查看: 1304|回复: 6
出gerber出现以下warning怎么办
发表于 2013-10-16 17:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
出现有warning,但是gerber文件能出来,cam350打开检查也没问题
" Q& C: u# K6 N" b& b: _, E
0 L1 f& d: a2 E* z2 f怎么回事啊{:soso_e115:}
5 N. {7 d% C: m
) x# D  l2 M- a) ~Results from parameter file ...
  u8 `/ J" n0 R2 ^0 R5 `7 g    DEVICE-TYPE           GERBER_RS274X. B( `* r( q5 v$ h- w" ^
    OUTPUT-UNITS          INCHES* K& _! ^( E5 O+ i4 q) O: Z
    FILM-SIZE             2400000 1600000
0 R  T9 Z2 K# {  b. Z; M, m9 J- |    FORMAT                3.5% L8 P8 {! v7 q2 w
    ABORT-ON-ERROR        NO
& V" v' F' M6 k; }" x% [    SCALE                 1
! D. X, B7 H. F% q$ e: E2 z; a    SUPPRESS-LEAD-ZEROES  YES( Z* @( t* n. F& t" {: r
    SUPPRESS-TRAIL-ZEROES NO! o# L' f" ~1 @" \# v
    SUPPRESS-EQUAL        YES2 q2 B! b! A' P. x
    UNDEF-APT-CONT        NO# F# D* i6 W, ~) I3 p
& t' D* b4 u: n0 n$ q) y; f
' V" i8 d) q0 B9 O  G7 P================================================================
) Y! c5 I1 m) U2 V     PROCESSING FILM < BOTMASK >& `: z7 ~0 Q& I, ^7 F
     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/BOTMASK.art > ...$ D9 H- X; G2 i' K8 t$ K
. o) A4 C$ i/ K% l  c: Y: x7 e! V7 `9 B; i
  FILM PARAMETERS :
0 ?5 F5 |% `, W) n! x9 T  ---------------------------------------------------------; d1 Z" D1 J  S/ Y. j3 {
  Undefined line width                6.00
, A9 w  c5 M6 w- e5 [0 ?6 b  Mirror code                         NONE
  ?3 l+ R+ ]- x, F  Rotate angle                        NONE; l. ~5 q' l7 _; a
  Offset x:                           0.00) H: O$ |9 a. R6 Q8 r. I& l
  Offset y:                           0.00
* V) b6 i' ~$ v2 q2 m1 _9 S. Y( a  Plot negative                       NO
# }' \0 l! z8 }9 j5 @7 R3 K& K  Suppress unconnected internal pads  NO
- n$ N; v  m2 b1 @  Draw holes only                     NO8 d# G* k3 W+ P% ^+ L+ ~' g2 s. n
5 j, h; [( u- I. f    WARNING: 0 width line found at (-1198.89 1386.00)
7 w  d0 D% X. A* @; j+ z           ... using undefined line width of 6.00
. P+ t. v, n* I7 E4 u
  }* [$ w$ G# u) b5 j6 N3 F6 l8 _6 D2 T2 r
7 W2 b  V  n. d7 q  APERTURES USED:
, p: _& y8 o/ c# f" D  ---------------------------------------------------------# m$ C$ U4 a0 x" g. L1 s
  TYPE       SIZE/NAME                   ROT   MIRROR MODE - ^* H% m& V( l7 G) F
  ---------------------------------------------------------: j% n, I# {2 R; x
  CIRCLE     0.00600                                  DARK
6 M& T; V7 L- O- o  CIRCLE     0.06500                                  DARK
. f. |4 o$ O  u% B! Y8 ?; Z7 Y  CIRCLE     0.08500                                  DARK
4 C# Y" K/ T( D5 y/ B- u1 e' e9 B  RECTANGLE  0.03000     x 0.05100       0.000 NO     DARK , G9 N4 A) B1 S3 ~
  RECTANGLE  0.03800     x 0.04600       0.000 NO     DARK 8 D6 [- ^) r4 L7 E- @. C
  RECTANGLE  0.06500     x 0.10400      90.000 NO     DARK 1 C* s; ]" t9 w  F+ c$ n" h
  RECTANGLE  0.10400     x 0.09700       0.000 NO     DARK & n+ I) @1 l, Q* v
  OBLONG     0.02000     x 0.06700      90.000 NO     DARK $ i' G& V3 |3 |1 `
  OBLONG     0.03000     x 0.06700      90.000 NO     DARK 4 |# x4 A  D" p+ K+ j$ e; L
