查看: 4387|回复: 5
线路同步后,主控的PIN脚乱了?
发表于 2012-6-27 17:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
原理图是orcad转过来的
 楼主| 发表于 2012-6-27 18:37 | 只看该作者
同步时出现** ECO In Report **
. e2 `+ [" E: L  j
6 @* W. n5 W' S' i- rWed Jun 27 18:36:27 2012% E" Z$ [3 _: F- M# g. r
/ D6 C% F, \+ n1 e$ \- Z/ [  I; LInput  File : C:\PADS Projects\eco2pcb.eco! E9 v( d* j. A! g$ t; h
Current Job : DR12-[X3]-20120525-1140.pcb$ s4 L. {* F8 C6 @
! ]2 d, h6 i& a
4 s& g% k  ^4 {1 L, i: s& j& B) e6 W8 _7 z) ?8 r" r1 ~. Z4 `# h
Line 1671 , Section *CHGPART*
2 O& v+ h) z/ Q$ x0 |Q6  TS\BJT-SOT-23  NPN4 N5 E5 y: Z$ j3 o% S
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "SOT-23". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
3 I) Z) V8 x; G' f+ y7 N; B) a3 {* D
Line 1673 , Section *CHGPART*! O1 q1 c! S6 }+ }, _
C1  TS\C0402  CAP_NP
' t9 w9 U% u, L# o* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402C". Open Layer Setup dialog box and change the layer mode of the design to increased layers.+ B, k8 I3 y+ p/ }' I( c3 R, S
' d- h+ d; e5 L! ?1 S/ a9 y
Line 1686 , Section *CHGPART*0 p) P! z7 i' C1 V; Q! A9 p
C114  TS\C0402  CAP_C0402_0.1UF/16V/X5R/MRT_RS_2
( w, s6 U( c) T! E3 z* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "C0603". Open Layer Setup dialog box and change the layer mode of the design to increased layers.  S6 n4 |( A. f
) C7 [5 x0 a" _& A  m1 |. a
Line 1687 , Section *CHGPART*" g0 N- u9 }& `9 G! r
C115  TS\C0402  CAP_C0603_TY_RS, h: x- a: l6 _. X
5 g/ R% O( ~% k) F9 o+ r, l6 |, W1 M* W% I  H( k7 Y4 Z
Line 1688 , Section *CHGPART*& w8 k' C6 _/ h; P! e. v; @0 M
C117  TS\C0402  CAP_NP
; ~3 s7 Q8 |% U9 L9 |9 p6 i* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402C". Open Layer Setup dialog box and change the layer mode of the design to increased layers.2 X4 p. Q# R! X1 J- }' ]  E
  z& Y& d: a6 i; U* j) k  ]Line 1689 , Section *CHGPART*
$ N! `8 E* i9 v2 I* x! W; yC118  TS\C0402  CAP_NP2 g, Q5 e8 S7 i4 _$ M
1 N1 y2 l. U! ]# Q# }: @6 w
) k" b  e( ?8 \+ w/ ILine 1710 , Section *CHGPART*8 u: f6 q: B  n6 c: ]
C3  TS\C0402  CAP_NP! D$ i7 y) c( Z, T2 o5 ?" }# b
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402C". Open Layer Setup dialog box and change the layer mode of the design to increased layers.3 `% K% N6 |* H0 j0 U
( S5 Q2 p! c9 N" ], NLine 1714 , Section *CHGPART*
7 V( q+ O) B* M9 {% @  gC4  TS\C0402  CAP_NP
+ S# c) A) T! D( @6 L* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402C". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
. l7 y- \) J+ n! M
. ~9 {* H$ t- y. L5 t, D- X, u9 ~Line 1723 , Section *CHGPART*6 i2 @( e0 ?) J( j  r5 p
C5  TS\C0402  CAP_NP
% G& r4 i" ]5 J* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402C". Open Layer Setup dialog box and change the layer mode of the design to increased layers.( m, |% t6 V2 R9 d
2 K; i- d  h  P7 _' V4 oLine 1736 , Section *CHGPART*
7 }  V2 P* B  h8 wC7  TS\C0402  CAP_NP_7
. v9 `- r0 o3 u- l) U* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "C0402". Open Layer Setup dialog box and change the layer mode of the design to increased layers.! c; @. `; h4 n8 q. e- \0 ^) S
9 B+ S& W7 V$ i7 e
Line 1746 , Section *CHGPART*
; Q3 C9 t: M$ q1 P0 [; s. b$ ?0 @C8  TS\C0402  CAP_NP_7
