TA的每日心情 | 开心 2022-5-9 15:00 |
签到天数: 28 天 [LV.4]偶尔看看III
Description
* z, Q- ?7 s; a9 @. kThe ZCC541A/B series is a high input voltage; l/ @, R/ T. Y; @& ~$ b
(40V), low-dropout linear regulator (LDO) able to
0 s s0 A; h2 {provide 1A load current. The ZCC541A/B family
; V; r1 w8 l$ o" O& D6 _LDO offers EN pin to enable and disable the LDO- o- u8 J+ Q% M
output, EN pin can take 40V input voltage.- r( t4 S: ]8 V8 S1 X
The LDO features very fast response against line4 a7 t) V3 K& z ~5 b' i- l' l
voltage transient and load current transient, and" X$ J; q3 j( w# x
ensures no overshoot voltage during the LDO start
, i# `6 z% @3 L( `up and short circuit recovery) z9 {" O- z/ h$ J* A0 a w
The device features integrated short-circuit and' d+ a# x# {# g3 m
thermal shutdown protection.
/ g7 |* n8 Z/ u# t& y$ ~Fixed voltages of 5.0V , 3.3V , 3.0V and 1.8V
. w! ^) p* Y0 i% z# y0 ^# t" yare available on ZCC541BKP with adjustable3 f c) J" D4 m7 _" f) t
output voltages to 0.6V on ZCC541AKP.* y9 B/ Z1 B7 a' t0 t/ ?1 `4 Z
Features
1 `. f& Q. B+ w Fixed and adjustable output voltages to 0.6V
7 t t. F5 T8 d9 g. c& j- r( f/ w% j" P High Input Voltage Rating:Up to 40V
; r$ r3 O# z& R1 C5 i3 E High Output Current:1A
' ^/ h+ W6 \5 N* _1 o. z High PSRR:65dB at 1kHZ2 A3 _" ?# \) M# U9 b
Low Dropout Voltage:1.5V@1A
% K/ w0 m5 F$ e ~; N* Z Fixed Output Voltages:/ V/ w& `( p/ n% Z# O5 H; g; q# S
1.8V, 3.0V, 3.3V,5.0V and ADJ6 l* A7 C- w" l& s3 k5 ] }
High-accuracy Output Voltage: ±2%/ @7 ]- i, \6 K' v. }
Fast Transient Response
! L* f1 {+ f5 z/ J! w Integrated Short-Circuit Protection$ i9 y; X V6 R0 u
Enable pin is available
4 H" A6 X7 l! ^7 a& e) C! a Integrated Thermal Protection
3 j. w5 w) Y0 h7 f Available Packages:ESOP87 g1 R# N6 \$ o7 p+ ]
