查看: 1138|回复: 2
ALLEGRO 转PADS 时这样的警告影响转换吗
发表于 2012-11-2 11:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
9 t+ n3 \9 U. [* R" a" i2 l1 e! X& F& E
此图是集成DFL skill 后, 执行MIAN OUT 命令后 ,经过一系列转换提示的警告' z( @; i  m/ A+ k2 N
* d% I2 g8 }, A: y" E$ G
看到里面 0错误,但是有15个警告(下图中有), 这些对最后导入pads 9.3.1有影响吗?   我转换后的文件不能导入
% T: m1 G& r1 O* W9 [. e+ h. g
3 Y# ?! x4 |0 e! a( eallrgro版本16.3   PADS 版本 9.3.17 ~; K5 w7 W" c# I& u4 J; H7 e
下面贴上15个警告的Log文件
9 I: s4 T- V6 }6 ?WARNING:  No route border found, bounding box used!9 c* u) d! d' l* R, V
WARNING: layer SOLDERMASK_TOP not found in layer table.  Check the allegro cross-section!) p/ t9 u7 _' U7 G) `! R6 S, |
WARNING: layer SOLDERMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!5 w; B; r, Z" S& \, p- V3 v
WARNING: layer PASTEMASK_TOP not found in layer table.  Check the Allegro cross-section!1 j; l6 K) L# C- ]
WARNING: layer PASTEMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!
% ~$ w" d4 X8 U7 ?/ p+ u0 RWARNING: layer FILMMASKTOP not found in layer table.  Check the Allegro cross-section!
% @8 D3 c1 U. kWARNING: layer FILMMASKBOTTOM not found in layer table.  Check the Allegro cross-section!! S5 S6 o& `; L: Y" d
WARNING: layer ALL not found in layer table.  Check the Allegro cross-section!
8 A( B! K1 H# e. y! ?2 L# t7 TWARNING: layer internal_pad_def not found in layer table.  Check the Allegro cross-section!5 C7 \' g8 ~5 x8 R& E, [: Z( Z
WARNING: layer ~TSM not found in layer table.  Check the Allegro cross-section!
" a1 d! r1 ~3 V0 b- H  F6 y- U. GWARNING: layer ~BSM not found in layer table.  Check the Allegro cross-section!
  p- {5 N5 W: r+ ~WARNING: layer ~TPM not found in layer table.  Check the Allegro cross-section!
! O9 Y$ G% v  \/ pWARNING: layer ~BPM not found in layer table.  Check the Allegro cross-section!
9 v1 [* [  n$ `5 s* @4 X* {5 [7 \2 `WARNING: layer ~TFM not found in layer table.  Check the Allegro cross-section!
2 y6 ^; n# d# T' y  [5 YWARNING: layer ~BFM not found in layer table.  Check the Allegro cross-section!) A; A0 [# v& f: F' k! b- m& a4 j
2 r# H9 i: }/ u  i0 T2 m
这是BRD 文件,16.3版本
这是BRD 文件,16.3版本
    2019-11-19 16:23
    发表于 2012-11-3 08:39 | 只看该作者
    你是用16.3直接转pads9.3.1吧?我就转成功了一次就没在转成功过
    发表于 2013-9-5 20:20 | 只看该作者
    一直不成功,哎……
    GMT+8, 2025-8-13 20:13 , Processed in 0.125000 second(s), 26 queries , Gzip On.
