查看: 11178|回复: 31
求助Allegro 16.3转PADS9.4.1
发表于 2012-7-2 19:49 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
谁会allegro 16.3转pads9.4.1 点击转换时出现下面的结果  不知道哪里设置不对  求解
    2021-3-9 15:11
    推荐
    发表于 2013-8-26 08:57 | 只看该作者
    装pads9.3.1之后的版本,软件自带了dfl skill,把它集成到allegro中,转换出mgc文件夹并用pads 9.3.1自带的allegro to pads translator 把brd转换成pads的pcb文件,教程在pads的安装目录里面
    推荐
    发表于 2013-8-26 00:15 | 只看该作者
    按照30#的操作,allegro转到pads里面,但pads里面的线怎么有些线是细的,有些是正常的,是怎么回事呢?
    发表于 2012-7-3 08:13 | 只看该作者
    From版主 [rx_78gp02a]
    : G( h* v6 ?( v% q  T3 Q安装pads9.3.1之后的版本,软件自带了dfl skill,把它集成到allegro中,转换出mgc文件夹并用pads 9.3.1自带的allegro to pads translator 把brd转换成pads的pcb文件,教程在pads的安装目录里面有.
    # q+ U7 @8 G9 O8 w-------------------------
    # g' I8 |8 U8 ~8 e# O" I楼上可以试试版主说的方法
     楼主| 发表于 2012-7-3 09:03 | 只看该作者
    Please wait...extracting and processing technology file
    * s" n4 z+ V9 |, O9 n. mStarting Export techfile...
    ' t1 F/ z- k2 U( Otechfile completed successfully, use Viewlog to review the log file.2 f6 ?0 L/ t& a+ Q2 K
    techfile completed successfully, use Viewlog to review the log file.2 P  F9 W& `3 o( ?- w
    Converting techfile...
      i' W3 @. l1 K3 M* F  |5 GExecuting command E:/S/AA_MGC/Work\techconv.bat& d( `* e4 V5 ?% |; ^1 r6 l
    Error: Techfile conversion failed!# C+ E! H6 b/ V
    extracting Layer Stackup# N' r' g7 ?  E
    extracting Design Rules. \3 w5 R$ h$ e  ~* i
    Deleting Existing Classes File
    ) ]6 t% b# L/ ^7 P! JDeleting Existing Props File1 F, b" Z# R: E' @+ Z( V
    Deleting Existing Board Items File
    8 O0 Y, y2 P# t4 u: dExporting Electrical Constraints.... u  ~- v& O4 R. c) b7 h
    Loaded existing device file 'E:\S\AA_MGC\Work\devices.dml'; |9 s* M$ e6 ~' o' N/ S' u" s$ r7 t
    Finished loading SigNoise device libraries3 ^2 l" h3 B2 ^' {9 _/ ~
    deleting old device files' b+ K, c& l" N1 I, }
    extracting device files
      R/ W) n* ]( \, kextracting Net Properties/ k% ?  V# j* n$ v/ m( D  [+ q
    extracting Board Areas
    8 w) |! d+ i! {' Rextracting padstacks! N3 r6 D) S8 n6 ^9 m
    extracting padstack completed
    , g3 d5 e5 V; d6 w$ o0 Iextracting Placement8 n# Z, F+ A) x- h! ^
    E- *Error* greaterp: can't handle (nil > 0)  这是我按照教程步骤输出的Allegro Command结果  PADS 9.4.1导入时会出错 File Import failed。PADS file not created
     楼主| 发表于 2012-7-3 09:27 | 只看该作者
    Error: Techfile conversion failed!# ^/ v3 s- b. Q  X8 ^, ~
    E- *Error* greaterp: can't handle (nil > 0)    问题估计是在这两条   但是不知道怎么改
     楼主| 发表于 2012-7-4 10:08 | 只看该作者
    高手呢?  帖子就要沉下去了
     楼主| 发表于 2012-7-6 09:55 | 只看该作者
    问题还未解决   Jimmy版主能帮忙解决吗   会的高手留下联系方式  我提供文件
    发表于 2012-7-6 11:43 | 只看该作者
    顶起,我也是同样的问题
    2024-8-27 15:49
  • 签到天数: 14 天
    [LV.3]偶尔看看II
    发表于 2012-7-12 10:52 | 只看该作者
    顶起,我也是同样的问题
    发表于 2012-7-12 19:25 | 只看该作者
    一直在为PADS和PROTEL之间的转换问题发愁 不能完全的转换 总会有那么点问题
     楼主| 发表于 2012-7-13 18:32 | 只看该作者
    最终没搞定   只好用AD作为中间过渡转了下
    发表于 2012-12-27 14:38 | 只看该作者
    cz0924 发表于 2012-7-13 18:32
    ' K( _  ^! g. j最终没搞定   只好用AD作为中间过渡转了下
      s; C6 z+ R8 Z1 `8 v
    用AD过渡的时候,转换出来的文件用pads直接import有没有出现什么问题?
