TA的每日心情 | 开心 2021-8-6 15:17 |
签到天数: 123 天 [LV.7]常住居民III
仿真 SFP 信号在16层 板子上 VIA 及隔离焊盘+ 伴地孔 仿真报错 不能得到 仿真结果 提示如下 烦请高手指教 谢谢$ P5 C; p/ }& Y
Starting FEM simulation.' F3 S4 W* K# m4 i
Setting environment for using simulator engine2 v9 c' q8 |' l% Q
Setting EMPROHOME to C:\Program Files\Keysight\ADS2020\fem\2020.00\win32_64\bin\) g0 ?! K8 M( H7 z' l9 S- B
Setting PYTHONHOME to C:\Program Files\Keysight\ADS2020\fem\2020.00\win32_64\bin\tools\win32\python
+ o6 i1 s7 Z. |& ?7 x C( rLicense checkout started
1 U/ O# e( l4 VLicense checkout completed# z8 v# E( g, }2 c) [ n9 ]
( n" L7 t+ `" O( r8 ~# G* x
CONFIGURATION VARIABLES WITH NON-DEFAULT VALUES:- x: c7 W8 R9 h4 b: s4 o$ N' Q
Actual Default9 k' L3 m- I) d5 S( E' a6 c5 H
3 E7 y- H% C' _/ T6 ?% [; _7 x4 S" Z$ a& m* \8 W& m% k
FEM engine : 370.000 2019-07-17
( X: S. `% b/ B6 O" \: ^4 v& x; cFEM solver : 1.2.03 y$ r; U0 v4 |1 z0 q S8 a9 `
AFS : 3.1.1
1 ]" M) |/ x2 M7 v" Y; n/ t+ q7 OMachine : DESKTOP-R8LHUK0
9 K! V4 e z" qMaximum number of threads : Automatic; c4 I6 Q( U) Q- S6 g
Maximum number of solvers : 1" `8 V% o# \/ {: I! T0 S$ M
Date : Tue Nov 17 13:59:55 2020
; M2 y5 D6 w0 K4 j& ]8 TDesign : D:\fangzhen\fangzheng\MG22_VIA\MG22_VIA_wrk\simulation\viad\%V%I%A_%S%F%P_%T%X\000001\emds_dsn\design- @+ |9 ?( \ h: W4 t2 L5 O( U* f
FEM Mesher: 2.0.3
1 l/ P9 z1 K+ x! E
?4 n' Q# m: w! B' VAutomatic initial target mesh size: 5.00e+00 mm
# L: ?5 c: a% q" \, {& J
# N1 t/ N$ ^! E: q6 T4 l4 xAutomatic conductor meshing summary:6 F' h* \5 r2 J! V3 @& X6 ~
7 y. T6 O2 p) O Port endpoint at (-1.7018 mm, 0.14732 mm, 1.49885 mm) : 128 mm estimated, 128 mm used
* t# j" ~/ A7 k# v4 M4 P" n Port endpoint at (-1.7018 mm, 0.14732 mm, 1.61303 mm) : 0.152 mm estimated, 0.152 mm used
& _1 Q" Y7 X3 X/ ~& u Port endpoint at (-1.7018 mm, -0.14732 mm, 1.49885 mm) : 128 mm estimated, 128 mm used5 ^; |1 Y1 V6 I* W+ {8 v; o
Port endpoint at (-1.7018 mm, -0.14732 mm, 1.61303 mm) : 0.152 mm estimated, 0.152 mm used: ] [# _9 X- e5 J
Port endpoint at (63.8556 mm, 0.1524 mm, 1.49885 mm) : 128 mm estimated
# R& U7 `& j% Y# `8 i. j Port endpoint at (63.8556 mm, 0.1524 mm, 1.4036 mm) : 0.124 mm estimated6 h4 b( T2 o0 N9 T
Port endpoint at (63.8556 mm, -0.1524 mm, 1.49885 mm) : 128 mm estimated
0 q5 D7 X4 n! w( d' w$ _/ V Port endpoint at (63.8556 mm, -0.1524 mm, 1.4036 mm) : 0.124 mm estimated) a, e7 r: V3 [2 a- d* j
emds_mesher failed to complete successfully:
) g. Y6 \/ o/ mOne or more faces failed to mesh: aborting.2 h; D* }8 V/ j0 N
Please load the file design_failed_faces.sat in D:\fangzhen\fangzheng\MG22_VIA\MG22_VIA_wrk\simulation\viad\%V%I%A_%S%F%P_%T%X\000001\emds_dsn\design to examine the areas which failed to mesh& s1 g) G; G3 D! O1 t
Please examine the geometry near the failed faces. Look for:
" s6 z3 F/ e1 i small gaps between objects- N3 L4 w4 Z# W7 s
illegal geometries using the Geometry Inspection command& B0 n0 B( q: _4 ? D, X- o
Tips:8 O3 v* m, v) \: _
Isolate the parts which are causing the mesh failure by excluding other parts from the mesh incrementally.
