查看: 785|回复: 0
输出网络表格时出了错
发表于 2012-3-4 10:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大家好,我用的是pads2007的,今天遇到一个问题,就是我在输出网络表到PADS LAYOUT 时出现以下的错误,请问是哪里设计不对还是真的有错。 特别是*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$258725 l4 s. _8 q2 Z% A3 o
*Part name not found 1 这是什么意思呢,我画的线路都没有被转过来,只剩下元器件了,这个就是怪了,请各位高手帮我分析分析呢,谢谢!( U9 _# `+ s4 Z4 i. p* r
: J( N+ g" S  L! l' [2 ^9 G; }7 N& y6 R  c% _+ Y, S
Reading file --  C:\PADS Projects\padsnet.asc
( u" f; ~* z) ~  ^5 c+ b# k: o) f*Part name not found 1
5 U3 \( m& @& m" a$ G) H1.1.1 1.3.1 1.2.1
* n, ~/ ]1 R* e4 j( c1 f2 r8 ]* H*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$25872' w  t" i6 y' L  E
*Part name not found 1+ P% v1 J. T2 C5 O
1.1.61 1.2.61 1.3.61 , E  X# t, B% t/ k
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$25890; a1 q6 r1 I4 U
Warning: deleting signal $$$25872
. E: R8 l: Z1 J; [; Z/ AWarning: deleting signal $$$25890, b/ k, f2 {9 R' P( E* b: o
**INPUT WARNINGS FOUND**
GMT+8, 2025-7-21 03:16 , Processed in 0.125000 second(s), 24 queries , Gzip On.
