本帖最后由 microzzw 于 2021-1-28 22:04 编辑 % Q9 a2 d4 J; M. v& {
% }% K I9 c- }( Z f& X
报错:ERROR: [Labtools 27-3412] Mismatch between the design programmed into the device 'xc7a100t' (JTAG device index = '0'
& T: T! J2 i O5 _3 ~% X and the probes file(s) 'xxx.ltx'.The hw_probe 'xx' in the probes file has port index '0'. This port location for the ILA core at location (uuid_4FAE2A1F27CF5763BD2630905069972B), does not support a data probe.- C$ [2 {- _9 X3 P; I9 j4 P* j
查找了很多资料都不得解,最后还是vivado自身提供的几点建议有用:# P/ v2 E: O- A* g( i R( h7 T
Resolution: , a* K/ L! d2 J! E
1) Ensure that the clock signal connected to the debug core and/or debug hub is clean and free-running.$ {" Z9 K$ [: P$ b. Y: y
2) Ensure that the clock connected to the debug core and/or debug hub meets all timing constraints.( p2 q1 Q$ ^. ]. m& ?0 v7 o6 P) h
3) Ensure that the JTAG clock frequency is 2.5x times slower than the frequency of the clock connected to your debug hub.( I. p6 O) U3 X6 B; a V$ r) o
+ C @/ l5 K2 j) y6 }2 E第一点是确保ILA的clock signal是free-running的,查资料大概就是自由振荡,像外部晶振提供的时钟是可以的,但对锁相环提供的$ D7 C e/ u# l6 _
时钟,由于要进入锁定状态才有稳定的时钟,所以可能不太行。所以就在我的代码里面将锁相环时钟改成了外部晶振时钟。5 S/ A9 K' s: x0 L5 v0 ^5 d
第二点由于功能需要直接忽略。
4 I; T! }( c* K! X5 Q- c& z/ P4 B第三点JTAG时钟频率比ILA时钟要慢2.5倍,我看了默认的JTAG时钟是15MHz(虽然我不知道JTAG时钟是什么?表征电脑与FPGA通信速率?),2 K" h3 c5 L0 K/ ]. ]; S
而我ILA的时钟只有几MHz,所以推测是这里出错了。所以就重开了open new target,在里面设置JTAG时钟为500k,报错解决。
6 b, X4 u7 H6 d3 r7 K. T& n+ E2 G+ c# K! Q+ N5 _/ T) I P
(28.18 KB, 下载次数: 5)
(36.06 KB, 下载次数: 4)
(36.06 KB, 下载次数: 2)