& J2 \0 U8 N/ J/ p& R* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "C0402". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
, [7 L3 y" z! U% @. D' [. Y7 i2 C9 W  l; Z3 k5 f
Line 1748 , Section *CHGPART*
' b0 d+ ~; T" U) @0 oC83  TS\C0402  CAP_NP
* L; C! S! H: k: _; ~' k6 _5 S* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402C". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
# C6 p6 w, C9 O4 E  s& f
% t% }# ~' s. jLine 1749 , Section *CHGPART*& q5 F; K1 m5 \# M& D9 y
C84  TS\C0402  CAP-POL_2- w6 C( t% X% q# I6 e+ R
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TS\EC-DIP20". Open Layer Setup dialog box and change the layer mode of the design to increased layers.7 a) R' U- E. F! R" @
7 M' k/ J$ r7 |( m; s2 a# i2 w
Line 1762 , Section *CHGPART*4 h$ u" {, r/ r5 J8 z: s0 F
C119  TS\C0603  CAP_TB_47UF/10V_NEC_RS
' E# {8 [2 l4 m& p" g( i$ m* Failed to get A-SIZE from library
4 M6 e0 o3 A1 I$ F' g9 a/ H" ?5 V4 d1 e$ g" x  L4 k3 ~0 u
Line 1766 , Section *CHGPART*
- i( r+ r" |1 F2 i* W8 tC14  TS\C0603  CAP_TB_47UF/10V_NEC_RS; G( i: I3 u/ P" z$ b) V8 o' R& \5 a
* Failed to get A-SIZE from library3 g: y, o3 i  e. l* ^& Z
3 c( ~. V: i* Z/ {: @Line 1777 , Section *CHGPART*
" M& `$ [+ R% Q! l: \, B8 h5 q3 oC142  TS\C0805  CAP_NP
. |9 R* @' M& f+ _8 g( K5 o* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402C". Open Layer Setup dialog box and change the layer mode of the design to increased layers.& F  v. h: C* H5 V5 P
9 d5 p. t; q+ l8 D9 i4 i
Line 1789 , Section *CHGPART*5 B! S4 R# L+ u1 W; L1 m' F. O; S
L2  TS\CM0805  CHOKE$ C+ @1 W: z& J5 g2 t. e8 G  d# F
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "L-SMD-4.4B". Open Layer Setup dialog box and change the layer mode of the design to increased layers.. a/ }  ]/ @, M% B0 E
+ g$ {9 z$ @# D* b# x1 ?4 M4 b; K; L
Line 1790 , Section *CHGPART*
  ^6 S) R+ ^$ ?* zL3  TS\CM0805  CHOKE9 D7 y# \5 f- J" q$ m9 T
0 l' a$ e8 l5 h- }* `% T; e
$ M, R( y5 K/ _5 s" |2 @5 G1 X$ W9 H8 \Line 1795 , Section *CHGPART*
% M; m0 x# }2 W- O3 G' _* aU8  TS\CSP3-68  LDO-3( [4 f2 q7 Y% e5 s) R3 o
* Failed to get TS\SOT-23 from library
! k; T7 A( ?) @2 s. N1 F- h
& o: w8 C; D, QLine 1797 , Section *CHGPART*8 h5 v# D1 o/ a5 P0 w: [8 l9 c
U3  TS\FBGA96  IC_STEPDOWN_S-8551_RS( T  T( ~6 U/ B8 V' ?1 _, V
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "SOT25". Open Layer Setup dialog box and change the layer mode of the design to increased layers.: a; y. b# n  ]4 Q0 a5 K, J/ ^
, P4 Z0 K0 R- Y3 f. q) q
Line 1805 , Section *CHGPART*
7 c# s8 s* v: \7 k( A2 O, ESW1  TS\MD-5  MD001-050037 M5 p3 s* E5 ?9 P  H; ]
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TS\MD-5". Open Layer Setup dialog box and change the layer mode of the design to increased layers.4 e" N  T8 ]- d& ^* O5 _9 i
: ?  o4 [( b  i; F9 p5 J: J& L
Line 1806 , Section *CHGPART*2 j% w, F3 G+ X) _& ^5 W' v
SW2  TS\MD-5  MD001-05003! f2 q3 Z/ y# p# T* c
& s' ]! @$ X* G: s/ J
1 L$ _  k0 d5 C* M* vLine 1807 , Section *CHGPART*" l. I8 Z  U0 W  E# y0 m
SW3  TS\MD-5  MD001-05003; J0 f7 s; T' g- H7 n
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TS\MD-5". Open Layer Setup dialog box and change the layer mode of the design to increased layers.8 `; R( v6 X! {. {& G8 a  ?
