查看: 226|回复: 0
ZCC2213A锂电池均衡芯片完全替代HY2213A
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-12-15 17:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    1. General Description# N& w7 \9 _/ R% p" N+ }1 _8 E
    The series ofZCC2213is created for multi-cell battery packs to single-cell lithium-ion battery 5 J# \5 I8 I8 y. A* k) a2 Z0 l
    Charge balance control, electrical level monitoring ICs and it also comprises high-accuracy
    4 Q4 ^4 h/ A( X0 l9 x0 M6 dvoltage detection circuit and delay circuit.
    - `( c2 G, f4 d$ k; A4 H0 H2. Feature4 }! F! h/ K- W8 g4 d! J% p
    ZCC2213series IC equips with the following features:
    1 G8 w% |' J9 O# T/ j) g, O(1) High Precision Voltage Detection Circuit, l( Z" K0 D# j8 ~0 P
     Overcharge detection voltage 4.000~4.500V Precision: ±25mV
    + }8 a8 @$ Y' ? Overcharge release voltage 3.800~4.500V Precision: ±35mV
    5 Y- @3 C+ i" H4 s  s4 l Standby detection voltage 2.70V Precision: ±15%2 w! J2 g5 J- M8 [! k$ K
     Standby release voltage 2.70V Precision: ±15%
    ' b5 @5 b. i7 D; G. p( G(2) Delay times are generated by an internal circuit (external capacitors are unnecessary).6 P& I2 ^$ |* l3 ^* {/ u8 k- Q
    (3) Low consumption current
    6 d- B/ e8 A6 a& f1 n, B9 e7 Y) K1 j Operation mode Typ. value 2.5μA, max. value: 3.5μA (VDD=3.9V)
    " ^- P4 `, [$ C0 T Standby mode Max. value:0.5μA (VDD=2.7V)
    & u% d* _/ ~9 [/ M8 [: ?(4) Wide operation temperature range: -40℃~ +85℃
    * d! C3 A9 H1 @(5) Small package: SOT-23-6
    . Q: h) d6 @4 k4 H) r; o( C  Q3 W(6) The series are Halogen-free, green package
    ' e/ R4 O3 l1 z5 n) N/ |6 K$ v3. Application
    $ f8 B7 q& }* h" n. y* `  q5 c' Q" v Multi-cell Li-ion rechargeable battery packs
    , s# r( R* S. }; r  z8 B8 X' ~: X3 \3 S: s! L3 ~1 Z% b3 x4 `8 o
    GMT+8, 2025-7-27 06:19 , Processed in 0.125000 second(s), 24 queries , Gzip On.
