3 O" X: w4 L. Y% P
- start-stop-daemon
- BusyBox v1.26.2 (2018-08-02 17:42:03 CST) multi-call binary.
- Usage: start-stop-daemon [OPTIONS] [-S|-K] ... [-- ARGS...]
- Search for matching processes, and then
- -K: stop all matching processes.
- -S: start a process unless a matching process is found.
- Process matching:
- -u,--user USERNAME|UID Match only this user's processes
- -n,--name NAME Match processes with NAME
- in comm field in /proc/PID/stat
- -x,--exec EXECUTABLE Match processes with this command
- in /proc/PID/{exe,cmdline}
- -p,--pidfile FILE Match a process with PID from the file
- All specified conditions must match
- -S only:
- -x,--exec EXECUTABLE Program to run
- -a,--startas NAME Zeroth argument
- -b,--background Background
- -N,--nicelevel N Change nice level
- -c,--chuid USER[:[GRP]] Change to user/group
- -m,--make-pidfile Write PID to the pidfile specified by -p
- -K only:
- -s,--signal SIG Signal to send
- -t,--test Match only, exit with 0 if a process is found
- Other:
- -o,--oknodo Exit with status 0 if nothing is done
- -v,--verbose Verbose
- -q,--quiet Quiet
3 Q# {( ]8 L9 V7 |5 r" X 0 A6 I' H2 x* D) R; I# N) I* J
" T% z3 P8 |& J" o3 u" ]' J* p - chad@ape:/$ start-stop-daemon --help
- Usage: start-stop-daemon [<option>...] <command>
- Commands:
- -S, --start -- <argument>... start a program and pass <arguments> to it
- -K, --stop stop a program
- -T, --status get the program status
- -H, --help print help information
- -V, --version print version
- Matching options (at least one is required):
- --pid <pid> pid to check
- --ppid <ppid> parent pid to check
- -p, --pidfile <pid-file> pid file to check
- -x, --exec <executable> program to start/check if it is running
- -n, --name <process-name> process name to check
- -u, --user <username|uid> process owner to check
- Options:
- -g, --group <group|gid> run process as this group
- -c, --chuid <name|uid[:group|gid]>
- change to this user/group before starting
- process
- -s, --signal <signal> signal to send (default TERM)
- -a, --startas <pathname> program to start (default is <executable>)
- -r, --chroot <directory> chroot to <directory> before starting
- -d, --chdir <directory> change to <directory> (default is /)
- -N, --nicelevel <incr> add incr to the process' nice level
- -P, --procsched <policy[:prio]>
- use <policy> with <prio> for the kernel
- process scheduler (default prio is 0)
- -I, --iosched <class[:prio]> use <class> with <prio> to set the IO
- scheduler (default prio is 4)
- -k, --umask <mask> change the umask to <mask> before starting
- -b, --background force the process to detach
- --notify-await wait for a readiness notification
- --notify-timeout <int> timeout after <int> seconds of notify wait
- -C, --no-close do not close any file descriptor
- -m, --make-pidfile create the pidfile before starting
- --remove-pidfile delete the pidfile after stopping
- -R, --retry <schedule> check whether processes die, and retry
- -t, --test test mode, don't do anything
- -o, --oknodo exit status 0 (not 1) if nothing done
- -q, --quiet be more quiet
- -v, --verbose be more verbose
- Retry <schedule> is <item>|/<item>/... where <item> is one of
- -<signal-num>|[-]<signal-name> send that signal
- <timeout> wait that many seconds
- forever repeat remainder forever
- or <schedule> may be just <timeout>, meaning <signal>/<timeout>/KILL/<timeout>
- The process scheduler <policy> can be one of:
- other, fifo or rr
- The IO scheduler <class> can be one of:
- real-time, best-effort or idle
- Exit status:
- 0 = done
- 1 = nothing done (=> 0 if --oknodo)
- 2 = with --retry, processes would not die
- 3 = trouble
- Exit status with --status:
- 0 = program is running
- 1 = program is not running and the pid file exists
- 3 = program is not running
- 4 = unable to determine status5 T- n' g- \8 L. `% T2 m
1 M8 L% Z3 w8 F
' Q( R4 \; ?9 B+ s8 t, c' P/ B4 N( M, w2 c& w, m" G! {
NAME
# G: ~# R- |0 m+ ~ start-stop-daemon - start and stop system daemon programs
, t k; G6 G! P; e" R( I/ j* ?
