本帖最后由 sisisisisisiwww 于 2022-3-2 10:15 编辑 * d" l1 g: L" M0 d# P
' D' u' L) H8 D5 _1 r7 s0 |) N
[allegro16.6][4层]HI3516CV500DDR4DMEB(BGA280-26-1818+MJ8-SRLFY)原理图和pcb文件 2 @2 P+ @* g, [7 a+ Z- g9 ]: {9 g
文件描述: 1. 作品用途:HI3516CV500DDR4DMEB 2. 软件版本:allegro16.6 3. 层数:4层 4. 用到的主要芯片:BGA280-26-1818+MJ8-SRLFY 5. PCB尺寸:127.41*145.55
2 c$ w' N& {8 v" N作品截图如下:
7 ^; \1 M2 A' ^顶层截图:
; l ?( B {) O0 N* [8 `
; _0 t# \, z g- l% r! T2 d8 S. u+ s
底层截图: ! Y* l y$ f+ H; e5 N5 ?7 U: ?
0 I, ?2 j. o; @2 H0 b全部截图:
7 a% _. y) b( Y
) u; v0 G2 B7 d( W3 _% WPCB&SCH
. j% W; ?+ K% M
5 I+ h6 h X- u& rBOM:
- x z( ?. ^( j! ?6 W: X| SYM_NAME | COMP_VALUE | REFDES | | BGA96-32-1609Z | H5AN4G6NAFR-UHI | U22 | | BGA280-26-1818 | HI3516CV500 | U1 | | DB9-2RM | DBR30_09K1206 | J10 | | GND12 | TESTPOINT-HOLE | TP2 | | HEAD0101-T-B | * | J2;J3;J14;J16;J18;J25 | | HSC0402-HDTA | 100pF | C159;C160 | | HSC0402-HDTA | 33 | R21;R26;R29;R30;R33;R245;R247 | | HSC0402-TA | 330N | C19;C20 | | HSDC10-1614B | DM3A-SF-PEJ | J8 | | HSL1008 | 2.2UH | L4;L6;L7 | | HSL1008 | 470nH | L10 | | HSOD882 | 0* | D4 | | HSOD882 | ESD8V0R1B_02LRH | D5;D6;D7;D8;D9;D11;D12;D15;D20;D23 | | HSOD882 | PESD5V0S1BL315 | D16;D17;D18;D19 | | HSR0402-TA | 560 | R101;R102 | | HSX2-0302 | 32.768KHZ | X2 | | HSX4-0302 | 24MHZ | X1 | | HSX4-0302 | 25MEG | X3 | | ID-BOARD | PCB-MARKPOINT | ID1;ID2;ID3;ID4;ID5;ID6 | | IDC20-DTM1-A | HU5_200PNA_S53T_FA | J6 | | MJ8-SRLFY | E5J88_14L824_L | J17 | | MLF6-065-0202L | HPA00615DRVR | U16 | | MTH_C6MMD3P2MM | HOLE-8STARS | M1;M2;M3;M4;M5;M8 | | PWC0103-M-N | DC2026_00 | J13 | | QFN16-050-0303LH | MP6507 | U20 | | QFN32C-050-0505LH | RTL8201FI-VC-CG | U9 | | RUSB5-065-0807E | 32010537 | J19 | | SBAT2-13A | BR_1225F1AN | U18 | | SC0402 | 5.6PF | C1 | | SC0402 | 47PF | C2;C24 | | SC0402 | 100NF | C5;C14;C30;C31;C40;C42;C44;C45;C49;C50;C52;C53;C54;C57;C58;: O# W: {: z/ y! G$ {- i2 J
C66;C67;C68;C69;C98;C108;C109;C114;C202;C203;C229;C230;C332;C461;C462 | | SC0402 | 1UF | C15;C189;C466;C467;C468;C469;C470;C471;C472;C473;C474;C475;C476;C477;C478;C479 | | SC0402 | 100nF/NC* | C16 | | SC0402 | 22NF | C22;C480 | | SC0402 | 15PF | C23;C136;C206;C207 | | SC0402 | 100NF/NC* | C38;C48;C61;C70;C92;C97;C463 | | SC0402 | 100nF | C43;C423 | | SC0402 | 10NF | C78;C79;C121 | | SC0402 | 680PF | C87;C88 | | SC0402 | 18PF | C128;C204 | | SC0402 | 1NF | C130;C131;C132;C484 | | SC0402 | 27PF | C144;C145 | | SC0402 | 220PF | C173;C174 | | SC0402 | 22PF | C185;C186 | | SC0402 | 220nF/NC* | C464 | | SC0402 | 220nF | C465 | | SC0402-BGA | 2.2UF | C3;C7;C9;C12;C29;C37;C96;C119;C122;C125;C139;C141 | | SC0402-BGA | 4.7uF | C21;C51 | | SC0402-BGA | 220nF | C47;C110;C111 | | SC0402-BGA | 100NF | C55;C60;C62;C63;C64;C65;C90;C99;C102;C106;C126 | | SC0402-BGA | 4.7UF | C93;C103;C105 | | SC0402-BGA | 220NF | C100;C104 | | SC0402-PD | 2.2UF | C27;C28;C76;C77 | | SC0402-PD | 2.2uF | C32;C33;C138 | | SC0402-PD | 4.7uF | C36;C41;C89;C116;C117;C118;C120;C134;C140 | | SC0402-PD | 2.2uF* | C81 | | SC0603 | 100NF* | C6;C150 | | SC0603 | 10uF | C11;C193 | | SC0603 | 1UF | C17;C18 | | SC0603 | 100NF | C84;C85;C86;C142;C149;C151;C252 | | SC0603 | 10UF | C408;C415;C485;C486;C487 | | SC0805 | 10UF | C8;C10;C13 | | SC1206 | 1NF | C133 | | SC1206 | 22uF | C192;C200;C460;C481 | | SC1206 | 22UF | C194;C196;C198;C199;C201;C334;C482 | | SC1206 | 22UF/NC* | C195;C197;C454;C483 | | SC1210 | 100UF | C146;C224 | | SC1210 | 100UF/NC* | C147 | | SC1210B | 22uF/NC* | C4 | | SC1210B | 22UF | C129;C135;C181;C182;C183 | | SCAPC2-280-327 | 220UF | C320 | | SD0805-LED | LED | D3;D22 | | SD1710A | 1SMA13CAT3G | D21 | | SD1714D | TISP4350H3BJR_S | D10 | | SED60-16F-A | MIPI_60_CON_F | J9 | | SF6127 | SSQ2 | F1 | | SGM8903 | SGM8903 | U11 | | SHEAD-4P-49 | 53398_0471 | J1;J5;J7;J15;J21;J23;J24 | | SIP-6P | TSW_106_23_F_S | J4 | | SL0402 | LB | LB1;LB2 | | SL0402 | BLM15HG102SN1D | LB3;LB9;LB10;LB16;LB17;LB19;LB20 | | SL0402 | BLM15BD601SN1D | LB11 | | SL0603 | MGLB1608_030T_LF | LB5;LB7 | | SL0805 | 4.7UH | L2 | | SL0805 | MGLB2012_220T_LF | LB8 | | SOD323-N | * | D13;D14 | | SOP8-50-150 | TLV2372IDR | U7 | | SOP10-20-124A | INA220AIDGSR | U34;U40 | | SOP16-26-208-255 | ICL3232EIA_T | U13 | | SOP16-50-300A | NC* | U2 | | SOT23 | D2-3_D | D1;D2 | | SOT23 | PMOS-GSD | Q1 | | SOT23 | NPN-BEC | Q3;Q4;Q6 | | SOT23-5 | SY8088 | U3 | | SOT23-5 | SY8089 | U12 | | SOT23-6 | SY8120I | U4;U5 | | SOT23-6B | RT9065GE_A | U6;U21 | | SPL0404L | 3.9UH | L1;L3 | | SR0402 | 12K | R3 | | SR0402 | 47K | R6 | | SR0402 | 0 | R7;R40;R41;R42;R43;R46;R47;R50;R57;R64;R73;R105;R107;R118;R444;R445;R446;R461;R462;R463 | | SR0402 | 47K/NC* | R8;R10;R11;R12;R15 | | SR0402 | 1K | R9;R17;R22;R35;R52;R74;R76;R80;R87;R199;R200;R201;R203;R204;R205;R207;R208;R252;R354;R355;R356;R374;R375 | | SR0402 | 10K | R13;R60;R63;R71;R72;R75;R82;R159;R160;R161;R162;R163;R164;R165;R171;R172;R178;R183;R188;R189;R196;R206;! }( w% N! D7 i& I7 }, ^' Q
R369 | | SR0402 | 100 | R18;R23;R28;R44;R45;R48;R51;R368 | | SR0402 | 20K | R19;R49;R153;R219 | | SR0402 | 0/NC* | R25;R104;R106 | | SR0402 | 2.2K | R31 | | SR0402 | 1MEG | R36;R37 | | SR0402 | 10 | R38;R230;R231;R240;R241 | | SR0402 | 24.9K | R39 | | SR0402 | 91K | R55;R56 | | SR0402 | 10K/NC* | R61 | | SR0402 | 30K | R77 | | SR0402 | 15K | R78;R128 | | SR0402 | 24K | R79;R220 | | SR0402 | 100K/NC* | R81 | | SR0402 | 470K/NC* | R83;R84 | | SR0402 | 2K | R85;R86;R250;R370 | | SR0402 | 1.5K | R96 | | SR0402 | 2.49K | R100 | | SR0402 | 4.7K | R103;R108;R109;R110;R111;R116;R117;R186;R187;R242;R243;R276;R277;R278 | | SR0402 | 4.7K/NC* | R112;R190;R191;R244 | | SR0402 | 5.6K | R123 | | SR0402 | 100K | R124;R125;R211;R212;R215;R217;R291 | | SR0402 | 75 | R144 | | SR0402 | 2.7K | R145;R146 | | SR0402 | 22 | R150 | | SR0402 | 3.3K | R156 | | SR0402 | 22K | R170 | | SR0402 | 150K | R185 | | SR0402 | 6.8K | R222;R223 | | SR0402 | 51K | R308 | | SR0402 | 1K/NC* | R367 | | SR0402 | 240 | R372;R373 | | SR0402 | 8.25K | R376 | | SR0603 | 100 | R1;R130;R131 | | SR0603 | 100/NC* | R2 | | SR0603 | 510 | R4;R5;R225;R226;R227 | | SR0603 | 1.1K | R14;R93;R94;R95 | | SR0603 | 2 | R16;R218 | | SR0603 | 9.53K | R24 | | SR0603 | 5.1K | R32;R34 | | SR0603 | 75 | R97 | | SR0603 | 24.3K | R98;R99 | | SR0603 | 4.7K | R149 | | SR0603 | 33.2K | R158 | | SR0603 | 0 | R289 | | SR0603 | 0/NC* | R290 | | SR0805 | 0 | R166;R168;R371 | | SR2512C | 0.005 | R20;R27 | | SSW-PUSH | TL3301AF160RG | S2;S3;S4 | | STFM16-50-285 | H1102T | T1 | | SW4_6M6X5M4 | EMR_0415_T_V_T_R | SW1 | | VAF6-1406E | 32110058 | J11;J12 | | WSON8-MX25L12835ZN | MX25L25635 | U19 | q3 z" \! W1 M; _" {2 h
