Part Type LTC3454EDD has a gate with 12 pins in the design and 11 pins in the Library.. Q$ l' b1 U% Y4 y" r4 s, D
Non matching Part Type LTC3454EDD is used by the following parts:
5 t1 H# A, t. K2 Z U6.
- V; V7 c( j, W3 `PCB Decal JST/XHD3_2mm not found in Library - not able to check following parts of Part Type HD1X3:
8 B6 a5 W& \6 N" i0 x J1.! G0 J) Z. j0 w7 i7 |
PCB Decal SOD123 not found in Library - not able to check following parts of Part Type 1N5819HW:
8 S" [ c6 q9 W. X9 D/ N6 b D2.& }, g* ~- E7 r
Part Type ZYA1001-FRS05 has 1 gates in the design and 0 gates in the Library.- { k# N* A+ C( E9 c
Non matching Part Type ZYA1001-FRS05 is used by the following parts:
a3 O6 \% V! T; i J2.
/ i/ p' z$ D( q3 Y. SPart Type PAD has 1 gates in the design and 0 gates in the Library.2 j( ], z- F+ K) P+ m( U& N; r! T
Non matching Part Type PAD is used by the following parts:
9 s6 t' y4 o' V J3 J4.9 K- }, x7 \, S5 ?/ X
Part Type ZYA1001-FRS06 has the following gate pins that do not match to the Library part:. N- y. G0 A, r9 r
(6 1) (5 2) (4 3) (3 4) (2 5) (1 6) (8 7) (7 8).- U, w0 C% o n& J h
Non matching Part Type ZYA1001-FRS06 is used by the following parts:& ~/ M" \$ i! Y7 f8 y
J5.& u" H! b8 t% h1 H
PCB Decal C1210 not found in Library - not able to check following parts of Part Type CAP1210:' S9 Z, K( R- s1 U6 r
C1. K7 ^4 ]: Z+ F- a2 s7 G! i( `
' h, N i K% r6 M+ i
Single/Zero Pin Net Warnin |
