单片机+1602加电位器,调节,和原来一样只有背光亮
7 E+ @' j$ y2 W
. @" ]: ? I8 M7 e: V2 i
0 `' u0 z9 @0 b& Z. {7 Fvoid LCD_write_data(uchar dat)% E8 d. R* e: E! V7 R
4 I% l3 n$ }/ o8 ]1 N* ^, S LCD_DB=dat;
0 B$ i- Q2 U' \; ] p1 | LCD_RS=1;//数据寄存器
7 @4 b6 s% j; L, h# ^& h% k LCD_RW=0;//写入数据: S/ [: v9 j/ p; U0 r
LCD_E=1;
( i% c2 g( i) ~ LCD_E=0;+ x$ l# z X L: C+ {2 L
delay_lcd(1);//等待程序执行完毕. B3 p5 h& ~5 Z! f! }% N
}$ V0 m9 ^, I1 n0 _1 U
//初始化函数- A' W/ ?! X0 ?7 F+ Q
void LCD_init(void)5 L' a% O7 S" X5 }+ [) M+ j* h5 \
4 Y0 N# F* t4 A; adelay_lcd(200);
# u2 @7 Y m H! W/ U1 c$ eLCD_write_command(0x38);//设置8位格式,2行,5*7* \( n) y! W) j
delay_lcd(200);
) X1 q9 W) ]0 ~1 ^LCD_write_command(0x38);//设置8位格式,2行,5*7* ^& ^0 C, l A' F% C4 z4 J4 `# o% ]
delay_lcd(200);
, ]0 C5 T- C+ ?4 m( [1 x: V! VLCD_write_command(0x38);//设置8位格式,2行,5*7
0 y8 u' o2 r3 [+ X9 u( a3 Xdelay_lcd(200);3 p& M% o* `) o
LCD_write_command(0x0F);//整体显示,关光标,不闪烁6 x4 {4 u5 @2 v
delay_lcd(200);
1 }/ A J( q: c* }LCD_write_command(0x06);//设定输入方式,增量不移位
* U0 e6 U2 e! edelay_lcd(200);5 X, G* e: Y1 d# l' Q9 h) D
LCD_write_command(0x01);//清屏显示2 O: e/ m; F1 Y/ L& I
delay_lcd(200);6 g% U4 T( I" @" h; i
}9 n8 z5 y9 x- A: h7 t' U+ W& W
//光标定位0 k9 H* L( s5 D" ]0 x2 b3 `5 f
void gotoxy(uchar x,uchar y)2 u0 b9 o- _9 {
{uchar address;: ^7 i* X( {9 ?0 |7 _
if(y==1)
3 w: O8 k! K# T# b6 [6 ? address=0x80+x;+ C; `8 a- @# d/ u$ n
else; ^! O* q9 V2 @1 K* u
address=0xc0+x;+ t9 ^1 }7 x8 S1 O; o0 _# T
LCD_write_command(address);
% x! ?/ t% Y3 P H& o- z% T' j}8 A! w# h- q( c2 J
//显示一个字符串0 _2 h) Y6 r9 ]" e- K9 n2 s, } q% q
void LCD_display(uchar *dat)
/ j" d2 W- |# g+ b" I) `{
! l2 c w5 _/ W3 t while(*dat!='\0')
( {5 R9 j2 H8 E2 M j6 i v/ _ {: U- L- H' W6 K. ^
LCD_write_data(*dat);7 e3 I7 B% T8 Z6 O' L3 b
dat++;4 V: z5 Z6 L) d+ o/ Q! E3 }
}, Y- ^; Q* v: ?4 y1 d% F$ g
9 H2 x# h: [3 W2 p/ q4 a//指定位置显示字符串
7 K$ L6 V9 c/ N4 A# U3 A% Q4 evoid LCD_display_char(uchar x,uchar y,uchar *dat); {. T- e4 T- Q, o, p
{ e- f$ r4 }- j- K+ v
gotoxy(x,y);+ b' N+ J9 a& g" K& c% \
LCD_display(dat);
* s2 k# m9 ^ d' V1 J4 c% e$ ~}$ t" z" W8 W6 J% P