  OBLONG     0.03000     x 0.07600       0.000 NO     DARK & l9 }6 ^6 N  c$ f8 F2 n5 f( V! u
  OBLONG     0.04000     x 0.07600       0.000 NO     DARK
) F2 ~! G6 q& l( Z- @# ]5 w  PAD SHAPE  SHAPE32X35                  0.000 YES    DARK
# w1 A7 z1 L' D' c  PAD SHAPE  SHAPE32X35                 90.000 YES    DARK ! z0 v* E3 w& V5 f; P
  PAD SHAPE  SHAPE32X35                180.000 YES    DARK & K7 ?) I6 ?9 V: _
  PAD SHAPE  SHAPE32X35                270.000 YES    DARK
4 m/ Y" z- E- ]3 X1 r0 X8 j7 J: E; Q5 P% z, O1 w
     BOTMASK created with warnings/ t( X! N; m2 l2 x! ^0 q
# `  f3 f1 n: m! v2 M- Y
, D" I7 e- \! W: M, k0 R
================================================================7 z" A2 a* J5 y; Y! b
     PROCESSING FILM < BOTPST >
! M, x8 D* A' ^" @- }# d4 P     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/BOTPST.art > ...$ L/ }/ L: n& b5 T2 e& ?
0 r( `, ]2 {5 V+ ]7 Y3 G8 n
7 O4 f! J$ a. q) I3 ?  FILM PARAMETERS :) W* G( C) z5 D/ K5 x
6 K8 D" N- g1 t, ~$ |5 m8 ]  Undefined line width                6.008 G+ G  I3 f. B# s2 }9 J+ R
  Mirror code                         NONE
! M( V$ o* n( j/ |" j  Rotate angle                        NONE2 Q( _( c/ P" R- j; x" b, ^9 ]
  Offset x:                           0.00
, B. N8 U6 ?/ ?0 D  Offset y:                           0.00
* b: m$ @+ t6 K# o' A8 w( t7 d  Plot negative                       NO
% w; w& o4 y- J  Suppress unconnected internal pads  NO
7 \& X3 |, p' q$ t, Z9 H( W  Draw holes only                     NO- V" b* F* u1 U0 x5 k
8 q% i8 n: ]# D    WARNING: Multiple 0 width lines; all will be treated the same as the first.7 |9 w5 N1 ~0 b( L9 b% t- w5 D6 N
& b* V/ m7 l% o6 a8 P2 N; F" a5 _4 ~
4 q; I% h5 ^0 w3 e
. R$ o; l! l! ?: k" r  APERTURES USED:
6 \; N" L4 ~) ^# k; w) o  ---------------------------------------------------------; t7 a: I! P8 x+ P; R: O; `6 t
  TYPE       SIZE/NAME                   ROT   MIRROR MODE + ]% M( k# F/ ^* w9 ^! B
$ F9 b; p- H* @  M! `  CIRCLE     0.00600                                  DARK 8 R' \) H  y( ?6 A9 p: d3 F, U* z
  RECTANGLE  0.02400     x 0.04500       0.000 NO     DARK
% D9 K% P! r2 I; I! i3 F  RECTANGLE  0.03200     x 0.04000       0.000 NO     DARK
) I2 t+ l- d1 l' z$ ]" s  RECTANGLE  0.05900     x 0.09800      90.000 NO     DARK 0 G) n0 B1 f9 j& d; h- u
  RECTANGLE  0.09800     x 0.09100       0.000 NO     DARK
& r/ D9 s5 T# q  OBLONG     0.01400     x 0.06100      90.000 NO     DARK % h( {7 x" N% a6 q7 F
  OBLONG     0.02400     x 0.06100      90.000 NO     DARK
# z3 x, b- S. S0 O$ \  OBLONG     0.02400     x 0.07000       0.000 NO     DARK ' y2 s. c+ h4 i
  OBLONG     0.03300     x 0.02900       0.000 NO     DARK % J! n- g' m2 |$ N1 U/ u
  OBLONG     0.03300     x 0.02900      90.000 NO     DARK
3 ^; X% Y& B7 z: p, L4 I+ x  OBLONG     0.03400     x 0.07000       0.000 NO     DARK / }$ v- }: g1 x3 T* T
' j+ Y* K* A1 O7 q0 C     BOTPST created with warnings
/ Z) g( O7 }8 T, s) A3 ~) l$ K3 ^/ N. }
) q& H" Z' D" u( C
# s' c& B9 G/ p! P     PROCESSING FILM < BOTSILK >! X4 n, w/ v# y! e' B
     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/BOTSILK.art > ...
