用51通过MAX6675读取温度,并在1602上显示。
# V3 i- z5 t4 D7 e* s2 Y& B: q现在的程序只能显示开机读取的温度,温度变化后,不能显示在1602上,请大侠看看是程序什么地方出了问题。4 ^9 C2 a! @/ a5 \
, m1 j+ y5 E3 \1 N单片机源码:9 z# O1 l7 a1 P5 ^, R9 ?. D- t1 Z
#include <reg51.h>! Y5 e$ T0 h9 v* }2 N* @
#include <Intrins.h>1 L+ g1 i* h7 S3 G. {( Z3 w3 @
#include <LCD1602.H>
/ f1 ]! d/ q& G#include <math.H>
/ v' |! y% s1 q6 V4 u+ O- `0 h
* E$ q4 P0 A3 d _, P% W6 c
4 \$ F1 s9 t; {# u) W$ D1 }1 v+ }6 _- K" K! O/ w
3 B# | q9 G% ^# Y- B6 O0 J- `, X& a#define uchar unsigned char
; o# J5 u6 ]- ~6 r6 B#define uint unsigned int
! K8 B5 t2 ]; T5 J1 W& r. v9 ?% F3 p9 u7 X" {0 }
, e* I+ W9 P- Z
9 M& c$ s0 R# b
# V) u8 r* r# p1 t8 [% psbit MAX6675_SO=P1^0;1 v- G& @1 F' f% |9 u$ q
sbit MAX6675_SCK=P1^1;
" l; \% m" ] Z' @4 }sbit MAX6675_CS=P1^2; 5 @( V0 n2 S9 l+ x" b( |9 |8 H
/ k* i: G3 C! M( G: D m
4 o* ~# G4 ^4 h* o1 S4 q9 [% |
1 y3 N1 c- d: c2 O4 i" U3 O* b1 T1 \
" M0 r- k& h) L. i# \4 J/ v" j# E# {8 ~
( }8 e8 P9 z, G' l
bit ack,flag=0,flag1=0;: z9 d. ~) S& X' D0 @0 [
6 v. o5 K0 U7 D* ^, h3 e# Q3 i
3 w/ V/ t1 ]4 J4 e4 W$ i
uint tz;
2 I3 m8 Y* Y, C: S0 _int t_zhi=0;2 e, z8 Q9 U; P9 p
# A& C1 R1 E* L9 j; S, m, r. I: c" k1 B# N) `( ^, F x
6 b/ X, k, d' K* x. {4 u& I
* D9 X! Y" f! E; w8 i) j- o- i, c0 _char code keytab[]={0xEE,0xDE,0xBE,0x7E,0xED,0xDD,0xBD,0x7D,0xEB,0xDB,0xBB,0x7B,0xE7,0xD7,0xB7,0x77};
. G1 v U4 K. M+ K) U, wunsigned char code str3[]={" "};
+ s- d, X2 s. s2 D! z' kunsigned char data disdata[5];
2 i5 E6 k* Z) y0 k: p: h! u) n4 m+ G) ?# r5 _9 \
5 `- \0 q. t r+ [" Q: p- v) `6 n% p z' c- j+ P: M* n
: A2 J+ m' f9 j9 t8 C+ z$ a& i
1 M9 r" A$ {0 \" v& i) t- n
5 @- }+ K1 C$ G! o/ y2 U
* n' s/ ^+ n- }0 W
" y: h1 A4 E6 W6 v7 m
" S `+ \/ i/ N, t: ?# d; p
. l5 e$ S) X; H% w$ Cunsigned int ReadMAX6675() # J' _1 O1 C7 q2 N h
6 J2 A/ H1 k; K& a unsigned char count;
8 O. C; T. Q; g& Z* k unsigned int Value;' M) T6 t' J* o8 C2 `; y0 [
MAX6675_CS=0; " ~' O, o* k {0 g1 E2 i- c! w4 q8 @
MAX6675_SCK=0;& @. e4 q# ?* V- y% M- u! |
Value=0;
( ^) X# @ P; p/ Z, \) Q6 K v _nop_() ;_nop_();_nop_();_nop_();
. \% [7 |( ~$ _; B- Q1 L& \ for(count=0;count<16;count++)
/ X Y$ `. d; r3 N, d {7 G6 x$ B6 ~9 y; H
Value=Value<<1;
/ `' Q& B/ C; M; J0 Z) d% o0 } MAX6675_SCK=1; $ l q; c; L1 V* X
: O. x. m9 A- {6 |, Z% `$ {+ X H; a if(MAX6675_SO==1) * e* {3 A- g# H& [! s& \: i! P# B5 T
Value|=0x01; f' d& z3 F: l! G
MAX6675_SCK=0;
3 _ Q5 J2 R0 m) O3 d3 G }* e8 V( Q& C6 L2 s
MAX6675_CS=1; 3 k5 I; |! m( Z s f* v I: o! k
return Value;
+ { b7 n4 r. ]( D5 B* b}- y) R5 h* c2 i& i
! n6 u M) a$ B+ w: e* T
8 ~6 u4 C/ B3 Z+ y# P/ `, H/ Lunsigned int GetCurrentTemp(unsigned int CurrentValue) 1 O, D8 r% s) U/ _8 D; J. c
{0 F; i3 F; g \' b
unsigned int TempValue;% t" a6 P0 w, ~2 @
TempValue=CurrentValue;