' h/ }0 I, f8 M0 _5 [
Line 1808 , Section *CHGPART*( ^" J4 B" h8 x; J
SW4  TS\MD-5  MD001-050033 O, R/ x1 t8 {, k$ Y) |  t4 _1 l
9 v! s' H9 Q. w& J8 K" E& w: O" O! w4 s
Line 1809 , Section *CHGPART*
1 H/ Y0 K/ H$ F+ m. {1 QSW5  TS\MD-5  MD001-05003
/ c$ O1 G! d. W: k# {* g* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TS\MD-5". Open Layer Setup dialog box and change the layer mode of the design to increased layers.: }4 t6 j% `: Q  H/ W' c5 F. B! i
2 B# ?6 f3 ?, k# q' h7 Z$ ?$ ILine 1810 , Section *CHGPART*5 Q8 G( ?+ Z# p* Y
Q1  TS\MOS-SOT-23  MF_P_IT2301B/ H+ K7 [: v: I* U3 I0 q/ K
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "SOT-23". Open Layer Setup dialog box and change the layer mode of the design to increased layers.- ?& r) m, w: P2 P" a6 S7 _
9 ^; U/ M, {" `Line 1813 , Section *CHGPART*
7 G  ^. p! x7 iR10  TS\R0402  RES
0 S( l0 d+ ^& b* p2 N, ^* K* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402R". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
1 M* t4 J. D' ^$ i0 ?9 M( a  i8 I; Q1 T8 {& ]1 b
Line 1830 , Section *CHGPART*, d9 ?( f# R' V4 k6 y0 j
R13  TS\R0402  RES_0402_RS_2$ r1 d! j( Y* U# m! N9 {/ q- j$ {7 @, \
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "R0603". Open Layer Setup dialog box and change the layer mode of the design to increased layers.6 ]2 ~) v8 ~/ G$ [: @0 r/ }1 S
" q- f9 h' ?6 O. |Line 1846 , Section *CHGPART*/ i5 r' X+ a1 t7 e1 C+ ^
R15  TS\R0402  RES_0603_RS_2
. h3 ]; I  F$ y( h: }! w0 X/ t* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "R0402". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
# @! T# Y6 H1 Q0 R6 O/ E
' J  `2 e) Q! A+ L& U5 o7 f2 _Line 1885 , Section *CHGPART*) k. z' M- e0 j( Z* |( V2 Z4 L' ~
R2  TS\R0402  RES
$ m4 [& i5 T% I/ L* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402R". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
% P; J- S3 ^- p) M+ ^" a4 R$ Q+ Q( R9 j- R: A7 K; `/ O, x
Line 1893 , Section *CHGPART*
# f; ]; l" R" ?R3  TS\R0402  RES9 R  R6 u$ z/ f4 B$ A& R) {$ ?; l5 H
9 ~" F* a* K3 y+ O4 G& C4 `8 w4 A' x" z  S5 u& O  p3 K! x' r& f
Line 1895 , Section *CHGPART*% [0 G8 ^' y9 j/ ^
R4  TS\R0402  RES
1 l6 n' D" q( Z1 n% U" ~* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402R". Open Layer Setup dialog box and change the layer mode of the design to increased layers., e! v$ K% K8 T( z! A9 X4 J( J
% N6 |0 S: ^# G# h4 @
Line 1897 , Section *CHGPART*: [$ q( A$ M9 H* F& ?9 A3 j0 E) G+ Q
R5  TS\R0402  RES5 y* ]1 E/ {; _7 q$ z) J1 r
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402R". Open Layer Setup dialog box and change the layer mode of the design to increased layers.- t6 N, A! s0 G% n/ w
( O2 K( \/ W, c- _) V
Line 1902 , Section *CHGPART*" ?" A1 a% O0 v9 ^
R6  TS\R0402  RES9 |% w; q8 ]. L+ f& E