# X: L" {3 Y/ P; d================================================================
! Q  J6 a. W. R3 w" r
, j( @; E% U  H8 D1 B' i7 }  FILM PARAMETERS :# k4 H2 G, w) S- W
: [& @/ b9 l5 A  Undefined line width                6.00
4 Y6 R0 c% t& d  Mirror code                         NONE
. F" n5 _+ g# \9 d8 Q  Rotate angle                        NONE# i; S. g) ~! `- Z$ o! H
  Offset x:                           0.00
: y. i( c" d+ m1 Z" O/ D  Offset y:                           0.00
- m9 A/ r& h- }. i/ c  Plot negative                       NO1 ^4 D# `4 P  s  A
  Suppress unconnected internal pads  NO! M/ v- k# B" o3 b
  Draw holes only                     NO
7 r' j7 P4 i! K6 ^: k+ N
/ j8 t! j1 |: }+ u" S9 ]9 x3 I) F. g4 u/ g( J, e% B- q
9 i! k9 v; s9 f* c  Q0 h6 j4 ], R2 m  APERTURES USED:( J: X- X+ p% n4 F1 L
1 N9 ]% z# p' H0 _) B* Y  TYPE       SIZE/NAME                   ROT   MIRROR MODE 8 R6 V4 ^, u5 ^$ i) k6 x+ B' a
  ---------------------------------------------------------$ r2 |3 G5 x, T/ J7 v* n3 A. Y
  CIRCLE     0.00500                                  DARK 1 g3 J* T8 L( n( v6 b! M
  CIRCLE     0.00600                                  DARK ; x1 ^# I- M7 u% v' ^* V
9 [3 A7 q' u7 ~8 G. X  v$ _6 C     BOTSILK created with warnings3 N7 t' f* g: n. n" j" a2 Q5 X
: e/ o+ W' g* n5 k& c2 w) n# p$ G
================================================================+ o  e1 r4 M: J! X* o2 w
     PROCESSING FILM < BOTTOM >$ _6 }, Q- U# P9 s+ r+ s- @
     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/BOTTOM.art > ...- u& E8 p! X# T5 S8 U
9 h& Q( s; T/ Q1 _: j  Q: J! u9 _7 X3 U( D
  FILM PARAMETERS :
$ _. E: ~7 l( J1 _  ---------------------------------------------------------. T; f9 ]3 T: m1 g! \* j% ^- z4 F
  Undefined line width                6.008 {) I' s2 @$ ]+ a+ d
  Mirror code                         NONE% h" u( I$ a: j. c1 U
  Rotate angle                        NONE
: \3 e8 A5 m) w. I6 W# i  Offset x:                           0.00
  [" D) V6 G9 X3 W" U  Offset y:                           0.00
+ i) B6 w3 E# C! r6 n  Plot negative                       NO
4 b5 L* {7 x( x3 B. g  Suppress unconnected internal pads  NO
* \6 N6 W9 ^$ O# _  Draw holes only                     NO
3 G, Y  Q2 K4 D2 x3 w# K! q0 _& B; ]
/ B% H! I* Z( V6 M: k4 C
4 G* q& U0 W* f2 g' q
  APERTURES USED:) V( A1 W& @8 U, e
  ---------------------------------------------------------& Y( V: m7 V( F- u
2 ?/ K" k% h. S& W+ A  ---------------------------------------------------------. l7 c! P% g0 f' v
  CIRCLE     0.00600                                  DARK $ a4 m7 `, ]" G! I6 L
  CIRCLE     0.01200                                  DARK " D/ Y# Z% s: K5 ~) c
  CIRCLE     0.02000                                  DARK ' l* @5 i6 ?. c5 O& a
  CIRCLE     0.02200                                  DARK ) g( f3 t. C" `# B$ b
  CIRCLE     0.02500                                  DARK
* \" i0 i. r+ |  [0 t  CIRCLE     0.05900                                  DARK
