbol: "SC0402": C& g1 }7 @0 d; ?: r
Cell HKP Added temp instance of symbol: "SOP38-20-173A"; _$ {( z* w7 I
Cell HKP Added temp instance of symbol: "HEAD-4P"0 L( Z/ q0 Z8 m" A7 [: R$ \
Cell HKP Added temp instance of symbol: "SL0402": M! r- b' ]/ ~, k) l
Cell HKP Added temp instance of symbol: "SOT23"
% X& j& I5 I- n# B8 M4 I- \9 vCell HKP Added temp instance of symbol: "ID-BOARD"
# i0 k' r3 j0 K- h! f# `: }Cell HKP Added temp instance of symbol: "VAF3-A"
1 J2 a' O$ [ e, L" U L" TCell HKP Added temp instance of symbol: "SOP8-50-173"& o; F" s# Q4 b I% ? x' J
Cell HKP Added temp instance of symbol: "MLF32-050-0505LE"
0 g. ~; U/ w+ v! V( P* eCell HKP Added temp instance of symbol: "SR1206"
^, ], F3 z1 o, L, M, _* qCell HKP Added temp instance of symbol: "SOP16-50-300A"- |/ Z" G( Q; X+ p' L. o% H3 G
Cell HKP Added temp instance of symbol: "CONN_CD_676000004"
$ E1 F, K6 s* v# b& OCell HKP Added temp instance of symbol: "SL0603"
/ o k9 q, T% ~) b1 }Cell HKP Added temp instance of symbol: "SIP-3P"
; ~( L0 Q" B* V/ f3 R. qCell HKP Added temp instance of symbol: "MTMM-125-D"7 r0 f4 T5 S; Y, R: {3 `) H2 U
Cell HKP Added temp instance of symbol: "STP40"( F S6 W4 V# j7 b
Cell HKP Added temp instance of symbol: "BGA416-26-2222"1 ~0 {3 y6 X% A% J
Cell HKP Added temp instance of symbol: "SC1210"$ K* O/ V* K" E0 S" y9 |
Cell HKP Added temp instance of symbol: "SC0603"" g. d$ k& e4 [, ~2 G# N" S
Cell HKP Added temp instance of symbol: "SOP8-26-118"
4 G4 l. O. T4 f$ k6 UCell HKP Added temp instance of symbol: "FPC18-40"
8 Y: o) R$ e K! g* i$ JCell HKP Added temp instance of symbol: "HSD0603-LED"
9 g$ i: o% e1 eCell HKP Added temp instance of symbol: "SR0402") \1 I7 l$ {. M; k5 a
Cell HKP Added temp instance of symbol: "SF6127"
' L) T* z8 t0 m/ JCell HKP Added temp instance of symbol: "IDC20-DTM1-A"$ u1 x( r; Z! b- X
Cell HKP Added temp instance of symbol: "FPC20-40"
. Y/ k: W, {" w: p, X5 L# d; ?6 }: eCell HKP Added temp instance of symbol: "STC3528", H" t( c8 e' B# R0 y+ T
Cell HKP Added temp instance of symbol: "SOT23-5B"( ^! f/ ?- {/ g6 ]- c( S
Cell HKP Added temp instance of symbol: "SPL0807D"
; G4 @- g4 P+ j# L6 o6 Z- Z' [; ICell HKP Added temp instance of symbol: "FPC24-40"
, x. [9 x+ G' b& y: VCell HKP Added temp instance of symbol: "SL2828"+ C( l$ q, j9 w- Q* X2 ?! X
Cell HKP Added temp instance of symbol: "VAF5-A"7 t+ ~ D( W6 t/ c! o' E
Cell HKP Added temp instance of symbol: "HSOD323A"
! A! e. v7 M# T C+ ^Cell HKP Added temp instance of symbol: "SFMC-132-T2-L-D"7 |% {( v$ u" Y' Z; I* F