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402R". Open Layer Setup dialog box and change the layer mode of the design to increased layers.7 k' I  j! H6 u1 i+ M2 L% k
6 Z" t9 X# l& }9 b* q! D' j7 f% K4 YLine 1910 , Section *CHGPART*! @9 ?0 x) Q; x5 M. K" m
R7  TS\R0402  RES
( d2 @0 \1 q( R* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402R". Open Layer Setup dialog box and change the layer mode of the design to increased layers.2 ]- L& r. U& {9 F/ q) ]& c
: S) t. r: E1 U& ^& A6 C% XLine 1920 , Section *CHGPART*
$ a7 K  Z! i+ r6 T: C  i, h9 m9 RR8  TS\R0402  RES
  G4 v) T  v( W' B5 ~( P* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402R". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
: D0 l( X" P! p5 B: V5 G: D0 a' X# U
' R3 o0 {  P8 n1 e# T* aLine 1928 , Section *CHGPART*5 \7 t9 a$ d! f) _: \
R9  TS\R0402  RES
2 J' w- q# q  N, V$ @$ P* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402R". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
, ~/ ^. N5 \2 }0 V2 H# Q$ V3 m+ q* H* I
Line 1953 , Section *CHGPART*8 e$ a1 |' U; p  \1 D) a7 Y. F
RT1  TS\R0603  PTC
$ B, p7 D$ c: f& f. I* Failed to get  from library
2 M2 ^6 o& E9 ?) B+ w
* }& O! d4 s4 G3 G& O( iLine 1963 , Section *CHGPART*) I# V# S+ W8 S/ c' A/ ^& L
U4  TS\SOP-8L  RT9166
. w2 T- A( I# C* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "SOT-23". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
; _+ E" z1 O  E# ]* F7 R6 d/ ~1 C9 ~/ H3 J0 k
Line 1968 , Section *CHGPART*
& t% R8 E+ j8 L/ f9 wU1  TS\SPCA6330A  IC_LDO_S-1135D33MC_SOT256 P+ t% G9 M- w4 R7 i
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "SOT25". Open Layer Setup dialog box and change the layer mode of the design to increased layers.6 O. X7 l  e$ A4 k7 U& \! T. a
# \  [& o# P: R  @4 ZLine 2006 , Section *CHGPART*
' ?7 x0 B7 I' x  W5 {D5  TS\TVS0603  BAT54C
* T7 m, _2 W5 Q4 D( ]7 r* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "SOT23". Open Layer Setup dialog box and change the layer mode of the design to increased layers.7 Q* M$ C1 @; k2 a! t1 N, u3 b
* L1 m3 p: G1 ^. t) K! T
Line 2010 , Section *CHGPART*
2 P5 {# D, |0 [J6  TS\WAF-2-1.25P-DIP  SD_0& T  ]6 p6 A  y
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TF1.1-1.6". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
) q9 n4 W' U) z% W2 R6 B+ L7 k& B& }. J
Line 2037 , Section *PART*  C8 J# N! p( {1 i
C12  CAP_C1206_10UF/16V/X5R/TY_RS
/ R; z2 \: |( `" R* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "C0805". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
6 L+ D' X" L0 e5 x- N9 J3 [3 d9 c9 A7 P$ q, r2 s3 @
Line 2038 , Section *PART*2 p) x5 E/ u. n8 F# N* ~% Z
C16  CAP_NP, M7 `4 ~( {7 P: t8 J- g! ^6 h" ~
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402C". Open Layer Setup dialog box and change the layer mode of the design to increased layers.& R! ]5 e% u: w$ E8 c( p2 g( L8 r
+ d$ J) Q6 a% b8 o* DLine 2039 , Section *PART*8 C% g) b+ d$ L: K, p' A% e