" u9 _! i3 X" G9 A; X) ^# U  CIRCLE     0.07900                                  DARK
0 |4 R0 p! _- [. G' g4 i. c' W# S  RECTANGLE  0.02400     x 0.04500       0.000 NO     DARK
1 U* B* r0 p" o6 k. l6 E& i. O" d( t  RECTANGLE  0.03200     x 0.04000       0.000 NO     DARK 6 y) }/ u# M7 t2 }
. p2 N. F( C+ G1 E4 r5 _' h  RECTANGLE  0.09800     x 0.09100       0.000 NO     DARK
% |5 o- K' e6 X# |+ F  OBLONG     0.01400     x 0.06100      90.000 NO     DARK
5 W* ^2 Q6 y6 o, {  OBLONG     0.02400     x 0.06100      90.000 NO     DARK 2 Z: h$ W! v/ [; S9 h' z
  OBLONG     0.02400     x 0.07000       0.000 NO     DARK ; M4 x: N) M  K' G8 Y; X
  OBLONG     0.03300     x 0.02900       0.000 NO     DARK ) U& U! _9 B+ h* |) ^  B; ?0 l
. F! |" s' k* ~4 D% q7 @& x  OBLONG     0.03400     x 0.07000       0.000 NO     DARK ' }4 {+ k4 p! B/ t
* l& D& ~  |4 E3 n- k7 ^5 f5 P     BOTTOM created with warnings
. G9 K* J% }, d& l
- x/ |8 w2 K9 \* N( V, o4 ^9 b. D% D' H6 B% n+ ~# G
3 A' y4 `/ W; ^  X9 B     PROCESSING FILM < DRILL >  W) [/ m0 _( X7 i2 b3 q; P
     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/DRILL.art > ...
# O* I  u) n; k0 B' I, ]+ S9 j================================================================
1 G+ v1 Y/ ?# R9 _9 ]
5 E% O0 ?- S! a+ |8 p7 D0 ~# q  FILM PARAMETERS :
6 ]9 p! u% ^* n/ @% c3 N  ---------------------------------------------------------
# p1 z% b2 n/ R( G) L. E  Undefined line width                6.006 `. s. _- g; f- z. l7 h2 r. a
  Mirror code                         NONE
# M' ?; M$ c& x) s. h  Rotate angle                        NONE- B! C1 L7 f5 M& Q
  Offset x:                           0.00  H* p* m/ c& l7 U
  Offset y:                           0.00
0 E/ _' {2 G5 p( r$ ~  Plot negative                       NO
( Z; ~3 A( x& B; G( |" Q7 h  Suppress unconnected internal pads  NO/ I& C8 @, c" Z/ u/ c: ~: ?* K
  Draw holes only                     NO
& g0 M2 L0 d! {$ ^, K5 d$ h: X6 m
    WARNING: text composed 0 width line found at (-771.80 2586.30)
* r8 ], r7 F: p5 `. q           ... using undefined line width of 6.007 ^- C& u) p( P* J- p
; K8 {  M+ Y! p+ T' N8 f# S  g    WARNING: text having Multiple 0 width lines; all will be treated the same as the first.
2 L! k3 x2 R  E) C( @  B           ... using undefined line width of 6.006 T' w3 c  [9 E; m' ?& [4 f
# L' @! t3 m& t3 N$ D! \
3 i! f7 D" t/ S5 l
5 Q, D0 s' ]5 d6 {
  APERTURES USED:
# g2 E* G& ?( ?( s4 [: J7 k* t  ---------------------------------------------------------$ h) X% @* q0 p7 h) p3 G: S9 _8 v
  TYPE       SIZE/NAME                   ROT   MIRROR MODE ' }* X( T; v. o9 M) T) F7 k9 i2 c
3 h4 ]* j. {% I5 F) \. B  CIRCLE     0.00600                                  DARK
8 q" Z! Y  h3 c
  a  }1 e- y6 |( W, d2 }  M' V     DRILL created with warnings
" m( C! `/ B2 Y) p" w' U6 F5 O8 s! l% C. b, \+ v
2 ^8 _& o0 q* g7 j  v. K3 D
================================================================  G# u' d% k3 o$ y7 Z! Q  B; x
     PROCESSING FILM < TOP >: F/ w# W3 `4 R
     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/TOP.art > ...
