6 e0 E4 B; M6 y9 g: ?0 k6 [
4 o& C p; h, I/ [0 K9 T, W2 T5 s9 o/ D參數定義
) r1 [4 M+ C2 o. T+ Z/ M* o這些參數光看都覺得很恐怖!
; A3 c7 b) R) s6 b8 o4 L& q3 v
9 Y: R3 |' ^$ m(dI/dt)c$ E- b! V9 P4 V
This is the maximum rate of decrease of the anode current allowed to turn the Triac off. Above this value, the Triac can remains ON in next reverse polarity. For standard, logic level Triacs and ACSs, the (dI/dt)c is specified with a limited (dV/dt)c parameter. For Snubberless Triacs, this value is specified without it.! j. O5 f9 r/ w4 B
% A( L$ s; l$ n. K! G" T$ k
(dV/dt)c3 r7 D5 S; @9 F, n( r) j3 a4 F: x
Critical rate of rise of commutating off-state voltage This is the maximum rate of rise of the reapplied voltage during turn-off. Above this limit, the Triac may remain ON without any gate current.# I# N0 G \$ x: O8 k1 G+ ~
) E- \& o. P! \
" a$ {6 p! M, X
4 M$ v' w, Z* ]9 Y! l |
