7 E# `; A7 \+ K; S, sDatabase Integrity Test Report on file Untitled -- Tue May 14 08:32:20 2013
" V/ T! c/ H( l- `: Z
4 \6 c8 M, W# } [======================================================================
6 ~! K% Y7 n7 ?; ]) v
( N* t# W" n/ j5 ^ERROR: Some pins of part type TQFP_14X14_0MM4_128_EP are absent in the pin map.
, u0 C$ z, n) N$ k
: C. u- `. `9 A6 nERROR: Pin P_PAD of part type TQFP_14X14_0MM4_128_EP is used twice.
3 R% I. H( a( S- f0 V8 J1 v/ Q# x' D0 v
ERROR: Some pins of part type QFN32_7X7_0MM65_EP are absent in the pin map.# @! _3 q8 t* _8 h: f
0 v( ]3 z. P5 [) n$ h+ ]: D
ERROR: Pin P_PAD of part type QFN32_7X7_0MM65_EP is used twice.' m% [3 C/ m- N S
$ p: y3 b5 r* H' F- Y% [/ l" cERROR: Some pins of part type DFN_12_4X3MM are absent in the pin map.
1 t, ]- A7 W+ M. Z% L$ F. P1 p3 l: A4 n6 B( j. z; K% @8 v
ERROR: Pin PGND of part type DFN_12_4X3MM is used twice.
- R( t Y& c+ A% i B7 h
# T! Q' l- \. J/ M6 q: fERROR: Part Type TQFP_14X14_0MM4_128_EP has two pins P_PAD in gate A.% O x2 d$ |' a0 J( a3 |
# ]: O9 Q$ b0 e6 a
ERROR: Part Type QFN32_7X7_0MM65_EP has two pins P_PAD in gate A.
1 [! ]8 v7 ]7 F/ l0 e# o1 L8 d9 Q- j0 N3 A# w
ERROR: Part Type DFN_12_4X3MM has two pins PGND in gate A.
% x. t0 W5 Z) j* A4 ^ |