    发表于 2012-12-28 00:18 | 只看该作者
    有的板子确实转不了,可能是有些不支持的字符在里面或者是过长的属性值。
    13#
    发表于 2012-12-28 10:34 | 只看该作者
    請問一下如果是出現下面訊息的錯誤
    . Z; r4 y( S% b8 T3 `: }要怎麼解呢??6 D2 R+ m" [( ]7 w* l- D- k- w. Q
    ' }0 g1 N- s6 B- i* i# y
    ERROR: Techfile conversion failed!
    & Z. Y' L* _  N9 x9 [WARNING: layer BOTTOM not found in layer table.  Check the Allegro cross-section!
    - X0 ^! {" b; B1 TWARNING: layer POWER not found in layer table.  Check the Allegro cross-section!; O- ]% @4 |$ e2 ^
    WARNING: layer GND not found in layer table.  Check the Allegro cross-section!
    ; a/ t3 n  J5 J2 j9 w* g* D+ mWARNING:  Board outline is non-closed or self-intersecting; using its bounding box as a board outline5 e2 Q& R" C3 e6 D) C) W
    WARNING:  No route border found, bounding box used!$ Y6 S2 U8 e6 U) M2 M7 [. Q
    ERROR: no data issued for clearance DEFAULT% Z$ O' k& N% ?8 v9 L# }
    WARNING: layer TOP not found in layer table.  Check the Allegro cross-section!1 Z' a: N2 U5 R* ^* |. I1 i
    WARNING: layer SOLDERMASK_TOP not found in layer table.  Check the Allegro cross-section!4 U: Z$ q9 M2 l8 \4 G
    WARNING: layer SOLDERMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!
    ; v$ W$ h# h1 m) w5 x1 bWARNING: layer PASTEMASK_TOP not found in layer table.  Check the Allegro cross-section!
    $ R% o  W3 `& eWARNING: layer PASTEMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!
    $ [! c: G! {' }* [. w. w! vWARNING: layer FILMMASKTOP not found in layer table.  Check the Allegro cross-section!% m" l4 x4 d8 e2 [9 p1 Z0 ^
    WARNING: layer FILMMASKBOTTOM not found in layer table.  Check the Allegro cross-section!
    : h% U) E, I' N( EERROR: Unable to issue shapes for padstack SMD25X25_R - layer problems' Z. d7 E! e) X" b0 g- S7 w
    ERROR: Unable to issue shapes for padstack SMD25X25_L - layer problems
    + q0 ^0 x. y5 ]9 XERROR: Unable to issue shapes for padstack 052X072V - layer problems
    : y! b2 s) w& m, \- V- X( gERROR: Unable to issue shapes for padstack SMD35X32 - layer problems
    14#
    发表于 2012-12-28 11:49 | 只看该作者
    顶起!!!
    15#
    发表于 2012-12-28 12:46 | 只看该作者
    allegro要求严格,任何非法字符都报错
    GMT+8, 2025-8-18 20:45 , Processed in 0.140625 second(s), 28 queries , Gzip On.
