pads layout link 时出现以下txt文档?? 请问各位大概是什么意思? 怎么解决。。。
8 Y, D3 N9 S, ]* y2 e$ R; T! N//////////////////////////////////////////////////////////////////////////////////////////////////4 Y, P `8 W. _# y: e: {
) S5 q/ i. Z* J
PCB Net List Errors Report - A10-EBOX08-0615 .sch - Tue Aug 21 20:50:53 2012
( x2 H t; P H -----------------------------------------------------------------------------% f- Z7 E& m+ }7 x, a% w8 D- M
Design to Library Part Consistency Check
` X' j; k0 B2 M6 H, _ ----------------------------------------
. K2 w0 n3 u, T' s5 q Part Type CVBS has the following gate pins that do not match to the Library part:
, x E5 B* S, D' j) q& ] (6 1) (4 2) (2 3) (1 4) (3 5) (5 6).
- l8 g0 X S) a0 K8 C Non matching Part Type CVBS is used by the following parts:
7 W C2 _# o) ~& Z% b6 [ J6.
4 p4 f& t! B7 h1 p) e) ` Part Type NJM4580/SO_0 not found in Library - not able to check following parts:
5 R9 y5 _0 A/ e8 O* e: F; P U4.4 g5 P8 A! \7 O, N2 f+ |
Part Type C0603 has 1 gates in the design and 0 gates in the Library.. Z$ E5 C7 C: R& f
Non matching Part Type C0603 is used by the following parts:
5 x$ N% \- @* u. H# P& c2 A x( W C63 C64 C65 C66 C72 C71.
' C# W8 t* \! P }( g Part Type SH has 1 gates in the design and 0 gates in the Library.6 _( A m! @0 V, b8 w
Non matching Part Type SH is used by the following parts:
- x; W% u& y4 R' Y2 R SH1 SH2 SH3 SH4.
. ~+ y8 Y, x) s$ n0 S Part Type IR_MODULE has the following gate pins that do not match to the Library part:
0 R; J9 e0 N j2 ] (3 1) (1 2) (2 3).& r7 h/ o* f' C1 P
Non matching Part Type IR_MODULE is used by the following parts:8 y4 N& p) t1 F) _
U9.% d% Y3 I# W8 m' R% s2 R- S: s% o
Part Type R0402 not found in Library - not able to check following parts:
/ @0 b& y$ M* m- Y9 z/ N( ` R10." H4 K/ C/ A- t* J
Single/Zero Pin Net Warnings- ?( \0 q# o) h8 ]
----------------------------8 T* q) Y" g4 t
Net LRADC0 has less than two pins in PCB net list file.
- f+ O p" u% }( ` H Net SD3-D3 has less than two pins in PCB net list file.$ G) P% h: j8 @2 V" a, ^% _% Z
Net SD3-CMD has less than two pins in PCB net list file.
& z$ I6 x4 o1 `8 t& C; g5 K: J- \ Net SD3-CLK has less than two pins in PCB net list file.
/ ~2 H$ ^2 {0 M/ E) u# A Net SD3-D0 has less than two pins in PCB net list file.
" c- ~0 m) _6 K C Net SD3-D1 has less than two pins in PCB net list file.
- E0 }# }" b7 R. C, l Net SD3-D2 has less than two pins in PCB net list file.
' o" ]4 @* o# X* M Net $$$7141 has less than two pins in PCB net list file.! x2 x0 P/ z6 x9 n- V0 b$ c. |
Schematic Connectivity Errors
0 Q5 V, m+ J0 J; E9 w( k) c -----------------------------9 `+ |: w4 x& `9 ^
Floating Connections or Subnets2 V% }2 ?: r1 a# ^/ F2 r
ECOL
# o7 b3 \+ [9 y3 z" o; y) c1 a& F 14_EMAC X1700 Y7680
. b) l6 `6 [! z8 y+ i9 jECRS
1 Z- V9 D1 U, g& O 14_EMAC X1700 Y7880
' j9 Q+ H) _9 ?, s4 S2 gEMDC+ @6 U: c, |' V
14_EMAC X1700 Y8680
2 |- h' T' Y% N# bEMDIO
5 m7 p8 V$ T% ]6 L3 x6 q1 Q 14_EMAC X1700 Y8480 0 w% F! B" ]7 ?5 w/ H3 p/ N
ERXCK+ }- @ a4 O$ c5 ?. C2 r4 ~
14_EMAC X1700 Y9280
0 U$ c( b' N; b8 ?ERXD0
?( q8 H9 G* g4 [, p& t6 |/ E 14_EMAC X1700 Y102803 g# v( X, x# d+ j v
ERXD10 _9 |" b& w/ T3 h7 R9 H" ~
14_EMAC X1700 Y10480
+ |# L9 E; L+ e ERXD2
) m! \, C- ?& _/ Q2 [ 14_EMAC X1700 Y10680/ p) Y. }7 }: }3 ~8 ]) O) e3 E1 p
ERXD3* {4 p: c' n& C3 K7 Z
14_EMAC X1700 Y10880
( Z: y+ L- z' P3 _0 Z; u+ j7 v- L ERXDV
! x2 l" Q- Q/ s 14_EMAC X1700 Y
) ^( F9 p9 S6 V0 R( J } |
