查看: 2049|回复: 1
candence生成gerber时遇到了问题
发表于 2011-5-23 10:07 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
FILM PARAMETERS :
  e- S2 _7 X1 Z. Y  ---------------------------------------------------------: A) M7 S3 ]* _. x; k
  Undefined line width                10.00
! b% W# j* I& K  Mirror code                         NONE- F$ u, P$ b5 F: S5 J
  Rotate angle                        NONE; F2 f  U, Y1 U! ~7 i
  Offset x:                           0.00
% M" v' h; F) L* u& H0 O! W1 i( A2 _  Offset y:                           0.003 m) q: n, m8 m$ X; U
  Plot negative                       NO6 W# j* Z9 U) R( b9 J4 Y) n8 h
  Suppress unconnected internal pads  NO
% X% Y9 M( X. W. t9 A WARNING: Photoplot window (21000 x 17000) exceeds film size (24000 x 16000)4 x3 z' F* O1 I& I3 c+ o
          stated in parameter file. # X, k% f5 N8 W3 e) u& l) V  O5 S; M
- T' ]2 O, `7 \6 N. z
  APERTURES USED:
2 t0 p. L7 c6 |; m$ p  ---------------------------------------------------------
0 P" ?8 O1 m0 ~6 @3 _: X8 e  TYPE       SIZE/NAME                   ROT   MIRROR MODE
$ |  Q: F9 o! j/ h. e/ ^1 n5 t" \8 m- y  ---------------------------------------------------------7 b& D9 E/ J5 @
  CIRCLE     0.01600                                  DARK % R5 V- z# y$ ?' D0 Q' ^
  CIRCLE     0.02000                                  DARK 9 j4 q2 I' d. f5 h5 N
  CIRCLE     0.02200                                  DARK
" x& ?5 Y" g2 Y  Z# b& [' ~* E3 S  CIRCLE     0.04000                                  DARK
2 \; b6 v/ B4 j/ P$ a, e& \3 l  CIRCLE     0.05500                                  DARK
4 Q1 b: |/ W0 S8 Q  CIRCLE     0.06000                                  DARK 4 T2 o/ b+ \+ r1 r/ D
  CIRCLE     0.06500                                  DARK 5 I! I( X# y( Y$ T0 x
  CIRCLE     0.07000                                  DARK
1 i$ r% {6 d" B- N# R3 i3 c  CIRCLE     0.08000                                  DARK
' n7 e- t* n! |  CIRCLE     0.11000                                  DARK
" c8 W2 U+ a8 a0 |. O( h8 M  CIRCLE     0.21102                                  DARK * l+ P) K# o* P! d& H0 y
  SQUARE     0.04300                     0.000 NO     DARK ; J3 j  h3 G$ ^: b* C; Z2 ]) p6 o
  SQUARE     0.05100                     0.000 NO     DARK
- {( F1 u! i6 D9 w7 C% h+ k  SQUARE     0.06000                     0.000 NO     DARK
; D( a# T; r+ a9 f3 T  SQUARE     0.06500                     0.000 NO     DARK
, h3 R& p6 Y. N; \, U  SQUARE     0.07000                     0.000 NO     DARK
- N# g9 a$ f' N! V- |  SQUARE     0.08000                     0.000 NO     DARK $ d/ ]' @1 g, ]$ s
  SQUARE     0.24000                     0.000 NO     DARK 8 ?- G* q3 d* A" H
  RECTANGLE  0.01100     x 0.01700       0.000 NO     DARK ' E, T( `3 A# G3 u/ b  b) Q
  RECTANGLE  0.01100     x 0.01700      90.000 NO     DARK . M( F+ ~. m7 d* d2 {
  RECTANGLE  0.01300     x 0.02500       0.000 NO     DARK 7 D5 B! F  H2 S1 }5 m( y
  RECTANGLE  0.01300     x 0.03300       0.000 NO     DARK 0 m! v! Y$ _) l
  RECTANGLE  0.01400     x 0.03200       0.000 NO     DARK
& _& E! p+ s- x8 K, s- S0 G$ R  RECTANGLE  0.01400     x 0.03200      90.000 NO     DARK
" b9 p- f) {/ {1 ?+ E  RECTANGLE  0.02200     x 0.01800       0.000 NO     DARK
3 `% L/ i( e+ P7 Q  RECTANGLE  0.02200     x 0.01800      45.000 NO     DARK
# U- N0 ?  n3 u  RECTANGLE  0.02200     x 0.01800      90.000 NO     DARK
. e1 R! ~! E# e$ |0 n1 V  RECTANGLE  0.02750     x 0.02500       0.000 NO     DARK % E" f+ f. G# l  R
  RECTANGLE  0.02750     x 0.02500      90.000 NO     DARK
/ E. p/ ~" u$ s3 {  RECTANGLE  0.02800     x 0.01550       0.000 NO     DARK / h: F* F3 E7 i
  RECTANGLE  0.02800     x 0.01550      90.000 NO     DARK
- x; ?1 M3 Y% u  RECTANGLE  0.03100     x 0.05500      90.000 NO     DARK
( G! |4 w& m+ J) }; `5 w  RECTANGLE  0.04400     x 0.05300      90.000 NO     DARK ; G6 e6 u. j2 I7 F, y
  RECTANGLE  0.04700     x 0.06000     179.943 NO     DARK
, E( e1 }* j6 e# j  RECTANGLE  0.05100     x 0.05800       0.000 NO     DARK
  E! I0 ^, h( ^) p4 b& B& n  RECTANGLE  0.08000     x 0.04700       0.000 NO     DARK . w( c" z; T6 z/ l/ s5 ]
  RECTANGLE  0.23000     x 0.01550      90.000 NO     DARK
  P& `6 ^* A2 d  RECTANGLE  0.23000     x 0.10000      90.000 NO     DARK 0 Z  C  I: y( U+ h% {% M
  OBLONG     0.01200     x 0.03900       0.000 NO     DARK ' Z1 H, k. F' M( F8 x* }
  OBLONG     0.01200     x 0.03900      90.000 NO     DARK * s/ b4 q$ W+ \5 o! g( U
  FLASH SYM  CIR40                       0.000 NO     DARK  (undefined)
4 S& o1 c2 c6 o# e" C, Q2 ]8 `& Y2 P5 q  y
    ERROR: aborting film - Undefined aperture symbol, cannot continue.. E" k# U' {/ q# I7 m" G: B
           See APERTURES USED table in this file for symbols to provide.6 g$ x) ~5 A7 F! V4 ]: ?) p
Error in TOP--halting output.  Artwork file not generated.5 B4 M* |  ^7 b$ \; Y1 N
*** ERROR with TOP
/ m% Z& D  _2 S这里说少了cir40的FLASH,但是我应该怎么添加呢?+ o+ W  n$ y! v3 l
" b: M+ q: D$ P! M我找到了用到cir40的地方4 Q8 O, Q  ^5 f7 G& C! D
5 Y- \. N* @! j! v* f4 r我现在应该怎么做呢?求高手指教。它在rgular pad那里用到了FLASH。谢谢!!!! @4 j: l( J* g* @5 y/ Q
发表于 2011-5-23 13:44 | 只看该作者
应该是没生成光圈文件吧,你运行一下APERTURES试试。。
GMT+8, 2025-11-22 20:58 , Processed in 0.156250 second(s), 27 queries , Gzip On.
