查看: 3076|回复: 23
急!!!大家帮帮忙啊,要去试面了,英文要求有的看不懂啊。帮忙解释下啊。
    2025-11-26 15:15
  • 签到天数: 137 天
    [LV.7]常住居民III
    发表于 2012-7-11 16:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    Education: * ~6 ^0 M- ]; }# j4 H) m% q
    Undergraduate Course/Junior College
    6 I$ l0 r7 S; `  j2 d0 L0 h  Q- X( w! B9 Q% _# t- W$ D+ |: ^
    Responsibilities:
    $ X: U  B4 R$ w3 v6 K) l! \# R% K" c5 V" e0 B0 ?) A8 i& o; Y
    * Co-work with EE, SI, EMC and Power engineer to design
    1 U! r' J, t  Y: S2 _$ r* Co-work with manufactory DFM requirement to design ! ^. C" [& G& J1 T
    * Knowing very well the whole PCB design flow.
    ; m# c7 Z& S" j
    5 Z+ x/ L) A& Z0 VRequirements:
    3 Z/ o6 |! s$ \3 A7 V9 J7 r
    % e' {% e9 R+ d. k/ S0 m* Electronics Speciality.
    ( a, B2 `; |* i6 s5 S) P  K6 T* Knowing the basic allegro environment system. 4 `2 g" `4 R/ N8 P; e& _
    * Can finish the whole PCB design lonely
    " z4 w* i7 n9 U4 q* 1-2 years of Layout design experience. $ a# t8 H$ a$ l) U; Y% Q8 ~5 K
    * Have the good experience in Notebook /server. ; i" K' m  V' ]# ?. f5 n. B
    * Knowing the high speed and D/A design.
    9 J6 M* |2 a: y: ?; T3 h* Designed the AMD, Intel or NVIDIA chipset
    ' ^+ Z9 x8 p! o" E* Can use capture check the basic schematic issue when you net in
    6 y% F# q4 e) W4 V4 j( N1 ?0 A* Can use Cam2000/Cam350 to check the Gerber file issue.
    ! L0 y. U8 K7 k. j" q2 k5 d* Have a certain concept on Fab
    ) O  x! e' h% I, x* Have basic Lib creation experience. ( {  ]# i8 w4 H+ u6 ?1 Y8 {
    0 ]. _. I: k; a- d6 b  m8 W4 H其中EE,SI指的是什么意思?DFM,FAB,LIB是什么啊??
    / m0 s3 P# o6 D$ H, i最好帮我全翻译了。谢谢, 这下真的急等啊。明天去面试啊。。
    " X& a; Y- N$ r
    , h6 M# ]: @4 Q: }0 y* A/ Z
    发表于 2012-7-12 09:54 | 只看该作者
    本帖最后由 sharp0 于 2012-7-12 09:57 编辑 " b* G" K/ b9 P8 |( _
    / a7 ^% m5 G- |4 a5 v! q
    # o' {2 P! Y9 t; l协同电子电气工程师(总工) ,SI工程师,EMC工程师和电源工程师来完成PCB layout。8 C, N, {  w1 u) h" D5 e
    个人见解,请斟酌。
    参与人数 1贡献 +7 收起 理由
    chensi007 + 7 很给力!
    发表于 2013-9-30 11:01 | 只看该作者
    sgphoto 发表于 2012-7-13 15:40
    ) q4 T4 q7 O1 N% w- o8 |7 b' |Can finish the whole PCB design lonely6 J5 A$ D7 s6 h. T
    字面意思是: 耐得住设计PCB的寂寞。$ O2 r$ N6 u$ j% t6 X
    要求蛮高的阿
    5 Y5 G: F8 b* O( T! \9 x! l
    神翻译啊,哥们真逗~
    发表于 2012-7-11 16:47 | 只看该作者
    本帖最后由 jimmy 于 2012-7-11 16:51 编辑 1 K/ h3 z* E; v, F1 G0 V& O
    # ~" Z, _: C  {% o! b6 DEE 不清楚, N/ {% e" }! ]$ R/ o; N; E, d! y
      z- p4 S1 y* c0 W( U& r
    SI:信号完整性
    & y6 ^: Y  C) Y: o- H1 @
    + `1 F: \% w* KDFM:design for 工厂.就是指设计要符合制程.
