查看: 2508|回复: 2
Allegro to PADS Conversion
发表于 2013-7-30 11:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Does any one know how to convert allegro pcb file to pads? I have PADS 9.5 and pcb file is in Allegro 16.3. I tried the procedure given in PADS manual but it fails.Can any of you please help?
发表于 2013-7-31 13:08 | 只看该作者
(1)https://www.eda365.com/forum.php? ... ight=allegro%2BPADS
- E3 E  b6 D1 s( T. o& H(2)allegro to Altium designer ,then to PADS ,sometimes you can not convert file in this soultion.
发表于 2013-7-31 13:30 | 只看该作者
推荐使用第一种方法,亲测可用.就是丝印元件编号和测试点需要重新调整.其他都是完美的
GMT+8, 2025-8-7 02:30 , Processed in 0.109375 second(s), 23 queries , Gzip On.