+ k. r. {8 r2 C' a& v2 y3 r5 J4 F if(TempValue&0x8000) ; ^& B# i, m9 s8 v( r* O* }7 F" n
return 0;( D2 g9 z/ C. B1 ]9 o" s$ X
if(TempValue&0x0004) + y: C+ U! N/ ?2 G. N
return 1;
; J; f" J2 p' ]( \9 E}# _# K4 Q7 X+ L z: E0 Z5 H
7 b' U2 x7 i+ Q- j8 z4 r- i
1 I" t: q! [% ~) l; ` g6 ~9 O
void tempdisp() //ζèÖμÏÔê¾
2 X5 Q( q1 w/ U+ Q4 W{ unsigned char i;
( v: X$ r# ^8 i2 k; L unsigned int TempValue;
) ^0 _( |. ^! o0 X" ] unsigned int testD2;' ^/ T& X: y' ~1 F
int xiaoshu;/ o7 b6 x% t* K* g* a3 H1 f# l1 m
TempValue=ReadMAX6675();' J5 {& O# X5 j/ l# D2 S
testD2=GetCurrentTemp(TempValue);
) \7 y- [/ p) `4 p; d* a9 H5 ^ c TempValue=ReadMAX6675();
, P/ X- A. d% U0 E+ g# d TempValue&=0x7ff8;
$ f u8 ]) R' b" V# ~2 H/ X) G* K TempValue>>=3; 8 h2 k5 P/ p% ~
xiaoshu= (TempValue*1023.75/4095)*10-262;3 ~) Q( B6 o J1 v% k7 v8 z/ h: d
t_zhi=xiaoshu/10;9 A5 N) `+ r! U0 C0 C
disdata[0]=xiaoshu/10000+0x30;
5 T: I/ k0 J4 q t xiaoshu=xiaoshu%10000;
/ t3 Z# U: z) O$ d disdata[1]=xiaoshu/1000+0x30; 3 C+ p; r/ D, j" S* B
xiaoshu=xiaoshu%1000;
( p# h, ?( X, h5 V5 D, E' w- Z disdata[2]=xiaoshu/100+0x30; ( e) A$ W0 ~& p- ^
xiaoshu=xiaoshu%100;
" F$ ~( W& [8 ] disdata[3]=xiaoshu/10+0x30; + R8 F1 Q. B4 T6 G
xiaoshu=xiaoshu%10;
7 R3 X1 W) b8 Q- D( f9 y disdata[4]=xiaoshu/1+0x30; , E0 Y8 t4 A( U6 O0 }' O. i! n$ z
LCD_set_position(68);
1 E7 u* ^4 y) t v for(i=0;i<4;i++)
y3 Q# A/ T8 \ LCD_write_data(disdata); . ]9 s3 h* W4 c ]
LCD_write_data('.'); 1 F2 e4 v" Y, U9 K* ?9 R
LCD_write_data(disdata[4]); $ s0 q h& z0 f0 h0 Y( H6 d
LCD_write_data(0xDF); 6 _; O" R6 E9 F" A( S8 I
LCD_write_data(0x43); " [/ X+ l& J( o3 _
) H7 b( `6 O$ g% M$ s
% w( @9 x7 C' U4 ^$ @4 S9 r}
: t- `( B n6 F) @8 J% d" Z+ A' i; K' K; ]
m! |$ }. a! F6 Y0 }+ {3 M5 d7 E1 {/ b) g" P. a/ y. {7 l4 S
' }; Z7 }+ k. V
4 T1 P# ^- d6 {3 h* w# F- [5 y! Q) P0 `
6 N t; c% Y& J4 s. d- R# L
- c6 F4 f/ ~; U/ o7 b$ u& w2 W/ L
9 s. L+ e: [4 ^4 y( ]
& d/ e6 I1 q: x L* n( f; r! E1 c o2 \' ]3 _( I( W
void main()
1 i8 ~4 n$ [3 c9 k{
+ J% L8 x7 Q# U1 x8 e: _# l
1 K9 r( J' e) J( P$ K
) r* Y1 n7 ~0 c( ]( H# O; F+ N0 c; q+ V% z. U( I- s5 A0 b
2 O! n# r9 [& Z. n
LCD_initial();# a! D7 L1 {6 O! ]4 l1 h
LCD_cls();
4 ?( l2 c3 Z# r LCD_set_position(0);
4 j( m7 q0 \# H/ E3 z* |0 d //LCD_prints(str1); v6 N" |8 j) r0 Q( n8 A! j" S( d
LCD_set_position(3);. C9 d) _" v8 W1 T3 n3 ?
; w9 H6 a3 m0 {3 a# X* }6 Q
1 [+ P( J2 ]( \8 B7 \8 ^% F MAX6675_CS=1; 2 G q' a' Q: V2 b. @$ V
while(1)
( \+ _! Y7 P+ i+ I1 Z0 E7 ^) ^0 u {
4 W: M S; y; |2 l9 F4 T ReadMAX6675();* Y7 @. r% ]8 \/ z# X
GetCurrentTemp();
4 ]7 K+ G/ ?, q4 F) O8 }, A6 } tempdisp();4 J W1 ^1 {* [7 x) X- c! V
2 \+ p- o) w9 u% A
q1 b, C4 w6 E9 Z1 P, Q2 y. z7 u0 s/ _/ h. j. O7 b- q3 Z- ?- v
2 ]* m9 `$ M) U, G9 |7 w- Z( N
}# W5 B* i7 _/ I* o' |% ^
}7 k% R/ |7 h5 w% w A' R; o. B2 i
: l4 `5 s' e$ r! a
