楼主 |
发表于 2012-10-24 17:07
只看该作者
本帖最后由 sharp0 于 2012-10-24 17:14 编辑 $ Z! p9 U! K3 O6 J9 d; q
! v/ N% f' p# S+ w' u出现错误图片文字是这样的8 m+ a0 f. Q: H s' B h9 G
MGC SDD Configurator
1 c4 a0 q$ T4 o$ C9 t
. O9 p: q2 t+ ]6 l) q6 w7 B1 n! gNOTE: The attempted PATH size has exceeded the maximum G& T8 v' A% `9 X( S6 Q2 g# Y
allowed for Windows since XP sp2.
! I3 M/ v* L6 c. N) b: l5 B+ P! lThe system path is limited to the maximum path length of 2047/ \, t$ G0 x! l9 ~2 j
characters.The user-defined path is limited to a maximum 511
3 Y& W8 L5 ~+ \% @1 X+ z! h0 ^' Zcharacters, but is limited to 2047 minus the system path. The
+ X6 a( s, d0 v$ g3 t4 e) I& O6 Vattempted PATH Length is: 229 You must reduce the size of your
9 U; n- A1 s: G$ v- huser or system path and7 g" M1 v6 e3 s( K \
add this value to your path:
; J( u6 t+ W) ^2 z6 \0 o' Z: fC:\MentorGraphics\9.4PADS\SDD_HOME\common\win32\lib
4 Y" s# p0 V e. TThis value will be stored in SDD_ADD_TO_PATH for easy editing.# P0 r1 @* ^7 C3 T, C
