查看: 2043|回复: 1
PCB框图有问题
发表于 2012-8-22 15:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
report提示如下
& r+ X& D# @2 u* ~2 `3 ADesign Name  D:/cameralink_FPGA/pcb/cameralink_fpga_route1.brd9 |7 m: Z/ {) l, Z4 y
Date  Wed Aug 22 15:38:45 2012
1 P% B( o( O, f: ?' l5 V% W8 F- M" K* k$ W9 e6 S  g5 e
DRC Error Count Summary DRC Error Type DRC Error Count
6 v  d& o% j/ B& o: K9 f) A- _Route Keepin 1
# Y& H/ p2 M3 a. TRoute Keepout 4
6 w& n; z* Y1 x6 J5 e7 CEtch to Pad 4 4 ^" ^/ N( d" u+ }0 }3 I3 w8 O
Total DRC Errors 9 ) n* C, n; S! F$ g
2 U4 O% V7 G& ~& o, u
1 R, ]& r) m2 |
Detailed DRC Errors Constraint Name DRC Marker Location Required Value Actual Value Constraint Source Constraint Source Type Element 1 Element 2
8 p" A; M; I' c" {8 s, ]( ]% l& fShape to Route Keepin Spacing (-137.796 178.740) 0 MIL 78.74 MIL DEFAULT NET SPACING CONSTRAINTS Shape "Gnd, Etch/Gnd" Rectangle "Route Keepin/All" 9 F4 z% n: o3 w2 M; L5 g% u+ F9 ^
Shape to Route Keepout Spacing (1900.000 4037.008) 0 MIL 0 MIL DEFAULT NET SPACING CONSTRAINTS Shape "Gnd, Etch/Gnd" Shape "Route Keepout/All"
) q3 ~9 u5 O! h5 L# l% HShape to Route Keepout Spacing (-2400.000 4037.008) 0 MIL 0 MIL DEFAULT NET SPACING CONSTRAINTS Shape "Gnd, Etch/Gnd" Shape "Route Keepout/All"
$ z8 d: Q, D; b# |8 e3 H1 RShape to Route Keepout Spacing (1900.000 100.000) 0 MIL 0 MIL DEFAULT NET SPACING CONSTRAINTS Shape "Gnd, Etch/Gnd" Shape "Route Keepout/All"   A  X; f; U) v+ G
Shape to Route Keepout Spacing (-2400.000 100.000) 0 MIL 0 MIL DEFAULT NET SPACING CONSTRAINTS Shape "Gnd, Etch/Gnd" Shape "Route Keepout/All" . v# e$ [) {! G2 S# @* A
Thru Pin to Shape Spacing (-2303.150 296.850) 5 MIL 0 MIL DEFAULT NET SPACING CONSTRAINTS Shape "Gnd, Etch/Gnd" Mechanical Pin "Outline." * j" E5 R- r' B% l$ Q
Thru Pin to Shape Spacing (2027.559 3840.157) 5 MIL 0 MIL DEFAULT NET SPACING CONSTRAINTS Shape "Gnd, Etch/Gnd" Mechanical Pin "Outline."
& G4 d8 L2 N  r. TThru Pin to Shape Spacing (-2303.150 3840.157) 5 MIL 0 MIL DEFAULT NET SPACING CONSTRAINTS Shape "Gnd, Etch/Gnd" Mechanical Pin "Outline."
% r- J& b9 x  q& b# D- {9 jThru Pin to Shape Spacing (2027.559 296.850) 5 MIL 0 MIL DEFAULT NET SPACING CONSTRAINTS Shape "Gnd, Etch/Gnd" Mechanical Pin "Outline." + A1 J$ x1 g: W; E! k
发表于 2012-11-2 09:00 | 只看该作者
这是drc报告和框图有什么关系
GMT+8, 2025-11-27 04:23 , Processed in 0.140625 second(s), 23 queries , Gzip On.