+ G0 d: A( s7 O1 i================================================================
6 g1 `+ Z- N9 |9 {' G. X: Z% m5 a0 c1 p0 e
  FILM PARAMETERS :: Z# ^. m( M0 {2 X7 j  w
  ---------------------------------------------------------( b! n% c' n- j0 m
  Undefined line width                6.004 _5 |+ I& Z5 N& l5 d
  Mirror code                         NONE/ B) m0 I7 t/ [& U/ s
  Rotate angle                        NONE
# A' {, N, Q+ {0 W& C8 X" M2 P  Offset x:                           0.00
$ d1 ]! J$ O0 k5 j; w  Offset y:                           0.000 x# h' J- d0 }* k8 _; N! @
  Plot negative                       NO
/ }  ?- W: K6 q  Suppress unconnected internal pads  NO
9 n/ {% d* P- a  Draw holes only                     NO
: L( ?! r( x6 m* h1 G
  ^; J) p% i  ~
7 q7 O2 ]# V6 F0 [  g3 V0 |: `. m# L8 ]& F+ ~/ A
  APERTURES USED:6 l! z/ t* u6 v
  ---------------------------------------------------------) s4 ^4 q/ p% A# R" b
) J+ o+ i/ B/ D& c( h* g  ---------------------------------------------------------
, S: y0 @$ h3 z# }, M) C  CIRCLE     0.00600                                  DARK + W9 t% k$ \. _9 i2 P# M
  CIRCLE     0.02200                                  DARK
( p+ g  S" C# z2 D! {' O( m7 T5 L3 ~  CIRCLE     0.05900                                  DARK
, f2 S3 Y0 e2 H. j5 R0 i  O  CIRCLE     0.07900                                  DARK
+ C( r% R6 d5 b" S( K3 {9 g" I  RECTANGLE  0.03500     x 0.07000       0.000 NO     DARK $ a& j  J4 p1 e9 f* B3 g8 O/ B3 P5 Y
  RECTANGLE  0.04000     x 0.03500      90.000 NO     DARK % r7 L  D8 h0 T4 v  ~
" l2 l* i9 B. U% g; R
     TOP created with warnings8 b/ W' H' v6 I3 P: T6 X
8 Z) |4 m, \6 Y& y1 ^; h
- x  `- P5 s* ^: l================================================================
6 w% t* d0 @& B/ B3 n     PROCESSING FILM < TOPMASK >
9 e+ W$ ?; z5 n4 U! y1 X     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/TOPMASK.art > ...
# Y: [9 i1 W% d+ h& C================================================================/ N) o+ U. r7 }: W- z. I
' o, M+ G8 P1 Q% b7 R
  FILM PARAMETERS :
9 F  h) p: C8 G/ n0 j+ ?7 B  ---------------------------------------------------------
" M* m# {2 O$ h+ L$ p% l  Undefined line width                6.00
# a' ^2 ^( m5 F8 k9 \  Mirror code                         NONE9 k$ w  g* `4 \9 o$ D2 F# a  k
  Rotate angle                        NONE
$ }2 d$ g# ^: g8 Q* H  Offset x:                           0.00
' l+ G. N7 {( w5 T0 J* a+ F! q  Offset y:                           0.00
( m2 M8 l& }' |( v  a2 s2 q  Plot negative                       NO# s' h, H# Q( z8 r/ C! `1 s# D7 ]; C
  Suppress unconnected internal pads  NO- x. K2 Z/ y: F' M
  Draw holes only                     NO8 D; ~' T" c& o8 H2 c( o* ^! s
$ p) F! E& Q+ b" s% L) e  L. C
/ s! Q. F  T9 e
7 f0 ^) g+ _- F7 p
  APERTURES USED:5 A! }# }1 |. x3 |4 e$ R2 ^9 G
' K. V, G* {% T6 V0 S  TYPE       SIZE/NAME                   ROT   MIRROR MODE
) ~. e( x. y  [0 G  ---------------------------------------------------------
) C2 W5 B5 d$ b; S  CIRCLE     0.00600                                  DARK
- j! r0 h' I& z6 m& a3 E. o  CIRCLE     0.06500                                  DARK 3 H0 L9 j* _' {/ x. o