    7 s1 s" s( K- h) \
    % j8 P. N- h# E8 A. x& I3 t) R, WFAB:不清楚
    3 z. K3 P2 a7 S$ I. I
    # N" S) \# [' ]( s, Z8 NLIB:器件封装库。指你要有创建和管理封装库的经验。' h7 T- Q! s% L2 Z6 F) c  d: a9 ?9 }7 o
      w; g8 l; @  i2 j( V7 R
    - l0 e# P9 o$ G: C
    你要面试的公司估计是电脑周边类的产品,比如笔记本主板,显卡之类的。
    + C1 ]# X& p$ W! b4 B
    # l1 _9 ?, S' G3 ?应该是个不错的外资公司,祝您好运!
    2025-11-26 15:15
  • 签到天数: 137 天
    [LV.7]常住居民III
     楼主| 发表于 2012-7-11 16:53 | 只看该作者
    jimmy 发表于 2012-7-11 16:47
    - l9 O1 O/ `6 G/ @- EEE 不清楚  Y) H/ Q9 n. A2 m5 U- z
    4 y5 X+ c  ?. w+ e4 s; q2 {
    SI:信号完整性
    9 r! Z% F' x$ y
    谢谢了。。
    发表于 2012-7-11 17:00 | 只看该作者
    yangjinxing521 发表于 2012-7-11 16:53 & |( u7 R1 {6 Y' m9 W( V
    谢谢了。。
    & O& @# t3 F) H3 a
    对方是用allegro软件的。你不妨到allegro专区再问问那边的高手。
    发表于 2012-7-11 21:38 | 只看该作者
    Thanks !!!!!!!!
    发表于 2012-7-12 09:58 | 只看该作者
    这里的EE是指的mentor Expedition
    发表于 2012-7-12 10:00 | 只看该作者
    FAB: Fabrication  . ( M* g( J4 U  Q, ]- j( F
    指的是 pcb 制作
    参与人数 1贡献 +7 收起 理由
    chensi007 + 7 很给力!
    发表于 2012-7-12 10:13 | 只看该作者
    DFM  :可能是工厂制造装配
    发表于 2012-7-12 10:14 | 只看该作者
    Design for manufacturability
    发表于 2012-7-12 10:20 | 只看该作者
    EE:电子工程师(一般公司特指原理图工程师)
    发表于 2012-7-13 15:16 | 只看该作者
    要求你都没有搞懂,估计面试也挺难的
    发表于 2012-7-13 15:40 | 只看该作者
    ) b$ k+ }! Q4 M2 s( {  r字面意思是: 耐得住设计PCB的寂寞。
    1 C) Y& ~) O: V8 y1 A! B: \$ e要求蛮高的阿
    支持!: 0.0
    支持!: 0
    哈哈 公司搞个lonely,啥水平,alone哈  发表于 2012-7-18 18:27
    应该是能独立完成整个pcb设计吧。。。。  发表于 2012-7-17 18:11
    14#
    发表于 2012-7-13 15:43 | 只看该作者
    Designed the AMD, Intel or NVIDIA chipset/ s6 o0 n+ z9 |* u; S6 |1 h
    设计过AMD, Intel or NVIDIA的芯片组.( G8 }4 ]2 g; _3 t* [( p
    这个要求实在是太高了吧.
    支持!: 0.0
    支持!: 0
    公司巴不得用买米的钱去换买牛的金子...  发表于 2012-7-18 18:31
    15#
    发表于 2012-7-14 10:50 | 只看该作者
    ! P( g; N& B' y% v9 P5 ]9 q* i正确的翻译应该是:能独立完成整个PCB设计
    $ d4 P7 g( {5 B1 M6 r# I
    7 C; n9 G! a! ^* ?* p, w13楼的真可爱^_^
    GMT+8, 2025-11-28 19:31 , Processed in 0.171875 second(s), 26 queries , Gzip On.
