用AM3352的板子,内核4.19,emmc1 不能使能8线! r: T" l3 G8 i# F- v$ d) y4 B. L
我看了很多贴子的log似乎都用的4线 驱动omap_hsmmc.c
0 r1 a8 C5 s4 L! b7 y. B&mmc2 {
# }# T7 Q3 s' a, u& } vmmc-supply = <&vmmcsd_fixed>;
- P1 `* y7 n$ I9 d$ a3 [# I# P pinctrl-names = "default";! o- j Z/ m9 }. S6 O) k
pinctrl-0 = <&emmc_pins>;
* y5 l5 ~: A9 v5 \/ p- ? bus-width = <8>;
' \* x3 z: p% M2 }8 Q7 A& l status = "okay"; M& R1 s9 K- O8 v+ k
ti,non-removable;
. S1 N" l+ o$ h$ ?; Z" ^( s};
1 e- G# b: y0 V, ]6 S2 z: J. O. o* y d4 ^: \1 E
# ?" J. Q* F, D信息:# Y3 t6 H* X- B/ [( a
root:~# cat /sys/kernel/debug/mmc1/ios+ r7 i) d, O7 k( O& j& \$ h
clock: 52000000 Hz
( V' V: K$ X4 O7 i9 N3 Q2 Pvdd: 20 (3.2 ~ 3.3 V)7 y7 H7 ^1 f: a. G1 ]: {& w
bus mode: 2 (push-pull)' G" f5 Q+ w# q/ @: t5 ~! w8 ^/ w' X; r- N
chip select: 0 (don't care)0 h! e* J. B9 e) O5 f$ D. P; L
power mode: 2 (on), T" N; {0 B: o% r' v Y
bus width: 2 (4 bits)9 ?4 z% O5 }* K$ j5 R
timing spec: 1 (mmc high-speed)
% M6 ]& J' _2 B6 c" M7 C8 N5 b, z9 A/ G. Z6 e7 l
9 ?5 S' Z0 {5 Z+ v7 U$ e/ }/ S
1 m+ w T* T/ }2 U) e# Q) ]0 dlog:" G- ]7 Y3 y' E( N
[ 1.662924] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 100 kHz3 ~; \0 d0 R2 {
[ 1.672359] omap_hsmmc 481d8000.mmc: omap_hsmmc_set_bus_width ios->timing=1 ios->bus_width=07 L5 K/ l# X" M
[ 1.680990] omap_hsmmc 481d8000.mmc: Set clock to 400000Hz
" e' R* R" p7 d4 l/ I: s[ 1.686838] omap_hsmmc 481d8000.mmc: omap_hsmmc_set_bus_width ios->timing=1 ios->bus_width=0" f1 Z- S5 H6 q) {2 t; t0 v. h* v
[ 1.695431] omap_hsmmc 481d8000.mmc: Set clock to 52000000Hz' x; s4 |$ I' g0 i+ q K
[ 1.701433] omap_hsmmc 481d8000.mmc: omap_hsmmc_set_bus_width ios->timing=1 ios->bus_width=3
% s' D' A) ?$ p) t[ 1.710020] omap_hsmmc 481d8000.mmc: Set clock to 52000000Hz/ E8 K- x/ \) w+ Z6 M. y
[ 1.716069] mmc1: switch to bus width 8 faiLED0 T$ [- o0 K7 P! B# o
[ 1.720589] omap_hsmmc 481d8000.mmc: omap_hsmmc_set_bus_width ios->timing=1 ios->bus_width=2
1 _9 o; {* P: }& g5 j0 y8 b[ 1.729175] omap_hsmmc 481d8000.mmc: Set clock to 52000000Hz% `* ]+ {0 }0 p( L9 D! ^6 l
[ 1.735710] mmc1: new high speed MMC card at address 0001
/ b$ v2 s& O( ]% P[ 1.742154] mmcblk1: mmc1:0001 004G60 3.69 GiB
/ d# u; I: S; ]: q[ 1.747295] mmcblk1boot0: mmc1:0001 004G60 partition 1 2.00 MiB. o3 B( t: L% N5 C5 W6 _- s
[ 1.753768] mmcblk1boot1: mmc1:0001 004G60 partition 2 2.00 MiB' C) I( Y R8 y: {4 f
[ 1.759963] mmcblk1rpmb: mmc1:0001 004G60 partition 3 512 KiB, chardev (244:0)
# F, P: O+ Z8 J4 G: a |
