TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
特性
1 b0 g; }4 w( ] S3 L M■ 3.0V to 9V Operating Input Voltage
! o4 J ]; l% s: A/ A! ^■ Up to 26V Sustainable Voltage" t' B. H3 U- v! a8 @
■ Up to 1A Configurable Charge Current for Battery
: }6 X: U8 W, @4 kwith 3 Cells in Series( ~7 G$ t: u5 o& M& }
■ Configurable Input Voltage Limit
R0 o/ t' H$ q* T2 U■ Charge Status Indication l4 M* }6 e0 Q0 _& j
■ Constant Voltage Selectable
$ o5 h0 ]5 n/ T■ Programmable Charge Timeout& `+ ~5 [/ V( C" q2 _
■ Thermal Regulation Protection
) d4 }' H! G1 [' K■ External Shutdown Function# h; h( A6 x' H6 L3 S0 I
■ Input Voltage UVLO and OVP
8 h. }; Z/ b4 t+ C■ Over Temperature Protection/ G( B! [; D1 V7 I, D4 Q' Q
■ Output Short Cir cuit Protec tion Normal
6 M [2 p$ f# q% I) H PSynchronous Boost Operation When Battery: ^" Q9 ?8 T T6 M- D
Removed) Y" H Z5 I2 v5 U5 h0 ]& o5 o
应用
/ w. J3 a, w& g+ x8 w# g2 R6 U■ Power Bank: ?) A, C1 H+ @1 G# d
■ Cellular Telephones,MP3Players,MP4 Players
: K& M; y7 e1 Y8 h■ PSP Game Players,NDS game Players. M) I7 x$ |0 R' U2 X- `' a9 ^
■ Notebook
' L* W+ f* o P/ K. O* s9 c描述/ `1 ^# M( B) K* Z8 g) R3 }
ZCC6983 is a highly integrated synchronous boost4 u* U; h! N% B# ? U1 M
charger IC for Lithium-ion batteries with four cells in
+ X/ W6 h! B) Q" ~series . The charge current up to 2A can be& `0 R1 N# E ]' M- k4 d3 M
programmed by using the external resistor for different
4 @& Q& w5 h) V5 m/ `2 u; F( ^portable applications.
0 ^6 G1 I* C) X, _, l/ }9 w* \Robust protections include input over-voltage
/ u: n4 ^; z# M# s" B! G2 Uprotection (OVP), battery OVP, battery short protection,& }, n4 z/ Z! @* U x. A, @4 U2 W2 s
thermal shut down, battery temperature monitor, a
' {8 C* u1 M7 mconfigurable timer to prevent prolonged charging of a
' u; p/ Y2 A; ^dead battery.
" L# U1 O- W/ s' u, |: [ ! ^& C' B+ m4 P1 [7 ?( ^
