1金币
?8 e. o, m0 i) ?1 a7 ~0 u' B
首次把把pads logic netlist导入pads layout中出现ATTRIBUTE错误,如下:6 f! {& U4 E- t% l
% e5 Q# }: K' m# }
Loading <RPF08155B> from library
9 b$ y/ o/ M+ d; ~8 eCannot assign value <6.0mm*6.0mm*1.3mm> to attribute <Geometry.Height>, a) L D: C4 M9 d7 o* M/ } `
Error: Unit mm*6.0mm*1.3mm cannot be recognized5 }, {1 V* \% E) E6 b! l/ G
Loading <LMSP33AA-262> from library
! O# Q! N( D/ k* D8 D% E0 X- pCannot assign value <3.2mm*3.2mm*1.5mm> to attribute <Geometry.Height>) c6 W# o% I1 p- M* f9 n
Error: Unit mm*3.2mm*1.5mm cannot be recognized
% _0 r6 h6 ~6 [ATTRIBUTE VALUES; u# _# t& [0 Y* Q! K, Y0 e" H
PART C1518 {1 e+ ~8 H: R
Warning: Attribute type Manufacturer not found, free text attribute assumed
, v9 p7 [; x1 W! y8 O u) M2 yATTRIBUTE VALUES
& a5 P- ^# v' U$ K* s ?PART R103: m4 ?4 g7 X2 [$ ^+ [
Warning: Attribute type ASSEMBLY not found, free text attribute assumed
3 _+ m9 |8 o n$ }( ^ATTRIBUTE VALUES8 I* n" x* R/ K* t# T2 f% P
PART R1031 I' _' D+ K1 I. p7 Z# K4 R; b
Warning: Attribute type DECAL not found, free text attribute assumed, o/ q# r9 M3 G. ~5 o
ATTRIBUTE VALUES. J) X$ V) t( U& h6 k8 S9 D4 X1 W S7 I+ G
PART U102
3 U. U& t U- q* TError: Unit mm*6.0mm*1.3mm cannot be recognized, f: g7 B& a. |3 C4 h$ h% W
ATTRIBUTE VALUES
" x# \. C; |% P; A% a, pPART U103
! u$ |2 s5 D" n9 |& ^6 FError: Unit mm*3.2mm*1.5mm cannot be recognized
/ c' h; |# |* K6 XATTRIBUTE VALUES
1 R6 W9 J6 M4 @! oPART C640
4 j2 K! j/ o- U6 X* J0 \8 PWarning: Attribute of type VOLTAGE not allowed for specified object5 a6 V0 ]' \' C6 s
ATTRIBUTE VALUES) s* c4 d" |. x, M
PART L700
/ l. m+ m5 k9 R6 U `Warning: Attribute type PART NB3 not found, free text attribute assumed
! c) Q4 t+ I" _! }/ S! o3 zATTRIBUTE VALUES
! i' p) C4 ^0 p# ]! A; E! [& PPART U101
8 ^3 Q& `7 {8 W3 x: R4 UError: String V8 is treated as Volt but such treatment is prohibited
$ v* l+ C$ y& d* y4 WATTRIBUTE VALUES7 R* _2 m# K0 W9 d' ?- I
NET VBAT, z- |5 ^+ g5 j7 k6 Y, d* N; J
Warning: Attribute of type Source Path not allowed for specified object6 C6 Y' p1 m/ }% l
ATTRIBUTE VALUES
2 d$ ^. E+ R. S# a @NET VBAT! r3 Q, }" l4 O9 ?5 u
Warning: Attribute type Name not found, free text attribute assumed
: }# v% d& Q: ]3 c, l+ d0 u**INPUT WARNINGS FOUND**$ }/ U# l U7 ~6 J3 g) i7 V, q
6 e/ O7 a; m$ l7 d- @+ k
我把logic的ATTRIBUTE全部修正与LAYOUT里面的ATTRIBUTE一样的还是出错,请各位高手指引我
% ~$ n" d6 y; K' {
. G: J' y, _' i7 a% F( m* G |QQ:271936212 / Y2 j9 Q8 e2 k7 A
8 a& I5 S6 t, \' o+ J* \非常谢谢,急 |