# f% m8 Y# q& y0 F& \, U1 ^ Z1 G Simplify the parts which are not meshing by using mesh priority instead of boolean operations
1 }1 V# w ] z* @: [! F3 J6 e(<type 'exceptions.Exception'>, Exception('3d mesh generation failed with errors. Check the error message for details. ',), <traceback object at 0x0000000006C1C308>) File "C:\Program Files\Keysight\ADS2020\fem\2020.00\win32_64\bin\empro\toolkit\engine_support\fem\state_machine\x_emds.py", line 1094, in mesh$ x" K, v, T- A( f- r
self.callEmdsMesher('level'+str(currentLevel+1))
$ F8 ^' O' J j# c j. p2 G( V File "C:\Program Files\Keysight\ADS2020\fem\2020.00\win32_64\bin\empro\toolkit\engine_support\fem\state_machine\x_emds.py", line 1053, in callEmdsMesher
3 N8 u& p/ a0 t9 F* R6 i0 `9 g self.genericEmdsCall_2("mesh", command)$ g% m% V, f" \. P) c
File "C:\Program Files\Keysight\ADS2020\fem\2020.00\win32_64\bin\empro\toolkit\engine_support\fem\state_machine\x_emds.py", line 1340, in genericEmdsCall_2" h# d; R! k/ U
raise Exception(message)0 T" b' z# P1 L
\& n9 m, ~" t9 Z' U1 NTraceback (most recent call last):
4 q/ W4 H* A/ k( q3 P( X File "C:\Program Files\Keysight\ADS2020\fem\2020.00\win32_64\bin\empro\toolkit\engine_support\fem\state_machine\x_emds.py", line 708, in simulate9 z+ S9 i+ G$ I8 `4 l7 M, i) `
self.simulate3D()5 a( ^' Q1 y$ a- ], } I+ X+ J
File "C:\Program Files\Keysight\ADS2020\fem\2020.00\win32_64\bin\empro\toolkit\engine_support\fem\state_machine\x_emds.py", line 459, in simulate3D, B) J6 d# e7 h8 G. F9 y
self.simulate3D_refine()
6 n, B0 N+ d& x- h7 g! h File "C:\Program Files\Keysight\ADS2020\fem\2020.00\win32_64\bin\empro\toolkit\engine_support\fem\state_machine\x_emds.py", line 585, in simulate3D_refine
/ u% Z9 {+ [6 L* }) |7 z self.initialSolve()
0 ~- |# w& |7 e5 H6 ?4 t6 z File "C:\Program Files\Keysight\ADS2020\fem\2020.00\win32_64\bin\empro\toolkit\engine_support\fem\state_machine\x_emds.py", line 281, in initialSolve
" {8 W) L* k' O! K- [* v self.mesh(resultDir,resultDir, []); # initial meshing
% R+ Z, x' M5 K5 y. l4 Z( N9 \: k File "C:\Program Files\Keysight\ADS2020\fem\2020.00\win32_64\bin\empro\toolkit\engine_support\fem\state_machine\x_emds.py", line 1094, in mesh1 x) Z' N z/ |. ^
self.callEmdsMesher('level'+str(currentLevel+1))0 Y$ q, W) J* B7 k6 S' u$ s8 d( @
+ e% v8 E" U% m# T! F self.genericEmdsCall_2("mesh", command)
% H0 i: r( K4 T" H7 p+ Y# l; M File "C:\Program Files\Keysight\ADS2020\fem\2020.00\win32_64\bin\empro\toolkit\engine_support\fem\state_machine\x_emds.py", line 1340, in genericEmdsCall_2# k' a: C. t F, `' d! O: Z; S1 H
raise Exception(message)" W9 r' v7 d) v1 t; E( N q& _
Exception: 3d mesh generation failed with errors. Check the error message for details. ( t0 f8 n% s7 W( L! h
------------------------------------------------( H3 X0 }' M" r5 t$ Q: X4 ^2 A
DISTRIBUTION SUMMARY:% o8 c7 _2 X5 M. S' L: I& X
V: |8 w" A. g9 P: J) x7 E& y. m/ e
8 F6 u. K2 a& U; H: h( ^6 K====================
2 e$ G" m( y R- O3 ]$ n0 P" c Q: n7 D# O. J
Simulation did not succeed.
( ~6 _/ L" O! B8 M% F; P4 T5 m5 \' X- z, y: b T
! V5 m- O; b4 R2 v Total Elapsed Time = 0:12:583 q3 t- r1 I/ H5 s$ h) Z' {! l
& a% K; E3 K4 V$ x, uSimulation results can not be reused
& s$ w8 L7 z+ ^; }
1 |7 c" s3 k# k0 W |