C6  CAP_NP
! B3 t1 j$ A1 y- H7 k: C* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402C". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
7 Z  B4 X0 d/ c) d3 u' z+ [1 \6 b  [7 f4 O( s9 b- r9 J
Line 2040 , Section *PART*
" \3 e1 K( l* v- w. R, [C15  CAP_NP1
" @) P. Z1 a, G% |3 Y) a0 Y* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0805C". Open Layer Setup dialog box and change the layer mode of the design to increased layers.7 [' z* p2 ~0 B
0 ]! t$ d9 R! z0 M: P' B$ X
Line 2041 , Section *PART** ?) w4 }8 z" j+ Z% k6 V; O
J9  CON2
8 M& e# d5 ?2 ^2 \5 r0 ]! ]* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "2PIN". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
( q8 [9 J$ E' [1 K/ {' H; m! M  g# R9 o! U! W: t" r
Line 2043 , Section *PART*3 `8 l( \' `) u. e/ O* z
U17  IC_CHARGE_IT4054-4.2_RS% z& _, L8 C( v/ v
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "SOT25". Open Layer Setup dialog box and change the layer mode of the design to increased layers.( A: l) R6 h' R% S
6 P( V/ r3 ]" S' K' \
Line 2044 , Section *PART*1 @0 D: _, ]/ z
U2  IC_STEPDOWN_S-8551_RS4 ?/ r  E3 ~0 e0 Y+ j
  b- t  M7 o5 v$ |7 P
5 v; {  }. H6 }% aLine 2047 , Section *PART*
0 ^7 G- I4 [7 U( gLED1  LED_KPT1608SURCK-5MA_RED_RS% d3 j  x( y+ y2 D; ?" `4 l8 ?. w
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "LED". Open Layer Setup dialog box and change the layer mode of the design to increased layers.- ?( o; z/ U5 k+ f- b
% I: g& P* ^7 I4 f. P6 n1 C4 ]$ K0 XLine 2048 , Section *PART*
6 n; D" c: O+ R- F3 p$ W( z! SQ15  NPN( U, u: f7 R5 f3 ~( A) A1 M  ~
/ X0 J% V1 O8 W! Q' G) c, }+ x4 b) g+ m! S' ?
Line 2049 , Section *PART*
9 k8 C! P5 s- S# R& ~. {R281  R
, |4 i# M7 T9 R& z! c1 `- Q% G2 G  S- m* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "R0402". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
+ M+ B, h) j+ y; h" e& |4 F5 ]) `# S5 s9 k) H% m( B0 ~5 ^4 S
Line 2050 , Section *PART*
, G3 L0 ?% x, ], L/ rR1  RES0 Q* ~1 P0 W7 k6 R% Y
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0402R". Open Layer Setup dialog box and change the layer mode of the design to increased layers., R, r+ ]- I- ^1 J( Q; }
  K7 c( m2 c7 \1 m' B  w6 M# t
Line 2113 , Section *PART*$ z' s! [+ S% k( f$ {6 w2 n
R12  RES_0402_RS_2- T" b6 O$ b7 R! k) K
0 |% H8 }) `  o9 E. k$ {# l+ r! B/ _
Line 2114 , Section *PART*4 [: M: D" G  N2 O8 Y9 i. E* W
R14  RES_0603_RS_2: \. p5 b3 {* H# C' B1 ]
& b2 p/ h3 C+ n2 X- ]: E& n% c$ U5 H* ~/ f2 D! H* @& |
Line 2115 , Section *PART*) G8 Z5 Z4 {& ]9 J4 p
R280  R_2
& c* N* R! A4 E4 V$ B) o! \* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "R0402". Open Layer Setup dialog box and change the layer mode of the design to increased layers.6 j3 c5 Q  W1 R' z# r
2 A. ~: M3 f' ]Line 2118 , Section *PART*
9 N& ^* S( ]% w8 ]* x& y: t) m+ gSW7  SW-PUSHBUTTON-3" |* P2 z( W1 d# I8 a% q: j
