查看: 1282|回复: 1
PADS原理图导PCB
发表于 2011-8-17 17:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大侠,本人在导PCB时,报以下错误,该如何解决啊?3 k/ @' t% Q! y- U$ k2 A
“* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "0805". Open Layer Setup dialog box and change the layer mode of the design to increased layers.”
 楼主| 发表于 2011-8-17 19:59 | 只看该作者
自己找到了解决方法:在logic中选择:setup->layer definition->clik max layers tab.OK!
GMT+8, 2025-11-26 22:42 , Processed in 0.140625 second(s), 24 queries , Gzip On.