Cell HKP Added temp instance of symbol: "SOIC8-50-157"- M8 X2 S. r; [3 N* m B
Cell HKP Added temp instance of symbol: "SOP48-20-720A"
' n |0 |2 J) `+ }1 GCurrent Symbol: SOP48-20-720A
' \) z3 D3 @$ G) v* {# [ N* HCurrent Symbol: SOIC8-50-157
" o' `/ z, Z$ M+ vCurrent Symbol: SFMC-132-T2-L-D. k1 j. Q9 x% k
Current Symbol: HSOD323A& |5 L0 L6 [; l( f. e0 K1 i6 b
Current Symbol: SR0603% i. P. w! J4 {. M
Current Symbol: VAF5-A
' e% p( a; H4 v: i5 M5 ^Current Symbol: SL28280 d. Y- ]5 i" j- k0 \
Current Symbol: FPC24-40
. @+ c3 I9 r' j4 B" RCurrent Symbol: XTAL2-100
5 r( X9 O$ A4 X0 {) g1 l5 c! RCurrent Symbol: SPL0807D1 _4 N: e% v9 |; m, ^! \
Current Symbol: SOT23-5B1 T/ W& t! j# R3 J9 @! F8 N
Current Symbol: SAC6666
4 f+ E) U% h+ HCurrent Symbol: STC35283 p6 M% j0 s @4 W, f
Current Symbol: FPC20-40 p& m3 e0 R! V w
Current Symbol: IDC20-DTM1-A
% B" F/ f; x, r) M' ?2 FCurrent Symbol: SF6127# l0 D( r. E- F
Current Symbol: SR0402- o5 A! F9 F3 y& T0 H( P
Current Symbol: HSD0603-LED
2 ?8 V9 _8 X9 O9 l% J% j$ DCurrent Symbol: FPC18-40( o/ Q! H3 ?" }+ s8 C. d7 Z- V( o
Current Symbol: HOLE125-8STAR+ c8 a# `+ j0 g" o/ R1 f
Current Symbol: SOP8-26-118
s$ F+ P# G& s. ^6 _& p5 u" o) f. |$ ?Current Symbol: SC0805
, K9 Y3 h* p) Q& K# LCurrent Symbol: SC0603+ [- M4 }' c, e0 R
Current Symbol: SC1210
: n: f6 c8 D9 h- I4 O: B# o% uCurrent Symbol: BGA416-26-2222
' K; @* b* z6 E, N( F/ ?9 \; aCurrent Symbol: STP40: I, I% C' z* N! E, \) H
Current Symbol: MTMM-125-D8 r( `3 }, f q0 Z9 g
Current Symbol: SIP-3P! N2 |) W: d9 b; K) q: c5 x
Current Symbol: SL06033 P! ~0 j! B+ l5 W5 w& U {
Current Symbol: CONN_CD_676000004+ ]! g9 z7 N% C9 M: o: k
Current Symbol: PWC0103-M-C
: S7 U% Q$ M8 h. [# wCurrent Symbol: SOP16-50-300A: o/ t8 @( j( Z% O- T) O0 ?- T0 c \
Current Symbol: SR1206
% S, C" }9 s0 T3 S) [$ [Current Symbol: MLF32-050-0505LE1 Q- T5 z6 d+ B, ?
Current Symbol: SBAT2-3209
1 v7 ^+ N5 i9 I# r* vCurrent Symbol: SOP8-50-173
. _- y, q6 z ^4 c$ x7 i# Y' `* dCurrent Symbol: VAF3-A- r5 Q- h* r* b# h" X: v
Current Symbol: ID-BOARD" e5 D; Y# {$ Y
3 }7 [% @2 u: m+ r2 W$ R" c" OCurrent Symbol: SL04022 K3 `; E" f& O8 t/ ?1 i! U
Current Symbol: HEAD-4P
% M" ?+ z4 L: G Z0 C# OCurrent Symbol: SOP38-20-173A. ~3 {) s; t0 |% V* m% s
Current Symbol: SC0402
0 J" W/ ?: \( F- ]6 @Current Symbol: SD2723
: o2 T: Q: I4 \ a+ l3 ZCurrent Symbol: QFN-72; x, n) y: x9 |- S
Current Symbol: SOP16H-26-173A
, J6 \% p! f7 m3 m% e DCurrent Symbol: MOLEX_47151, @ ~6 T( V- |7 k8 c! X
Current Symbol: SR08052 [& }3 q+ N( Q Q9 A d% I
Current Symbol: SX4-0705
