查看: 769|回复: 3
pads中为什么PCB铺不了铜,线布好了,铺铜边框也做了,急急急!!!
发表于 2013-9-24 16:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
错误提示为:THERMAL RELIEF ERRORS REPORT -- GQ4002main09245.pcb -- Tue Sep 24 16:42:30 20135 k9 u) ~8 J7 r! [/ d; f
1 k4 @; J) J& H5 v+ }
# b' B. I' \9 i/ x- P
       Drilled pads with                    Nondrilled pads with
( p% c, O) ?, y' c. sless than 50% thermal extensions      less than 50% thermal extensions# j3 Q' r+ L- W! \
  O; D" Y. O& b; y* Z% eReport of Thermal Spokes Generator.
. O$ d' l+ @* r# _( R
$ \) J8 f, D6 X6 t. Q- h1 G4 E$ IOn Bottom:
2 \6 H0 t2 X+ ^0 q$ h( q                                        U7.R14  (42.13234, 60.72836) # = 0. ?$ m6 c; x: A: m5 i7 D
                                        U7.R13  (41.48234, 60.72836) # = 0
! J1 g  t% ^4 O4 ]; u, M) _, m                                        U7.R10  (39.53234, 60.72836) # = 0' U$ ?( X* z6 o2 Y% K% j9 G0 \9 W1 ^9 g8 w
                                        U7.P11  (40.18234, 60.07836) # = 0/ }  }! c" b  r' E/ ?. l
                                        U7.N10  (39.53234, 59.42836) # = 0
+ I8 a' L; z! g6 J! x; B                                        U7.K8   (38.23234, 57.47836) # = 0
' o2 H/ }% |. T! }3 s                                        C41.1   (31.61528, 53.95756) # = 1
; p' v2 V+ J4 [5 g/ p8 e% X                                        U7.AA13 (41.48234, 64.62836) # = 1
) u% f/ n$ Z  `: V                                        U7.AA10 (39.53234, 64.62836) # = 0
8 V$ g# k9 T, t) [4 d) m1 f- L/ C7 @: Q                                        U7.C8   (38.23234, 52.92836) # = 12 g) s( N* \4 ^" [% S
                                        U7.J7   (37.58234, 56.82836) # = 0* V# Q0 N) R  p- f
                                        U7.C9   (38.88234, 52.92836) # = 1
, V* G% ^; r- T1 |' H0 h" y                                        U7.N3   (34.98234, 59.42836) # = 0) l" ~9 h. E: M6 C3 K
                                        U7.U8   (38.23234, 62.02836) # = 1
- H/ f; H1 ^* b6 \4 n1 ]                                        U9.B8   (36.26414, 70.39505) # = 1; J, B6 e' X/ N9 E) K$ D9 |
                                        U9.F8   (39.46414, 70.39505) # = 1
! B7 f  F6 v% J, e                                        U9.D8   (37.86414, 70.39505) # = 1: L, g' W( P2 g" w  }5 L# |
                                        U9.H2   (41.06414, 75.19505) # = 10 J  N6 m, i: d" `) d
                                        U7.C11  (40.18234, 52.92836) # = 0
( J; e- J0 F- q# F, [                                        U9.A3   (35.46414, 74.39505) # = 1
3 G3 B) a; f& u                                        U7.K6   (36.93234, 57.47836) # = 19 V5 _) g" h6 ?4 v* J$ p  n
                                        U7.T15  (42.78234, 61.37836) # = 0* _9 C& B* W% u- c% g
                                        U7.T14  (42.13234, 61.37836) # = 0
  m& k+ q7 @: K                                        U7.T12  (40.83234, 61.37836) # = 0* o( |- f# i! d! u
                                        U7.T9   (38.88234, 61.37836) # = 0
1 y5 x7 ?3 f4 L8 D                                        U7.M3   (34.98234, 58.77836) # = 0
- H8 x# R" Y  {6 A+ H# N                                        U7.L3   (34.98234, 58.12836) # = 05 c4 \. h7 F" r( {5 c+ N: D  {
                                        U7.J11  (40.18234, 56.82836) # = 0
2 c4 a5 z! L( C9 w. V( @7 X2 R& S                                        U7.C7   (37.58234, 52.92836) # = 1( `/ `3 S* R3 E  O( Y7 K9 e
2 W( |  G! M% X0 T/ T
On Top:8 v9 c* u0 S0 ~" M7 V. S, v
                                        C162.2  (49.19243, 58.67523) # = 0
3 `3 D8 N/ [. U  V- N" u5 e: B9 h. ]                                        C46.2   (32.62971, 51.89029) # = 0  K" ~4 [! R0 r; g
                                        C143.1  (39.03136, 52.63647) # = 1
: \+ n+ r" v; E5 d, z                                        J6.22   (46.44413, 44.38196) # = 0& c( t1 ~& n# k. Q* w9 D4 T
                                        C15.2   (65.26357, 66.42046) # = 0$ k3 \  `4 d% O
  f( h8 k" l( }( N6 JTotal Drilled pads:    0               Total Nondrilled pads:   34* d, e4 V0 {. a. |- ~4 e
发表于 2013-9-24 17:10 | 只看该作者
一、检查板框设置;, w5 H1 N- p1 a1 x
二、区域内是否有对应的网络过孔;
发表于 2013-9-26 13:20 | 只看该作者
搞定了吗? 没高点就把PCB文件发上来帮你搞定。
发表于 2013-9-26 14:46 | 只看该作者
有没有给铜框覆网络?
GMT+8, 2025-8-15 22:21 , Processed in 0.125000 second(s), 23 queries , Gzip On.
