查看: 204|回复: 0
ZCC2213A锂电池均衡芯片完全替代HY2213A
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2022-2-23 17:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    1. General Description( M1 }6 m: [$ h1 v+ y, Q  H
    The series ofZCC2213is created for multi-cell battery packs to single-cell lithium-ion battery
      F; @$ v. b  LCharge balance control, electrical level monitoring ICs and it also comprises high-accuracy
    1 Q* S: k- `/ r4 W; s; w/ svoltage detection circuit and delay circuit.
    ) P* f& [  {0 M9 c' @2 D4 i2. Feature& A+ V6 Z- I' D# E+ o" u! b; ~
    ZCC2213series IC equips with the following features:
    0 W3 `3 T% X9 K(1) High Precision Voltage Detection Circuit
    / q- U7 v% p* ~/ f) X- [. W) { Overcharge detection voltage 4.000~4.500V Precision: ±25mV( R/ J) l) Y( I& G
     Overcharge release voltage 3.800~4.500V Precision: ±35mV; E; D6 N' y- Q3 E; X! s* e0 ^9 Y
     Standby detection voltage 2.70V Precision: ±15%
      y* {3 l* k9 U Standby release voltage 2.70V Precision: ±15%
    2 c2 s* t1 C, \  B: D) Y: a$ \! Y* Z$ J) C(2) Delay times are generated by an internal circuit (external capacitors are unnecessary).+ L& G: O; X2 P5 {) D) K
    (3) Low consumption current
    9 z  ?  d: W0 f3 S/ {7 w4 R1 }2 ] Operation mode Typ. value 2.5μA, max. value: 3.5μA (VDD=3.9V)
    / F2 ?, Y0 ?+ c% y& C0 ]" Y Standby mode Max. value:0.5μA (VDD=2.7V)
    " I% D# l: a  q2 r6 H7 N% t! j& I(4) Wide operation temperature range: -40℃~ +85℃0 Q9 `8 d4 T" v: q+ z& U' D
    (5) Small package: SOT-23-6
    " Q2 ^. ^' l, L3 U' B# ?4 i1 L(6) The series are Halogen-free, green package
    . x6 F, w, \3 _, G; U3. Application
    5 ~" T* P$ `& u  M6 [' Q2 W$ |9 u Multi-cell Li-ion rechargeable battery packs
    : v# Q; x) u3 U7 ]0 s, H. @* x7 U. ~$ E: G
    GMT+8, 2025-7-27 11:49 , Processed in 0.125000 second(s), 24 queries , Gzip On.
