查看: 955|回复: 1
铺铜时出现大量提示^
发表于 2013-9-3 13:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
铺铜时提示如下问题,不知道是什么意思,看铺的铜又没有什么异常啊+ {% I4 c5 S% C+ ~$ y* X' o
0 f& A# @7 q" g: w/ L' \+ z+ ], ^9 U' W) z! f- l  v1 A/ a! J% w3 G
; p5 k* i- e! Q! f2 Z( g' Y( MTHERMAL RELIEF ERRORS REPORT -- LY-S5E4412-CORE-PCB-SV1.3-130903.pcb -- Tue Sep 03 13:20:50 2013: x# [6 C9 m( c. |" |0 x
' C4 ^1 X9 A% ^( p: v- b! i& ^2 P
5 N  Z$ A+ H$ s: F       Drilled pads with                    Nondrilled pads with
# r% I6 p  [9 U# R3 M' N7 Iless than 50% thermal extensions      less than 50% thermal extensions
$ d1 R: {- z- x6 r! Z% D7 L2 ]& P$ f" E( e3 F
Report of Thermal Spokes Generator.
$ r) {0 o, z6 s: [, k
/ p+ w, p5 A/ }6 WOn Bottom:
8 s: K5 k- [2 @# s0 D' X                                        C20.2   (4175.45, 3221.77) # = 1
2 p5 ?4 z; `+ q% j: ?* E% M; _                                        C9.2    (4108.97, 2650.44) # = 0
3 a1 u+ P/ T7 M/ C: N" ~3 [  y+ ]                                        C81.2   (4787.65, 2844.44) # = 0- }3 A: H2 u6 Q" n8 X2 ~" J" K# q
                                        C67.2   (4566.86, 2622.42) # = 1
5 Q6 }- ^3 Q% Q& o! J( r4 `                                        C36.2   (4517.82, 2828.28) # = 1
' m4 r* \; d( |: m                                        C25.2   (4367.72, 2819.48) # = 1
* }. X. z+ {/ p0 m                                        C119.2  (4240.72, 2617.48) # = 16 U' y3 ?( W4 D3 R
                                        C11.2   (4134.09, 2981.1) # = 0
* {, E  q5 i3 i5 f* T9 h  F+ V' ?  a                                        C22.2   (4475.21, 2901.1) # = 11 x8 t# H) v' U5 A: b- h
                                        C41.2   (4464.34, 3006.1) # = 12 C9 s1 t7 J* C2 y3 Q
                                        C15.2   (4266.09, 2833.1) # = 1
$ V0 t! M9 {8 u6 }- V3 f                                        C40.2   (4263.22, 2955.1) # = 0
; g2 m3 c$ \, k7 t+ C8 }                                        C120.2  (4751.3, 2604.53) # = 1
- Q5 F  O1 c4 L4 @  E. g+ X9 i
/ ?7 t. v- V5 LOn SIG06:
/ C; I, v. u  u* J9 OQ3.1    (3506.09, 3950.28) # = 1( T# E4 w1 k& ]# y
# E7 w. g# m0 ?# N8 F) lOn SIG3:4 ?5 f" V3 s+ F7 K. L7 k) f
Q3.1    (3506.09, 3950.28) # = 1$ k3 j# c* W( y3 R1 ~  f6 Z; E
U51.32  (3252.9, 3740.82) # = 0
& G. q4 K$ @8 p7 C3 Y4 k0 HU51.33  (3252.9, 3662.08) # = 0% t5 v# ?4 L* U* p2 l) u
. S7 r, ^! w4 p+ q/ T+ W  j. gOn Top:9 O! \5 p, a# \" t
                                        U6.T9   (4530.03, 3769.33) # = 0: _3 M* Q4 a1 l- Y! J7 D) ~
                                        U8.27   (5297.69, 3638.13) # = 0* D  A; A  [+ o0 d0 c  ?* x
                                        C127.2  (5159.23, 3748.23) # = 0
4 L2 J) O) O# v1 G                                        R69.2   (5104.93, 3743.23) # = 10 H; B- e+ P* p' t
                                        U5.M1   (3602.73, 3251.4) # = 0' x0 O1 f# n/ w; U
                                        U7.M9   (4080.98, 3643.29) # = 0
9 R( \' p, w9 F& h% v                                        U7.M1   (4332.95, 3643.29) # = 02 Z' F. k; U: `, N- W
                                        U7.J8   (4112.48, 3548.8) # = 06 w2 w$ c# p- S5 g5 S
                                        U7.J2   (4301.45, 3548.8) # = 0
& K: N* F/ q% y* l                                        U7.G8   (4112.48, 3485.81) # = 0
: A! Q* c& K: P4 w9 \2 y                                        U7.E8   (4112.48, 3422.82) # = 0. E' J) r7 j  X& G& j1 e8 e
                                        U7.E1   (4332.95, 3422.82) # = 0
- B7 M, i# D3 Y                                        U7.D8   (4112.48, 3391.32) # = 0# j$ y' e- h; T0 Z' T8 ^1 c9 j& C- b3 z
                                        U7.D1   (4332.95, 3391.32) # = 0) j+ z* q" p) B9 L, x6 i
                                        U7.B9   (4080.98, 3328.33) # = 0
9 h  }2 h$ [1 `( [' a                                        U7.B1   (4332.95, 3328.33) # = 0* H& X, r/ j( Z( R0 F
