大家好,我用的是pads2007,为什么我在画好原理图转档时出现这样的提示且画好的线路无法转过去。情况如下;/ s$ b5 _9 l Q: X7 g
5 `2 \% c8 N! O- NReading file -- C:\PADS Projects\padsnet.asc9 d" y( g9 p" L4 I
Part name already used 1.1
3 m9 W+ D5 i7 V8 V* N1.1 PIN1.2@PIN1.2
5 {3 Z, S z. G- {' X- N: sPart name already used 1.2
, M( I+ X4 O* t1.2 PIN1.2@PIN1.2
$ w7 {$ ~4 @ H& }7 JPart name already used 1.3
9 N( Z" k1 h, ^, t. F4 L D1.3 PIN1.0@PIN1.0& e, l: N1 m; S7 i3 H
*Part name not found 18 n" k7 u0 f K5 f
1.1.1 1.2.1 1.3.1 - l# N! p5 j- m+ \% O# ~ D
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$15665
: y6 {. S7 n% B3 o*Part name not found 1
* j7 ?: @$ V" L3 f+ C( S: o1.1.61 1.2.61 1.3.61 - T6 D; Q9 W# G4 a, }3 D
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$156832 W2 F/ U \; W: C. ]/ F U" l
Warning: deleting signal $$$15665) l1 B& F# J& `1 r( V
Warning: deleting signal $$$15683
' \8 u4 b O; s$ P/ P**INPUT WARNINGS FOUND**
2 _7 k! m* e8 X8 i. x0 ?0 d请各位高手帮忙。急 |
