Brief Introduce DR6018-S V02 IPQ6010/IPQ6018/IPQ6000 Quad-core ARM 64bit A53 @1.8GHz Processor 1GB DDRL3L System Memory 8MB NOR Flash, 256MB NAND Flash Supports Dynamic Frequency Selection (DFS) 2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate 2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate Wallys Communications (Suzhou ) Co., LTD www.wallystech.com with over 15 years of experience in wireless industry, specialized in designing and manufacturing routerboards and wireless network cards. For decades, Wallys keep providing top wireless devices and wireless technology. We mainly develop high power wireless products based on Quacomm chip such asIPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/IPQ8072/IPQ8074/QCN9074 and so on. We sincerely hope to establish business relationship with your esteemed corporation. Absolute Maximum Rating Supply Voltage: 24V~48V(DC Jack) Operating Temperature Range: -40ºC to +70ºC Storage Temperature Range:45ºC to +105ºC Operating Humidity Range:5% to +95% (non-condensing) Hardware Specifications CPU: Qualcomm-Atheros IPQ6010 CPU Frequency: Quad-core ARM 64 bit A53 @1.8 GHz processor System Memory : 1GB (2x 512MB) DDR3L 16-bit inteRFace with 32-bit memory bus designEthernet Port: 1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports NGFF Slot: M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module) SD Card Slot: 1x SD Card Slot(Option) USB /header: 1x USB 3.0 Port(Option) POE: 24V~48V passive POE/Active POE(Suport 802.3bt) DC Jack: 24V~48V power supply LED header: 2.0 pitch pin header Serial Port: 1x Serial Port 4 Pin Connector Wireless: On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain 4 x MMCX Connectors Nor Flash: 8MB Nand Flash:256 MB DDR: 256-512 MB Dimension: 125mm x 105mm x 20mm % V8 s" x8 `7 D% \