                                        U7.A9   (4080.98, 3296.83) # = 0
& \( p7 m6 J9 O6 |                                        U6.P1   (4782, 3706.33) # = 0
' j& b5 d; r* P1 D/ Q) x                                        U6.M1   (4782, 3643.34) # = 0
. K8 n8 ^" I/ Y6 R                                        U6.J8   (4561.53, 3548.85) # = 0
- D  W# E1 [* K1 S. R                                        U6.J2   (4750.5, 3548.85) # = 0
; [2 |3 j  a$ O+ O! w                                        U6.G8   (4561.53, 3485.86) # = 0+ ]+ M: D6 ^* w' `: d
                                        U6.F9   (4530.03, 3454.36) # = 0
9 @5 g  I+ I3 E; p3 N/ X                                        U6.B9   (4530.03, 3328.38) # = 07 X# [5 I4 z: O: v
                                        U5.T9   (3476.75, 2999.44) # = 0! S! B  O% W8 o( L
                                        U5.P9   (3539.74, 2999.44) # = 0
5 z! X/ y1 @, Y5 ^+ q                                        U5.P1   (3539.74, 3251.4) # = 0! Y: \0 S# k) A) I0 P# E
                                        U5.G8   (3760.21, 3030.93) # = 08 ?3 A6 P# a3 ~3 R, L) o
                                        U5.G1   (3760.21, 3251.4) # = 0
' e. n* o! m+ F' X                                        U5.E1   (3823.2, 3251.4) # = 04 A9 ]1 b4 U8 E* k
                                        U5.E8   (3823.2, 3030.93) # = 02 q$ H- j* ]) m; Q5 Y
                                        U5.B3   (3917.69, 3188.41) # = 0, ^) f" y4 }9 l3 y
                                        U4.T9   (3476.8, 2537.12) # = 06 U  z" i# a  h9 F
                                        U4.T1   (3476.8, 2789.09) # = 0: g3 G9 l3 D4 C; |( I' ?
                                        U4.P9   (3539.79, 2537.12) # = 0
' ]! l- f6 R6 [9 A/ H7 C                                        U4.P1   (3539.79, 2789.09) # = 0
/ ~! n/ j% i; T# j5 k: @                                        U4.J8   (3697.27, 2568.62) # = 02 J$ v; e5 `7 m: F, z6 n. p2 K
                                        U4.G1   (3760.26, 2789.09) # = 0
. q" |9 N# o/ n) N9 F* Z                                        U4.F9   (3791.76, 2537.12) # = 0
9 T9 y1 i) ^* y                                        U4.E1   (3823.25, 2789.09) # = 0
9 T8 F  c1 S3 |: ?                                        U4.D8   (3854.75, 2568.62) # = 0
2 `4 b4 y5 {! Y: a: ]                                        U4.A9   (3949.24, 2537.12) # = 0
9 \5 r! u3 v( a( y$ R, y                                        U11.R10 (5208.04, 2690.92) # = 0, W( ]1 M1 o' }1 y& Y
                                        U11.P5  (5306.46, 2671.24) # = 0
# z5 D6 N# l. K: s% s                                        U11.K4  (5326.15, 2592.5) # = 0
# B2 z5 ?/ ?5 c" J5 ~                                        R99.1   (3557.77, 2419.88) # = 0
; J1 C! I- R# Y$ ]3 x3 @  X                                        C2.2    (4037.52, 2412.33) # = 1: E! J, x. G8 U! n! h% Q
                                        C1.2    (3945.43, 2413.79) # = 1/ |7 w2 o0 m  Y% E! E, [$ B& e7 \
                                        U10.12  (3530.32, 3701.12) # = 0, a% q. Y# x+ d  \5 N
                                        U8.20   (5358.71, 3545.61) # = 0
3 n- j7 x, P5 C9 a% s  N; M                                        U16.AK26 (4815.03, 3146.14) # = 0+ V: n2 P# I7 O. Z( ~1 a
                                        U16.AK18 (4815.03, 2941.42) # = 0
2 P& ?1 j! X1 a" f# F. J/ E                                        U16.AK1 (4815.03, 2506.38) # = 0% B: O( m& V1 Y, g  C' {; Z
                                        U16.AH14 (4763.85, 2839.06) # = 0
: g" X; ~% @8 R- V9 _/ B                                        U16.AH7 (4763.85, 2659.92) # = 03 c/ [$ M- t& b2 D4 `0 X1 g; V- C
                                        U16.AH4 (4763.85, 2583.15) # = 03 j! Z  b9 w! }* f) d% p
                                        U16.AB10 (4610.31, 2736.7) # = 1
: N$ c5 F6 O: @- N  v                                        U16.AA24 (4584.72, 3094.96) # = 01 O5 F" }. {" ^, V) a/ ?