  CIRCLE     0.08500                                  DARK 8 [0 r' ?+ v7 h% o7 G
  RECTANGLE  0.04100     x 0.07600       0.000 NO     DARK 0 ~- m0 X; H8 A, P/ U" k+ D
  RECTANGLE  0.04600     x 0.04100      90.000 NO     DARK " c+ w- c' `  P+ a- Y
' {% I* I7 G8 `, S* `     TOPMASK created with warnings
/ D1 P4 X, F' G, R# |
5 T. |) h# y1 e6 L; @
# z" h" L5 A0 V9 B# c5 \0 i================================================================7 y6 W( p& W' V( {" X+ ?
     PROCESSING FILM < TOPPST >' y; X+ \- J; T! {0 o- J
     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/TOPPST.art > ...6 q* K; j8 G- O+ t* j
. Y+ S3 [1 T# w
% z$ S; b% Y3 N& I! d  FILM PARAMETERS :
' J1 a8 A9 V4 J$ F  ---------------------------------------------------------* j8 N/ w, V0 v  Y
  Undefined line width                6.009 T2 E3 C. k, ?
  Mirror code                         NONE
7 n, t( V. \, ]6 f  Rotate angle                        NONE
9 w8 @, ~  J) k: p  Offset x:                           0.00
9 [. J7 |  y9 _5 `  Offset y:                           0.00
, C, n9 i! P1 v& ]- p  Plot negative                       NO
% J) A5 W$ O/ i! ?$ u8 M* H4 K8 E/ d  Suppress unconnected internal pads  NO
* t3 M+ m) R  }8 b. \5 `6 M  Draw holes only                     NO; x' O" Z3 K7 i% |3 f8 Q1 ^
  i  {6 g/ [8 q, r3 V' G  z
, w. |- B1 ^' _$ R, E: w3 T0 _
- s# x: c; c& p; a/ H  APERTURES USED:; s9 Z' f5 m% }1 y; R
6 c5 B$ q  I7 X% t  TYPE       SIZE/NAME                   ROT   MIRROR MODE : ~1 a! j* U; ~* H7 {
+ u# d1 ?2 R! }) F1 r0 Q5 O- [  CIRCLE     0.00600                                  DARK
0 e' a- ~; t0 e4 ^( F  RECTANGLE  0.03500     x 0.07000       0.000 NO     DARK 9 X6 s! Z. O, }
  RECTANGLE  0.04000     x 0.03500      90.000 NO     DARK - n5 c4 S5 P( ?$ ?* S0 M
9 G- B/ m$ ~# K- {1 R9 T  k+ ~  w     TOPPST created with warnings7 k, t/ {. e# `: g. x9 a
$ m4 `0 E2 ^  g4 ]
9 _+ f' L# }2 \! p================================================================
' ?; i" X  I) {* x     PROCESSING FILM < TOPSILK >: ^$ c3 |' V' M3 A
     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/TOPSILK.art > ...
) z9 Q5 P' }0 r8 D7 l* y================================================================6 R& y3 Q* y1 z- }4 g) D
/ o, \, L4 t- u7 w* h. O' _% @  FILM PARAMETERS :1 q( A/ S% n, l& l7 \$ @
  ---------------------------------------------------------2 n1 e6 a, L( Y) ?/ k$ ~
  Undefined line width                6.005 a4 x) p$ S: D1 G) ^
  Mirror code                         NONE
& [  N$ e2 X  H* m0 j  Rotate angle                        NONE, }# B* v8 T3 G
  Offset x:                           0.006 J. d, z! q" s! W$ {& q) \3 G
  Offset y:                           0.006 Q# L* @9 Q, E' w
  Plot negative                       NO
% ^( K2 j( H2 V+ j+ y% m- [) k" k  Suppress unconnected internal pads  NO  O7 D. u- \. S  p( O( C
  Draw holes only                     NO
; E2 p! r' D0 t3 G8 v' H9 b9 b