7 @9 Y1 J, { y% m& Z9 USYNOPSIS0 b! ]/ |# Q7 q4 ~+ g6 P% I
start-stop-daemon [option...] command; {* S B" t/ P8 _& H8 k) y3 W4 P
L D7 ^ [; f4 w- D; {: Y
DESCRIPTION
+ r3 x( A' v" ?% Q start-stop-daemon is used to control the creation and termination of system-level processes. Using one of the matching options, start-stop-daemon can be configured to. j; P3 h+ [2 d% o/ C; r
find existing instances of a running process.2 ]8 a& d. L1 X& D3 p. M) j8 j0 M
* V p( ~% ]6 n. a8 n
Note: unless --pid or --pidfile are specified, start-stop-daemon behaves similar to killall(1). start-stop-daemon will scan the process table looking for any processes- q O8 b6 }' \
which match the process name, parent pid, uid, and/or gid (if specified). Any matching process will prevent --start from starting the daemon. All matching processes will. H# d4 O; G; u+ `2 V) w+ l0 a9 O
be sent the TERM signal (or the one specified via --signal or --retry) if --stop is specified. For daemons which have long-lived children which need to live through a
) U' l1 [+ c2 K) X --stop, you must specify a pidfile.
+ [) {( \2 {9 l4 _! Z( ~7 P- H' h9 R# k6 }* Q9 l7 F6 n' y
COMMANDS0 z( U! z/ P0 ]7 ?3 y
" ]1 d& n2 B2 U4 g6 u! [" |/ B
( q$ S. n+ X2 @- c -S, --start [--] arguments+ o5 A& Z% v- V1 ?- T
Check for the existence of a specified process. If such a process exists, start-stop-daemon does nothing, and exits with error status 1 (0 if --oknodo is specified). If such a process does not exist, it starts an instance, using either the executable specified by --exec or, if specified, by --startas. Any arguments given after -- on the command line are passed unmodified to the program being started.
1 U( {3 G, o8 u& C8 G& I' R5 o1 l! T, i" T; k' C
-K, --stop
5 p6 k' r% t3 u0 x Checks for the existence of a specified process. If such a process exists, start-stop-daemon sends it the signal specified by --signal, and exits with error5 ^' P2 t, a- Q
status 0. If such a process does not exist, start-stop-daemon exits with error status 1 (0 if --oknodo is specified). If --retry is specified, then( H) w6 {1 D8 ?! S% D/ w: V6 w
start-stop-daemon will check that the process(es) have terminated.
P& m- K G6 h" z4 T* U% j
. V4 f5 `6 c% `$ p -T, --status
* ]) ] Q4 p4 Y6 Y. w4 A( U Check for the existence of a specified process, and returns an exit status code, according to the LSB Init Script Actions (since version 1.16.1).- @8 E& Q2 f8 w/ R u& |" U* D
7 K, _, K- u0 {' b- r7 g -H, --help; V7 o+ v: o% a! q q7 C" e
Show usage information and exit.3 b5 p) q3 D( M+ t
; V- O2 H7 s) }9 j( { F2 z0 K8 v -V, --version+ Z+ C& O. a3 b* [3 S6 V
Show the program version and exit.
4 h1 ?, H. }, W4 v; x% f9 \
) A* B( O2 r) y% C% O COPTIONS7 z: Z& I: }5 G4 P( D2 [: e
Matching options* I$ ^* P4 q% J; U: f' o7 F
) J; ]( t& H8 h) K( N/ j- w h
--pid pid
& E' g' }+ g, S0 q: S Check for a process with the specified pid (since version 1.17.6). The pid must be a number greater than 0.$ V, {$ J( f% }: S7 o$ R. N
/ C1 H6 Q; G+ ^7 f5 C; M3 m* r --ppid ppid
& \& y8 V% n5 r! i1 C0 { @# H+ C Check for a process with the specified parent pid ppid (since version 1.17.7). The ppid must be a number greater than 0.
# U! y: X/ k% }8 A9 _$ l
( A( w! `/ u, o& m6 | -p, --pidfile pid-file
6 E$ t$ j. ]: R1 ^4 c% h6 y m8 s Check whether a process has created the file pid-file. Note: using this matching option alone might cause unintended processes to be acted on, if the old process4 G: P6 Z! s7 N: p. I) H
terminated without being able to remove the pid-file.
5 y' n2 d! G: C) N) G' i6 _+ s, J1 t: s% d5 U! H V6 O
-x, --exec executable
; j& r. R3 b5 i7 p Check for processes that are instances of this executable. The executable argument should be an absolute pathname. Note: this might not work as intended with interpreted scripts, as the executable will point to the interpreter. Take into account processes running from inside a chroot will also be matched, so other match restrictions might be needed.