                                        U16.Y9  (4559.13, 2711.1) # = 1
4 Y4 o7 h" r) K5 w                                        U16.V14 (4507.94, 2839.06) # = 1* l1 n5 k# l1 G
                                        U16.V10 (4507.94, 2736.7) # = 0) Y5 i# P! G8 D/ p6 O# J1 W
                                        U16.T25 (4456.76, 3120.55) # = 0/ n6 _: r+ K2 n) l" U$ w
                                        U16.T9  (4456.76, 2711.1) # = 0
, j" T1 A4 T+ E                                        U16.P23 (4405.58, 3069.37) # = 0
# l8 o' E( h' F* v8 Z                                        U16.P21 (4405.58, 3018.19) # = 0
) x4 C2 o& P/ v4 B% m( ^6 {$ D                                        U16.P9  (4405.58, 2711.1) # = 0
  C5 u3 i. Z. C3 z6 c- b1 V; x                                        U16.M26 (4354.4, 3146.14) # = 0
1 y3 s. {% `" P$ m  c# m' T                                        U16.M21 (4354.4, 3018.19) # = 1
8 h* v3 M# S6 P8 v' e: p                                        U16.M19 (4354.4, 2967.01) # = 1
/ Q) I: e$ g9 e% h9 h8 G                                        U16.M9  (4354.4, 2711.1) # = 05 b* l4 d7 `6 \9 r( V
                                        U16.L4  (4328.81, 2583.15) # = 0
5 o5 o; `- }* q7 {  Y                                        U16.K26 (4303.22, 3146.14) # = 02 i' i& H/ x/ J6 u# o. N% G
                                        U16.K11 (4303.22, 2762.29) # = 17 v# ~1 @1 z: D4 ?: U; z) x5 u% S. k
                                        U16.K9  (4303.22, 2711.1) # = 1
) Y7 [( P0 M, x' s& w                                        U16.G26 (4226.45, 3146.14) # = 0
5 @  v! K' h  N% |: y2 g                                        U16.F14 (4200.86, 2839.06) # = 0
' A3 O, P2 h; ]% Q                                        U16.E26 (4175.27, 3146.14) # = 0
4 k1 H+ v0 h, j  O2 @) O                                        U16.C26 (4124.09, 3146.14) # = 0
7 Q# s: e# a+ r, C4 [) ~& i                                        U16.B19 (4098.5, 2967.01) # = 0- M; U0 s. s5 l& @: P
                                        U16.B10 (4098.5, 2736.7) # = 0' M8 r" n" k2 f* x  D0 T& P' P6 w
                                        U16.A2  (4072.9, 2531.97) # = 01 `7 l. _8 ~9 v* d
                                        U7.P1   (4332.95, 3706.28) # = 0
9 \; U" D. g+ X; u( ]                                        C157.2  (3650.88, 2373.98) # = 1
) Q1 ~: B# B, z, r9 `0 g5 I' F; V7 I/ e, s1 j1 [
Total Drilled pads:    4               Total Nondrilled pads:   96' e% p$ k' ]6 N4 k9 R# p
. r4 }2 D  m/ k) x$ i! YReport of Violating Thermal Spokes Remover.' T% G5 N% K- F  i1 h
- ]& r$ N. B: N4 P' {' _
On Bottom:( k  j; V) ]4 p# c
                                        C119.2  (4240.72, 2617.48) # = 0
( @# B# j- t  ^2 R' E
6 p6 L6 m  s, q( t7 d. lOn Top:3 }" R0 e. E2 o2 ?
                                        U16.AB10 (4610.31, 2736.7) # = 0
+ l+ c2 ?3 [6 N! ^: z& K2 I! P! W1 j
Total Drilled pads:    0               Total Nondrilled pads:    2
* P" F1 Q: R2 J; Q' y$ w
 楼主| 发表于 2013-9-3 13:36 | 只看该作者
已经查了资料,原来是热焊盘问题,已解决,谢谢!
GMT+8, 2025-8-16 14:39 , Processed in 0.156250 second(s), 23 queries , Gzip On.
