2 d) y/ U/ q& ?6 ?+ W非常感谢你的回答哈。 I6 n' K' ^; L1 H; L$ h5 `; g 5 | b; G3 Z+ T8 x+ _/ Q# f/ W可是为什么自动布线和smart edtior都不行呢? 2 u% {; \; W9 u. C! o% D/ \; {3 m 2 @* q6 R+ u4 a* ` f按照你说的,我在 router editor中打开了会爆出一下的警告:" n2 [" K# v; m$ B
Net DGND is defined as a signal net and contains 147 pins., G0 n6 K4 J! b9 u! W
# This is more pins than most signal nets contain. " _2 t) C; E0 i# Please verify whether net DGND should be a signal net or a power net.1 H" `* Z' p, B* V- z4 @
# Note that a signal net will be routed as starburst or daisy chain.# C( G# J+ H& P- W* O9 A
6 m* `9 d# }7 ?# q
这样的警告是不是因为我没有进行模拟地数字第的划分呢?