7 C' c1 A+ K; \2 gCurrent Symbol: CAP2-300-2407 C9 m* O8 K4 {4 o' b& b
Current Symbol: BAR50_10
0 u. w+ C& E% K2 O( `8 t. YCurrent Symbol: MLF40-050-0606L
' _4 r8 \6 H4 [0 `Current Symbol: QFN64-050-0909LH
R, i- G! p! B, g% l5 ZCurrent Symbol: SD0805-LED7 C2 f* D) ~& I
Current Symbol: MJ8-SRLFY) P/ J! }# b+ V$ k* g
Current Symbol: SOD323
! C3 ~ q9 H0 ?$ o3 C% R# U* r0 H9 T# QCurrent Symbol: SEN3-100C/ B+ @+ C( E, G y1 B
Current Symbol: SDSW8-L3 m$ a! `2 V& X+ Q% z4 u, M
Current Symbol: SL1210
' }" X0 u0 P0 }0 j6 r2 @' jCurrent Symbol: SOP8-50-150A$ G! \) L8 C% ^
Current Symbol: BGA324-40-1818
' c9 ^# i# t9 G, U6 mCurrent Symbol: SC1206
' }, `6 t7 F% r; d q1 V/ ~Current Symbol: SIP-1P
! p# Z1 V/ B1 v Y/ `9 g8 V4 ~Current Symbol: HSL10072 K! V: J: \0 G
Current Symbol: SL0805
" E! f7 E6 x- s3 ~* B* m% _" M/ v0 ?0 wCurrent Symbol: SOT23-6% a0 t3 i0 Q' n$ U7 C
Current Symbol: BGA100-40-10103 j$ I' h% ^$ V: }3 c
Current Symbol: PCI36-12V
; c! M } t4 K( }4 E' d) kCurrent Symbol: SCAPC2-280-327' |: T. A. u+ I0 z/ i/ }) i
Current Symbol: USB8-1715
* D3 E; ^' r* ?Current Symbol: SOP8H-50-155A) e0 w Y, J v5 `9 V7 J$ q, Q6 x2 T
Current Symbol: SRN8-08041 _9 q6 g( E7 z
Current Symbol: DB9-2RM
$ @5 L# K b( S7 }Current Symbol: SOP16-26-208-255
; [7 s/ X; n+ f, }2 @Current Symbol: ID-COMP
% {7 ~" v# \. r6 E% V4 J% CCurrent Symbol: SSW-PUSH( f$ \5 O5 e8 p9 b. F
Current Symbol: VAF2 g o5 h1 O! ?; I4 V- I% h) t
Current Symbol: STFM24-39-630
& x3 g E* [" H1 w" J9 v9 P* Z/ OCurrent Symbol: SIP-6P
; O" m+ M$ o- I& [* C8 XCurrent Symbol: SOP8-50-150
' I2 r8 {8 e( |6 i T qCurrent Symbol: SOP16H-26-173B. V9 x+ Z4 K* U5 a9 q9 ]7 y
Current Symbol: SL0603A
! S* [; R% U% O7 C; ^/ C0 u8 \Current Symbol: DIM0425-80-A
2 @! H7 i! L ACurrent Symbol: BGA96-32-1609D; t8 E. I2 Y) h8 R4 I0 A Q- n& V! [/ r9 a
Current Symbol: SX2-1205$ F6 m0 T9 e* } v" ^$ Y: ^9 g
Current Symbol: SDI-5DIP
$ E9 P: d- i9 Q7 G) l! }$ DCurrent Symbol: PSW3-RA- c% n/ B, w7 K% Z
Removing temporarily added symbols.7 Q0 [, f9 H' z. n4 Q
65 symbols removed.
4 ^9 H# Q: t. q, t9 r% y; ^---------------------- Al2Exp summary ----------------------
0 x' n8 y0 r" D( o c! R$ w- }Al2Exp - 0 error(s), 24 warning(s)
* E+ w4 m* C9 e s' r ^Export log file saved at "D:/2/1_MGC/LogFiles/inteRFacelog.txt" file
& X# M* @/ n5 I/ vRun "show log" command to view log file2 O: {1 c8 f9 g; Q6 G& z) K+ P5 \
------------------------------ Done -------------------------------
; W! `& g" ~& E: b: O
9 N. [6 a7 Y/ k! O3 H, O
C2 e& @8 ]# |* Q* |" u' F+ J求高手解答 |