' F$ ^% Z2 v  Z% I* n1 m% V
7 v# ?' u) r; {1 _' o6 @0 b. Z8 M# V; d  {6 B8 P* B. T+ a
  APERTURES USED:, G2 q* H/ d2 G( X% L; A( Q. W
  ---------------------------------------------------------# i' o* Q/ O- D3 N! m6 W" R, j
  TYPE       SIZE/NAME                   ROT   MIRROR MODE . z" Q/ s0 d4 ]7 @( {. |# S5 a3 o
" S% d4 J3 i$ Z  CIRCLE     0.00600                                  DARK
3 G5 T" o% n0 L6 m# q2 i" P- E. G, \6 m. T, {; I: \' [
     TOPSILK created with warnings
$ D) t+ E1 ?6 |6 [
+ c0 d1 Y: b0 d9 n8 F& L' M3 B4 ]$ K
------------------------------------------------------1 B0 g6 ?0 H- k' j* l/ k( |
SUMMARY:
3 ]+ P* l' _) h( R7 x0 w        BOTMASK created with warnings
" }$ }1 E# C6 z8 z0 \        BOTPST created with warnings
. n( W3 @7 Z# Q$ T; o+ ^        BOTSILK created with warnings
" ~) t' S9 O7 n+ [        BOTTOM created with warnings
; R2 {/ S: ]- }9 f# Y7 |; e        DRILL created with warnings
9 w) e2 {+ F4 h        TOP created with warnings
) z- |0 ~- l1 w9 O' {        TOPMASK created with warnings
8 T6 H! z7 }4 _        TOPPST created with warnings
$ P' a; F( Q: m3 W        TOPSILK created with warnings6 v9 [9 H1 x; ]  A" u
/ `( }3 \; A6 [6 S3 K
ARTWORK had warnings
2 h1 \& K. f: z0 d
    奋斗
    2025-11-21 15:48
  • 签到天数: 135 天
    [LV.7]常住居民III
    发表于 2013-10-16 17:04 | 只看该作者
    , t/ D  x- ~8 H# Z! ~2 U           ... using undefined line width of 6.00, ~' O. p* k+ H
    7 F' |6 [/ L! t" a4 g  N2 R0 S# A1 a% t. `, y3 R& o' v8 a. r3 O0 |! H. ^
        WARNING: text having Multiple 0 width lines; all will be treated the same as the first.$ U$ w+ e( M# h/ Y4 ]: {+ j4 N
    5 V8 P/ N- u" Q1 C. c           ... using undefined line width of 6.00
    发表于 2013-10-16 17:05 | 只看该作者
    如果像这样每一层都有warning,最大的可能是你的画布>24000*16000,调小点。
    $ q; y. d  }* ~( T  u6 g& {7 U然后再把0宽度的线改一下就ok.
    发表于 2013-10-16 21:54 | 只看该作者
    樓上的猜測不對.% s5 ?5 L" y- {, E8 Q
    這很單純的是因為要被產生成gerber 的底片資料裡面有一些線條是沒有給寬度的.
    8 L. @0 Y+ i- B  {* k4 y沒有實體大小的資料是無法被產生出 Gerber , 因此系統這時候就會引用 undefine line width 這個設定值來代用 , 幫然因為也不知道這些資料套上undefine line width 這個設定值是否合理 , 因此系統一定會給出警告的訊息 , 讓使用者注意
     楼主| 发表于 2013-10-17 09:24 | 只看该作者
    procomm1722 发表于 2013-10-16 21:540 z: q* p, A3 r' I( f) x" {2 e3 U
    樓上的猜測不對.
    4 I7 @4 W3 u) G& k* T  u/ l這很單純的是因為要被產生成gerber 的底片資料裡面有一些線條是沒有給寬度的.' G1 o0 R/ n8 S, \! u% F0 g
    沒有實體 ...
    $ R6 I) m3 j6 T& o4 b# F: T" n+ c! v% b请问出现这个问题有影响吗,或者说如何解决呢
    发表于 2013-10-17 13:39 | 只看该作者
    要說有沒有影響 , 一般應該是沒有影響.
    7 T& L4 _& c9 \% a  C' ^但是心裡應該會覺得毛毛的 , 不踏實.& o4 p$ c6 x6 T
    但你只要把零線寬的資料( line , text )補上寬度(width , photo width ) , 自然就不會有這種訊息出現.
     楼主| 发表于 2013-10-17 16:19 | 只看该作者
    procomm1722 发表于 2013-10-17 13:39
    % R! N( p, f- U3 b+ m6 y要說有沒有影響 , 一般應該是沒有影響./ g+ N. m0 w1 b) n* G+ @/ s3 c
    但是心裡應該會覺得毛毛的 , 不踏實.6 j$ X4 }/ G' B% s
    但你只要把零線寬的資料( li ...
    ! J0 F" T) T: ^/ _+ N谢谢{:soso_e100:}
    GMT+8, 2025-11-22 08:39 , Processed in 0.171875 second(s), 23 queries , Gzip On.
