The XDS110 comes in a package consisting of:1 V5 H( k+ i3 \" Q
- XDS110 debug pod4 s, |' D( Z! m* E+ n1 \4 P
- 20-pin debug cable
' ]2 [# D( ?: y% D0 f - 14-pin auxiliary cable
& `4 Z/ }: x9 w5 e( H4 l: f* [ - TI 20-pin to TI 14-pin converter adapter (使用的该转接头), S# \/ n/ Q, O
- TI 20-pin to ARM Cortex 20-pin converter adapter
" p" Z' S2 {$ H: D' O - TI 20-pin to ARM Cortex 10-pin converter adapter
$ p0 z# w, m5 S) M& K9 N5 h - USB cable
4 `, D" F I7 u5 Z/ T6 a& Y% H. K - Breakout board for auxiliary cable* k1 Z X. O/ D
- Quick start guide
: a/ j( ^7 k+ @3 ^* P 使用软件版本:CCS6.1.3测试连接报错内容如下:[Start: Texas Instruments XDS110 USBDebug Probe_0] Execute the command: %ccs_base%/common/uscif/dbgjtag -f%boarddatafile% -rv -o -S integrity [Result] 3 V4 ?% y: `; W4 I& y% D9 ?4 s m1 p
-----[Print the board config pathname(s)]------------------------------------ C:\Users\panxi\AppData\Local\TexasInstruments\
3 M# ~7 _/ H0 \0 ~CCS\ti\0\0\BrdDat\testBoard.dat -----[Print the reset-command softwarelog-file]----------------------------- This utility has selected a 100- or510-class product.
) `: C9 f$ b* X& MThis utility will load the adapter 'jioxds110.dll'. An already open status was returnedwhile soft opening the controller. -----[An error has occurred and thisutility has aborted]-------------------- This error is generated by TI's USCIFdriver or utilities. The value is '-110' (0xffffff92).
8 k: t4 r! N3 y0 a: C4 rThe title is 'SC_ERR_OCS_ALREADY_OPEN'. The explanation is:( ~6 y' c% n9 C1 J0 c( x
This utility opened the controller but found it already in use./ c' D, Q1 k( I
You must exit other debuggers and utilities that access the' i: W r5 b, {$ U: x
controller because this utility must be the only client. [End: Texas Instruments XDS110 USB DebugProbe_0] 关键信息截图:7 H. Z4 ]( \. C! e
