查看: 3591|回复: 1
关于新版PADS系统自带库的问题.
发表于 2012-5-26 09:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天安装了pads9.4.1发现系统自带了不少7251 7351元器件库,但是发现" M0 K/ t" P1 T/ ]
CNA7251,CNB7251,CNC7251,CNP7251,,,
: w0 u4 v* F/ L- o( C& C! ~4 O0 Y  THA7351,THB7351,THC7351,THP7351,,,
) d: L# p# N3 `+ `; @2 N不知道这些A,B,C,P代表什么意思,; ?  @0 S# t: v* [% r3 ?  ^
知道的大侠指点下吧!
 楼主| 发表于 2012-5-26 09:48 | 只看该作者
百度了一下找到了答案,谢谢"白山黑水",以下是从"白山黑水"新浪博客复制过来的,给有同样需要的人.
0 I/ \) V: |+ u  w' Q: D6 PI'm looking for description about these libraries which category of component each library: @. J, }( P; o9 ^7 `
covers or any other specifics, and what begining letter stands for.+ }8 U3 n/ f* `3 t. T
( t+ F3 L4 M( h" g( f
In LP Viewer found PLB library files:
; N2 o7 s0 {( ?. h
$ G+ Y# h; z' @5 \PCBM-STARTER.PLB09
% [; O# H6 I  G  {# f! qBGA7351B.PLB09. h2 D9 j: L( f( |0 s0 p
SMN7351B.PLB09
" K/ ^- a, S8 LSMM7351B.PLB09
9 p( L; V! W: B* {SML7351B.PLB09# j) F- R) `8 @0 z
CNA7251.PLB09
/ J- ^" l6 K4 Z4 V' Z% tCNB7251.PLB09
- w  G" A/ h4 H  q6 [) n) t9 E9 ACNC7251.PLB09* n2 j: z) b/ u, w5 X3 K
CNP7251.PLB09
+ E7 Q" m4 r' m5 f+ N% E0 ETHA7251.PLB09' N. j) z) |( ?" ?
THB7251.PLB09) o% T% P0 w0 u$ d
THC7251.PLB09) {, e/ w8 W" _9 I% e9 i' E, y
THP7251.PLB09
7 Z* n; J9 K: r* l9 s+ j( ~. [3 { : L. `( k0 V/ M
5 f, i. v& q# e' }" d) SAnswer
1 ^6 J+ Z4 a' s$ B3 i& x2 o; j, ~' V" {# n$ Z. K/ o. D0 h, X* M
PCBM-STARTER = BGA & SMN combined with Mfr data added.
% ^. L' Y. F* u7 p7 i, _
) z, Q2 Q: l$ D. c7 z, tCN = Connectors- c6 j1 Y+ j" D9 W% C$ H( \8 N
4 r4 L' p9 F7 x( P: v$ y2 D' Q2 Q
TH = Through-hole
- d3 C+ l( R0 R* u5 b2 i % ^( E5 t. x' ^9 |/ |) ?& G
SM = Surface Mount7 R1 N8 X) ]3 c1 U3 a
, [( ^+ P  o& HA = Most Annular Ring for Through-hole
% d4 w' F5 N5 F/ SB = Nominal Annular Ring for Through-hole
8 l" z; o% D  K- {6 VC = Least Annular Ring for Through-hole: S" [6 q9 B* Q) w# v5 Z
P = Proportional (The Annular Ring grows larger as the hole gets bigger for Through-hole)
3 s$ ?# c+ Z! v5 I
0 A1 G0 W. [6 w  `5 mSML = Least SMT Pad
2 y" ]! f; L6 r9 Z* ~SMN = Nominal SMT Pad3 H5 ]  W0 e  F" R8 L# L
SMM = Most SMT Pad6 H3 e& W" n  O
! D. E: L. `, OBGA only comes in "Nominal" format: \) v6 J0 U& o
( Q7 p- O; T) b- [$ H+ r
这里的Most ,Nominal , Least说的是封装在制作时的一个思维标准。Most 用于密度小的板子(pad 尺寸最大),Nominal用于密度适中的(pad尺寸中等),Least适用于密度大板子(pad尺寸最小)。
参与人数 1贡献 +5 收起 理由
CS.Su + 5 赞一个!
GMT+8, 2025-11-28 15:26 , Processed in 0.187500 second(s), 28 queries , Gzip On.
