查看: 3074|回复: 23
急!!!大家帮帮忙啊,要去试面了,英文要求有的看不懂啊。帮忙解释下啊。
    2025-11-26 15:15
  • 签到天数: 137 天
    [LV.7]常住居民III
    发表于 2012-7-11 16:12 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
    Education:
    8 m( x; r" j, a& D% u+ LUndergraduate Course/Junior College - P  B8 F5 ~8 P) k# b. ]2 V& H
    - q' u" q2 g' s% ^. `. IResponsibilities:
    % A$ E6 B; ]) M5 }' u: c7 ~
    . R+ _/ `& [7 M, Y4 j4 D* \3 q* Co-work with EE, SI, EMC and Power engineer to design
    8 c7 n- g, x& q  E# e# E# M* Co-work with manufactory DFM requirement to design
    / a$ S& d% @9 w* a5 X  F* Knowing very well the whole PCB design flow. 6 g" L0 Z/ {$ [" E  Z1 x  C
    4 ^5 r) I5 |0 kRequirements: + |$ D1 w7 y6 Y8 \- S
    2 B4 N# N5 z0 I7 l* Electronics Speciality. ; z5 p1 ?9 a) G" u5 ]2 U
    * Knowing the basic allegro environment system. % Z* m7 x& }  E. [: m. ~
    * Can finish the whole PCB design lonely 2 f' b4 r6 M+ H- P
    * 1-2 years of Layout design experience. $ ~% D+ p. `" A
    * Have the good experience in Notebook /server. : H' e. B' X  A# u$ J5 a. r
    * Knowing the high speed and D/A design. 9 G* c1 F, J* b5 G) n) k
    * Designed the AMD, Intel or NVIDIA chipset - E0 |# b. V1 A
    * Can use capture check the basic schematic issue when you net in
    8 f7 g) w& E( j1 Z5 t* Can use Cam2000/Cam350 to check the Gerber file issue. ( z' N0 Q) K" n# k8 F
    * Have a certain concept on Fab
    / B2 C6 X3 P" i/ J* Have basic Lib creation experience. $ x! l# N" s6 o% q0 T
    5 Q7 p( s- `; X) o2 R; @其中EE,SI指的是什么意思?DFM,FAB,LIB是什么啊??2 x& t$ ?9 D4 D, H# I; \
    最好帮我全翻译了。谢谢, 这下真的急等啊。明天去面试啊。。) [  G3 z) N  Q1 i
    * g) }! ]) n; C# _
    发表于 2012-7-12 09:54 | 只看该作者
    1 d, g8 Z3 A1 z8 ~7 {0 u! y% B. E, F( `/ L
    : U( j9 Z$ Q+ w协同电子电气工程师(总工) ,SI工程师,EMC工程师和电源工程师来完成PCB layout。
    1 G3 o; y, [0 t个人见解,请斟酌。
    参与人数 1贡献 +7 收起 理由
    chensi007 + 7 很给力!
    发表于 2013-9-30 11:01 | 只看该作者
    sgphoto 发表于 2012-7-13 15:40
    - _/ L1 H9 ^) |1 q* JCan finish the whole PCB design lonely  m& }% U; Y0 m8 e  F4 |6 D. q
    字面意思是: 耐得住设计PCB的寂寞。- Q- B( ]& E$ h$ ?
    要求蛮高的阿
    - |! e2 ]6 F0 \" g+ n% H+ J5 x- C6 S
    神翻译啊,哥们真逗~
    23#
    发表于 2013-1-21 20:11 | 只看该作者
    2025-11-26 15:15
  • 签到天数: 137 天
    [LV.7]常住居民III
    22#
     楼主| 发表于 2013-1-21 18:49 | 只看该作者
    我晕。。我这这么老的帖子也让你们给翻出来了。丢人啊!面试不成功啊,当初人家怪我allegro用的不熟。现在哥都工作快半年了,一直在用 allegro做事。。。
    21#
    发表于 2013-1-21 18:12 | 只看该作者
    本帖最后由 幸福万岁 于 2013-1-21 18:23 编辑 7 J8 e+ v  t3 [0 P$ ?. m/ _
    . u; }# b! q; L3 _4 d
    哈哈  13楼的英文估计就2J哈哈  居然这么翻译 太有才了  - d, N* H) v1 M$ i
    我也只有2J   哈哈
    20#
    发表于 2012-12-12 10:00 | 只看该作者
    sgphoto 发表于 2012-7-13 15:40 $ W: r1 a# o1 M% e- r
    Can finish the whole PCB design lonely  Y, f2 q0 k0 z
    字面意思是: 耐得住设计PCB的寂寞。
    . u7 E. S  D9 Y8 }; j; ~要求蛮高的阿
    3 [0 l# j1 e# |应该是alone,lonely是指情感上的寂寞
    19#
    发表于 2012-7-24 16:09 | 只看该作者
    我覺得好像是專案經理 , 一般 Layout 工程師沒這樣高的要求.! R# n. N' G3 K7 c
    不然就是這加工師的 Layout 人員都是專門對某個客戶直接對應聯絡. ; }) N. @: M/ @( H5 I1 g7 N
    有些公司的  layout 是有如此的要求 , 如 Mitec ...
    18#
    发表于 2012-7-24 09:57 | 只看该作者
    受教
    17#
    发表于 2012-7-19 10:40 | 只看该作者
    * G) ]7 J4 ]  M, W8 Z8 Y0 x
    路过
    16#
    发表于 2012-7-18 16:59 | 只看该作者
    哈哈。
    - M- E: d! E; ~) }) W; ]7 w他这个lonely是孤独的意思。应该用alone就对了。
    15#
    发表于 2012-7-14 10:50 | 只看该作者
    Can finish the whole PCB design lonely: k4 w, `/ c# T5 S8 K# [
    正确的翻译应该是:能独立完成整个PCB设计
    - [1 t9 z7 C( c5 J- S7 O3 f
      o4 U( t. }6 |- \5 u13楼的真可爱^_^
    14#
    发表于 2012-7-13 15:43 | 只看该作者
    " Y# J8 a3 V& B& x. K设计过AMD, Intel or NVIDIA的芯片组.
    3 X4 i/ c( L7 A% y$ O4 {" T这个要求实在是太高了吧.
    支持!: 0.0
    支持!: 0
    公司巴不得用买米的钱去换买牛的金子...  发表于 2012-7-18 18:31
    发表于 2012-7-13 15:40 | 只看该作者
    Can finish the whole PCB design lonely& B7 s- W: ]" u. _% w! R- o
    字面意思是: 耐得住设计PCB的寂寞。
    " K" t4 e! j2 ~6 M" h要求蛮高的阿
    支持!: 0.0
    支持!: 0
    哈哈 公司搞个lonely,啥水平,alone哈  发表于 2012-7-18 18:27
    应该是能独立完成整个pcb设计吧。。。。  发表于 2012-7-17 18:11
    发表于 2012-7-13 15:16 | 只看该作者
    要求你都没有搞懂,估计面试也挺难的
    发表于 2012-7-12 10:20 | 只看该作者
    EE:电子工程师(一般公司特指原理图工程师)
    GMT+8, 2025-11-28 19:06 , Processed in 0.187500 second(s), 27 queries , Gzip On.