* Failed to get TS\PTCFG-T-RB from library9 z8 L' D5 }) `8 N  ?/ i
/ L5 E; C' h. f% Q8 z
Line 2119 , Section *PART*
" k3 f$ D1 F5 mSW6  SW_PUSHBUTTON_3
5 w& V5 Z( s: U* Failed to get  from library3 {& a0 A8 R& G' B( x2 ]5 I, u
3 |) p+ Y. c* ~7 f  M$ Q" n. `) ALine 2174 , Section *NET*
! I8 ]- c7 S7 D3 U, }R4.1  C3.1  R3.2  U2.5
% G6 ]3 \8 i8 z/ _7 a8 b$ q* Part name U2 not found
: B7 K# c6 [1 h" F" K8 \$ [7 @6 C. j, T, x, g1 W9 f* l* e
Line 2176 , Section *NET*
  [$ j4 {8 \, Q2 l$ \+ j% ?. bR7.1  C6.1  R6.2  U3.5! c; x0 g3 R  R' ]0 Y- ^* ]
* Part name C6 not found
; R' N# Q, o  V5 W0 W* Not valid pin name 5 for part U3
+ v, ^5 m& b$ G# O: p5 ]
% I/ M2 w$ x; m3 E0 V  XLine 2178 , Section *NET*" M& C$ X8 I$ G7 i
C1.2  U1.4# `6 [" ]: k/ W, U" d$ T. [! ~
* Not valid pin name 4 for part U1 . \0 r+ C2 b; N( @
$ G: n- G: L9 R" K1 ULine 2180 , Section *NET*
. @8 s/ W& I; aR14.1  LED1.1
7 I1 k$ u( c, x4 U' ^4 @! `* Part name R14 not found
; G3 p3 m# P  a% r, D$ m- M0 x7 g* Part name LED1 not found9 ?6 g' Y0 ?5 r. E
) L* N! \6 o6 j  \8 A# U
Line 2182 , Section *NET*. A6 d2 g; g" b9 j0 X" P4 }+ n! _
U17.1  LED1.2
9 u3 @% s: g* t; }" _; A* Part name U17 not found* L  Q+ }% Y8 Y9 @% C5 v
, X9 Q6 y6 h" y% d
. c' m- a1 c& a- P9 E- d% lLine 2184 , Section *NET*
% E5 t# M% z- d8 k" ^& g3 nR12.2  D5.3
: b2 v, A9 V! F+ B5 r. e% i1 `* Part name R12 not found
. g8 v  D- {8 H; c* Not valid pin name 3 for part D5 ' w3 ?6 I+ @, ~7 t) J2 s- Z9 _& m
$ A# h& W( h, \  ~! n% iLine 2186 , Section *NET*
, x6 G6 {1 Q9 G# VU3.1  C117.2  R10.2
& Z0 F+ y1 y) u5 g) T# ^. f7 D* Not valid pin name 1 for part U3 . L9 ~: ~% k$ z, M. M
! z* h. D2 }; I) `
Line 2188 , Section *NET*
1 N. t: f: M7 sU2.1  C118.2  R2.2
/ o; q  ]+ w& D( d* Part name U2 not found
( e6 z* b8 }) R" V0 N2 y8 m; v  [# ~* y' T3 K1 e0 U
Line 2190 , Section *NET*, }$ b  [9 L: P1 n2 ^5 \4 V. @
C142.2  R1.2  U1.34 R6 \4 a' b. X: g7 f
* Part name R1 not found
6 z" j3 W0 E# u. }* Not valid pin name 3 for part U1
# g* n7 A; l* `4 ^4 Y6 m6 C  `0 {
( Y9 t  f$ c7 E  U6 s" ~% vLine 2192 , Section *NET*. \& t: F+ s+ T2 A, d7 t
R12.1  Q1.1  R13.2) d1 Y7 P$ ]" `/ u
* Part name R12 not found; j9 J) }" d5 ^; y. T+ w) t
* Not valid pin name 1 for part Q1 ' z) X- W5 O( a0 u1 j6 X
发表于 2012-6-27 23:31 | 只看该作者
首先,orcad可以直接导出PADS格式的网表,然后新建工程,导入网表并另存为新名称,然后再进行ECO对比!
 楼主| 发表于 2012-6-28 08:34 | 只看该作者
dqd7411 发表于 2012-6-27 23:31
0 f0 x6 L' p" {$ L6 f+ _/ ]1 V首先,orcad可以直接导出PADS格式的网表,然后新建工程,导入网表并另存为新名称,然后再进行ECO对比!
5 i; d8 y* _: R4 p, r5 b
具体怎么操作呢?5 g% T9 H- @" q2 ^" s4 T
发表于 2012-6-28 10:30 | 只看该作者
首先切换到工程管理窗口,单击“tools”菜单,选择“Create Netlist...”选项,在弹出的对话框下,执行如下操作:3 `! o' _% L  }2 n" P8 e
剩下的PADS的ECO对比升级,在此不赘述。你可查看相关PADS帮助文档。
PADS网表导出
PADS网表导出
发表于 2012-6-29 10:13 | 只看该作者
有没有更详细的说明?这个看了还是不太明白。
GMT+8, 2025-11-28 16:07 , Processed in 0.171875 second(s), 26 queries , Gzip On.
