查看: 119|回复: 0
Wallys/ DR6018 Wi-Fi 6E QCN9074 WiFi 6E Card
    2023-1-9 15:31
    发表于 2023-1-16 15:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    Qualcomm-Atheros IP6010
    Quad-core ARM 64bit A53 @1.8GHz Processor
    1GB DDRL3L System Memory
    32MB NOR Flash, 256MB NAND Flash
    Supports Dynamic Frequency Selection (DFS)
    2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
    2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
    Support: Quectel RM500Q-GL
    SupportCN9074 WiFi 6E Card
    ) g* H. P. C; l% }4 o
    Absolute Maximum Rating:
    Supply Voltage:        24V~48V
    Operating Temperature Range:        -40oC to +70oC
    Storage Temperature Range:        -45oC to +105oC
    Operating Humidity Range:        5% to +95%  (non-condensing)
    Hardware Specifications
    CPU: Qualcomm-Atheros IPQ6010
    CPU Frequencyuad-core ARM 64 bit A53 @1.8 GHz processor
    System Memory:1GB (2x 512MB) DDR3L 16-bit inteRFace with 32-bit memory bus design
    Ethernet Port:1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
    NGFF Slot:M.2 (NGFF) E KeySocket with MiniPCIe 3.0
    SD Card Slot:1x SD Card Slot
    USB /header:1x USB 2.0 Port
    POE:        24V~48V passive POE/Active POE(Suport 802.3bt)
    DC Jack:24V power supply
    LED Header:FFC/FPC Connector
    Serial Port:1x Serial Port 4 Pin Connector
    Wireless:
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
    On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
    4 x MMCX Connectors
    Bluetooth:Optional
    Nor Flash:8-32MB(normally is 8MB)
    Nand Flash256MB
    DDR:1GB
    Dimension:185mm x 116mm
    Wallys Communications(Suzhou). Ltd http://www.wallystech.com which is professional supplier specializing in manufacturing and offering superior OEM/ODM/JDM services in wireless communications. As a specialized manufacturer and exporter for these products in China, we sincerely hope to establish coorperations and business relations with your esteemed corporation. We mainly develop high power wireless products based on Quacomm chip such as IPQ6000/IPQ6010/IPQ4019/IPQ4029/IPQ8072/IPQ8074 and so on.
    7 \2 Q& B" f8 a! N! v$ n# H1 o; t
    DR6018 V4(3).jpg (29.18 KB, 下载次数: 1)
    GMT+8, 2025-7-31 09:02 , Processed in 0.125000 second(s), 28 queries , Gzip On.