0 _0 z* f% @; Q( d6 [( W0 ^2 o3 Q6 d# Q$ S0 [/ I5 j, e. f
-n, --name process-name
) m! a, x) k. I Check for processes with the name process-name. The process-name is usually the process filename, but it could have been changed by the process itself. Note: on, p. Q. w _! L- G* W
most systems this information is retrieved from the process comm name from the kernel, which tends to have a relatively short length limit (assuming more than 150 Q" L! ^7 a+ s+ f/ e
characters is non-portable).6 L; X( s1 {; c! Z
0 A2 ]( Q$ l* q) q. V& g4 T3 l7 V
-u, --user username|uid' f( I/ u/ @6 y( @
Check for processes owned by the user specified by username or uid. Note: using this matching option alone will cause all processes matching the user to be acted
, T P( i& m' v+ e8 m on.
9 j' t% d: O2 o: O3 q8 i7 V
" c U* j4 D- r0 f( H4 w! V! qGeneric options
0 b0 R* P2 ^$ G- V2 g7 s0 T/ q -g, --group group|gid
; b2 E" o& }& \- u3 D, E Change to group or gid when starting the process." h: f. f. _+ E" x( P
/ d, u, C0 i# c
-s, --signal signal# s1 a1 I3 [2 Z& D9 [4 _# v
With --stop, specifies the signal to send to processes being stopped (default TERM).
! Z8 q1 ]3 F4 J( Z$ l+ c$ E# W; t. J1 G
-b, --background
, C: y, R' e/ y7 q5 a Typically used with programs that don't detach on their own. This option will force start-stop-daemon to fork before starting the process, and force it into the# Z& A& h! s, t, c; v6 p( J- u
background. Warning: start-stop-daemon cannot check the exit status if the process fails to execute for any reason. This is a last resort, and is only meant for
$ [( z& f! i3 \ p2 l- b programs that either make no sense forking on their own, or where it's not feasible to add the code for them to do this themselves.2 V* e; e# q. Z6 W
~1 v( M9 R4 }
-C, --no-close
. M2 E( ]' G! v' g Do not close any file descriptor when forcing the daemon into the background (since version 1.16.5). Used for debugging purposes to see the process output, or to$ h) }6 {# u9 I6 H# `0 U. C% j/ D
redirect file descriptors to log the process output. Only relevant when using --background.
$ X" o9 c& ]' L9 p5 d4 K9 w3 S0 [, W1 N& ~7 G6 K% t5 T" W# R
-N, --nicelevel int+ @' M, Y! t. K5 d6 t8 [( ?
This alters the priority of the process before starting it.+ A* Q3 U- E! J& E* ^
G2 z9 _( b8 W8 D7 @ -P, --procsched policy:priority
: f- v6 X2 u0 v- `' M This alters the process scheduler policy and priority of the process before starting it (since version 1.15.0). The priority can be optionally specified by
/ j' ?1 y; E- f) S appending a : followed by the value. The default priority is 0. The currently supported policy values are other, fifo and rr.
+ @6 {, k" D2 y" f; q6 h4 ~' |' b% \& i) x( k, E2 L
-I, --iosched class:priority
G3 [; o: L* { This alters the IO scheduler class and priority of the process before starting it (since version 1.15.0). The priority can be optionally specified by appending a, T: E* ~/ [' T2 H2 ^' J
: followed by the value. The default priority is 4, unless class is idle, then priority will always be 7. The currently supported values for class are idle, best-
6 X8 s$ a; k. d: q effort and real-time.
, L9 ^' l! c' P \$ h4 p8 C! C4 b4 x, c; o& y/ i
-k, --umask mask
/ p% p2 }' D$ \" a k- \ This sets the umask of the process before starting it (since version 1.13.22).3 c3 l8 ]& _; S Z. I
4 {0 I" Y0 F2 A+ d5 Q; K
-m, --make-pidfile9 Q. s* n& d ] H2 e3 O D' S
Used when starting a program that does not create its own pid file. This option will make start-stop-daemon create the file referenced with --pidfile and place
* z9 b5 U8 G* Y- e, `7 g0 I8 \ the pid into it just before executing the process. Note, the file will only be removed when stopping the program if --remove-pidfile is used. Note: This feature1 b; D" O- _) w& U! [) C- r( o
may not work in all cases. Most notably when the program being executed forks from its main process. Because of this, it is usually only useful when combined with$ Q% ~9 I" h, Z" T
the --background option.- f9 ^7 N$ \2 ?$ |3 {
' b2 R+ N1 [# O2 }( q2 m: ?. X |
