+ x3 j* G9 O. ~$ |( d$ L1 T/ w! n- z, x; j: D+ x/ T; V
刚刚用pads9.3抄完一个板,结果客户要求存低版本的,我输出PADS2007的ASC文件后用PADS2007导入提示错误,开始以为是版本之间有差异,就出了一个9.3的,再用9.3导入,结果还是一样的错误报告,如下:
+ @/ \% w p, v) f( h. g' m/ [, x6 D6 x
Reading file -- E:\A009A1.asc
5 L3 t) ~$ z& _: E& P*Not valid pin name for part type U85.3
, `. X) T+ A ?( k! [! k8 cU85.3 U85.2
+ l1 s. y1 d0 }& h% x6 v9 q* ?Bad Connection item no# -1. w4 `; `( p' ~' t
*Part name not found 22246588 o) v7 p" a( P7 ^5 W
22246588 45750000 2 228600 1536 & A# S, |2 l9 T6 k
Bad Connection item no# -1, O. M# G7 y# O! S/ P$ C
*Part name not found 220020002 H. v9 J) Q% {+ c2 K X) ]5 Q
22002000 43650000 65 228600 1792 THERMAL
* r$ h" B' w' ABad Connection item no# -1, l& e$ x/ w5 u9 {
*Part name not found 38200500
# L5 f( [' K- X8 l& F7 h- T+ c( V# k0 Q38200500 40705500 2 228600 1536
9 [! A' g% g7 g, lBad Connection item no# -1
, F' q, X, k0 P$ g' z9 I*Part name not found 40867500& d9 j* D. k* k4 a M* Y- ?
40867500 38800500 65 228600 1792 THERMAL % L3 W. k/ H# P, o
& q$ w3 u3 M4 h: q) U3 i( n*Part name not found 43650000
, h# T7 Y7 m& A- b43650000 38898000 2 228600 1792 THERMAL 0 L1 r% T9 w, t' y& w
/ {: d- O3 T8 j. \6 a$ T- Y+ u( d7 S0 t1 @
*Part name not found SEG
- P: m0 P0 a9 _+ f: CSEG 2 0 381000 23 q- [+ b z* \8 j/ [5 i- b
Bad Connection item no# -1. |" M5 \9 W! ~+ q- M/ i- G% T
*Part name not found -644210752" c1 J7 }" l! v1 H+ f
-644210752 -658010348
3 m- g! w z/ s+ H" eBad Connection item no# -1% m! @3 w: ^* d' c
ATTRIBUTE VALUES
. ^4 \5 s0 O' G% x/ gError: Net $$$45 not found: W! R2 `. V# l/ { W7 C" r
ATTRIBUTE VALUES5 M& u M) I( j. b. h
Error: Net $$$46 not found
* K, L3 E$ t0 R5 u B. O0 ~0 FATTRIBUTE VALUES" \; V3 S- e/ [
Error: Net $$$47 not found
7 k* K1 r- q5 ]+ c0 o/ [: P/ }ATTRIBUTE VALUES0 ]- ?3 C; |% W9 V" {- p$ I& x
Error: Net $$$48 not found- A* q8 I+ T( T3 U2 ^ [8 j
ATTRIBUTE VALUES
" M# J' @% \8 C4 PError: Net $$$49 not found
% ]1 {; C& Z! V3 pATTRIBUTE VALUES
& s! o$ T5 w! h: l, @Error: Net $$$50 not found1 |! \; L+ \- W* V9 d7 z$ ]* B# _
ATTRIBUTE VALUES* K& m; j1 h: |5 F8 l; S
Error: Net $$$51 not found
6 U# j, i* L) }6 q; Q( zATTRIBUTE VALUES
& f, |5 s' \3 S6 M..............
9 g# _! S6 E- m: z
+ A9 J- w, S! C1 v" p* U4 u想知道问题出在哪里,难不成我要重新来过?
" R7 c) m' h# E5 Y: D是不是我的PART Type建的有问题?! m9 [) r; }9 {) G1 l% M8 l2 T
8 r8 Y! s& }3 y
怎么没有回应哦,真的很急啊 |
