讲解光耦建模的文章,需要的可以看看!
: D4 D% X1 T- t& h8 l; V6 O& c' L' K- z8 O5 ` O
* B) d Q2 q; g; L% B# RModeling phototransistor optocouplersusing Pspice simulation software(基于PSPICE仿真软件的光电三极管建模)
- v, V) z8 j5 h- M$ \) u/ W$ M, r% u% U* a4 `! f
$ V- i: L) _, z6 ~8 P* s
Z m9 a- Q$ Z. P2 {) o: H- D
v; Q$ t% ]: ?8 c& ^* f+ ^lntroduction) N H4 s. ?' }) \3 W* H
引种- l( P+ q& M; \! d* S
PSPICE is a circuit simulation program that's used to pro-vide a reasonably detailed analysis of circuits containingactive components such as bipolar transistors, field ef-fect transistors, diodes, and op-amps. PSPICE can alsohelp characterize lumped components like resistors, ca-pacitors and inductors.+ o- x" q& a2 |; }; b
PSPICE是一个电路模拟程序,用于对包含双极晶体管、场效应晶体管、二极管和运算放大器等有源元件的电路进行合理的详细分析。PSPICE还可以帮助表征集中元件,如电阻器、快起搏器和电感器.' _6 C4 s9 q( g
PSPICE programs are comfortable with measure-ment parameters like Voltage and Current. However,when it comes to modeling optoelectronic componentsthe PSPICE program does not possess the capability toevaluate or simulate components with outputs mea-sured in radiometric or photometric units like Watts (w)or Lumens (lm), or other variables like optical intensity,radiant power,irradiance with unit measurements inmW/sr, mW/m2, lumens.
# R3 P& Y5 C% Z0 ^# w* R f# EPSPICE程序对电压和电流等测量参数很满意.然而,当涉及到光电元件建模时,PSpice程序不具备评估或模拟以美国瓦茨(W)或Lumens(Lm)等辐射或光度单位或其它变量如光学强度、辐射功率、单位测量的辐照度(mW/sr、mw/m2、lumens)来评估或模拟元件的能力。
. Y* k* @1 c" H( o! N9 b- eThis application note provides a guideline to modelphototransistor optocouplers with first order approxi-mation using PSPICE models." b9 u3 Y% w% j6 X Q
- A% [% [' M+ ]+ \5 g7 b% p7 }8 ^& t
$ c$ m+ T2 J3 U! d) M5 ?6 P7 y0 j
! k% P3 @0 o, t* t5 `; E6 s5 l' c
