查看: 219|回复: 0
Wallys/mini pcie QCA9880/QCA9882 2.4G/5G Dual band support DR40x9 IPQ4019 rou...
    2023-2-7 15:43
    发表于 2023-2-7 15:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    Wallys/mini pcie QCA9880/QCA9882 2.4G/5G Dual band support DR40x9 IPQ4019 routerboard
    8 B  A3 ?# ~# }0 L6 b( mQualcomm-Atheros QCA9880 chipset- Y% d+ H- k, b9 X! n6 p  f/ S
    2.4GHz max 26dBm & 5GHz max 25dBm output power
    . L  M; r- X. [6 S) `IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
    ; h, j- c& C2 Y4 m1 h0 |3x3 MIMO Technology, up to 1.3Gbps * j3 S, b. s/ |+ S: [
    Mini PCI Express edge connector
    + I' \9 n- F5 z3 j( H8 PRoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals  , l; O, v5 C- C8 N9 k1 o" S6 B
    Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio3 b% b/ s# Q& F/ P+ m* ^3 u8 G
    Combining (MRC), Space Time Block Code (STBC) & R8 e7 w8 s9 ~+ V/ _# \
    Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards 7 w7 g6 r1 ~; i* L! l6 E
    Supports Dynamic Frequency Selection (DFS) 2 x8 q5 F( P, g* H/ r# O4 Z, ?$ |
    FCC,CE and IC Certification. x& ?7 x2 B% @) o0 z) c
    % ~* v: |& ~  H# |
    Symbol
    % |( ]2 N& \1 z7 J
    Parameter
    ( I  t) g' \, S' g# ^
    Chipset% S1 ]: N+ h" S! @: F& Z
    QCA9880- t& w" l- E. X# c, `. w
    Host InteRFace( B( S  q- K* g" V
    Mini PCI Express 1.1 Standard
    " a' m" T- ^; X  x+ r; A
    Antenna Connector& H! s2 F# V1 K9 J' c
    3 x UF.L
    : F8 a1 ^6 n, s) Q$ _2 P& H+ Y  n
    Frequency Range
    8 P* p2 M) B# a" U* a. f% c/ j- i
    2.4GHz: 2.412GHz to 2.472GHz
    2 O3 {" Y% G7 F) H( J8 n+ z% Z5GHz: 4.920GHz to 5.825GHz
    6 c6 M& K; ]  g1 d3 a
    Operating Voltage3 {" K2 s. s* J9 }8 C' Z5 e- w! F1 W- U7 r
    3.3V DC
    7 \" v, m6 \" H5 \
    Power Consumption0 e3 }0 K: y' v, Y
    5W(Max)
    " O' [! `/ s( j: M- x
    Modulation Techniques
    : h. a" \9 `' Q3 y
    OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM5 Q) A- x2 V5 Q) f$ w5 n
    Environmental Temperature' N/ o8 y! I5 U, r2 y& c
    Operating: -40°C to 70°C, Storage: -40°C to 90°C, Z! G) G3 p8 f8 M6 r
    Environmental Humidity, non-condensing
    9 X, P; b6 f% j, ?" i# M2 r' l
    Operating: 5% to 95%, Storage: Max. 90%2 U1 I$ t. U- J4 s( l6 e* M) \; {
    ROHS Compliance3 I1 P. F: ^: q1 d, _! A; m
    YES
    7 c2 |5 f9 s( h
    Dimensions (W×H×D)
    7 G3 Q. a/ U) W8 w! s1 b+ t
    30.0mm × 50.9mm × 3.2mm
    : j* u. r& E8 j. @0 X
    : \$ ^% M* [& V# n$ k) ~; ^
    , W6 ]  c4 y  @7 Q. t$ n$ S
      Version
    % {& h0 A) F) \- s  I( n" K5 ^; e* H' Y5 X
    Version
    CPU
    Feature
    DR900VX
    QCA9880
    4 F& s* w4 u8 B, A0 S" [
    DR900VX-i
    QCA9890
    Operation Temp. Up to 85°
    DR900VX-4.9
    QCA9880
    Support 4.9G
      `+ t* _$ `% ?; R
    Wallys  has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
    Skype/EMAIL/Teams:sales@wallystech.com
    WEB:https://www.wallystech.com/
    9 Y" H; X- T) Z* p% m& w6 f- k2 [1 o% o% v
    GMT+8, 2025-11-6 19:17 , Processed in 0.125000 second(s), 24 queries , Gzip On.
