0 t$ [/ z4 g3 I5 ^, B环境描述:9 S/ w* Y) A5 U7 H$ q( g
) |$ u% P; o# E9 p1. VM Ware7.1下安装Linux,各种版本均可。( f, Y: ?- c1 S9 ~# C
6 X$ N5 _0 G% T: }3 F Q' E) F0 N
2. Apache HTTP Server 2.2.17 for Linux。& ?, R" D2 H9 F% J" @- C% K5 I! W
' z0 y/ \$ E/ c+ k7 N" _) e
关键步骤:# Z7 N) b4 J6 b v. J
" G0 T# D. `0 H( T. Q/ ^4 W1. 将Apache压缩包httpd-2.2.17.tar.bz2存放到root目录。
8 A9 }' P% Z; Y" U
o% ]& |2 K% a U, N) l2. 打开命令窗口,依次输入以下命令,每条命令需要按回车执行。! k7 l, `7 W4 U6 s% A
/ X8 J+ n( v0 V! z6 c! zview plaincopy to clipboardprint?- D& L% p6 w+ N8 Y
#cd # ^3 z: F L; |7 U; s
解压Apache安装包 0 R7 A' h8 l- _: y% T: g7 V
如果是gz文件,将jxvf替换成zxvf + E Y7 C' X; B+ O6 T
#tar -jxvf httpd-2.2.17.tar.bz2
. f( P8 K- f- G# j0 P#cd httpd-2.2.17
; F; Q: d% D3 n/ G* y/ @ , W) @0 `; y3 |. X8 X
编译和安装apr
$ _: u% x( {. O- {! R& i6 i#cd srclib/apr
! x7 j( w1 w& q. M; Y; h#./configure
" y x7 o I1 J) U; v默认安装在usr/local/bin目录下,如果要指定安装目录,可以使用如下格式
2 W0 q+ g! t8 @2 j#./configure --prefix=/usr/local/apr ; H: j# P& ^( S2 ^& a7 k
#make
; e% n1 o$ F" L0 R" n, \. I#make install ; A* X, N* [% B3 B: G, A
4 ]- d+ H% {7 n7 ?: w7 x! W5 r* J p' L编译和安装apr-util 0 \, p( o( m5 P+ B
#cd ../apr-util 4 q; h: s* v" j: h9 Z0 m" v. w, \
#./configure --with-apr=/usr/local/apr
8 ]! D3 j* f5 H, y) Y. E* N2 R#make 8 g6 _, [! N6 F
#make install
# w6 ^3 ^7 ?4 O X
9 U( J/ @5 i; J- X" i" B最后编译和安装apache
. N7 V+ E2 ?; u/ `" A#cd ../../ & S7 G; M8 ]; N& E# y( z" ]3 x
#./configure --enable-so # L3 b( g2 r0 P
#make
% [$ p; f0 T$ F1 X#make install
?. ^- i3 p9 e- [9 O / j6 ~/ E, c$ z6 w* y6 G) ^ K7 Q# T
启动Apache服务 # D3 R, ?7 Z2 b5 \, {( S6 s
#/usr/local/apache2/bin/apachectl start & O, ~" F- c( B
#cd5 Q F! l4 K9 U
解压Apache安装包
. J; @% {0 }' t如果是gz文件,将jxvf替换成zxvf
* B: t. M' q- h" v, ?#tar -jxvf httpd-2.2.17.tar.bz2
! ?5 q' e. x q' P/ a#cd httpd-2.2.17
& b5 R* G+ T3 D% e2 m; {; I
6 e# P: R2 Y4 }2 d' S' R编译和安装apr
0 u, n" ^* m2 M, M" G% W! n% b#cd srclib/apr, _6 l! s- b* N# y8 A& U h! p
#./configure4 X1 f/ q& @. N* H1 s
* b- n/ h/ u5 S5 i1 m/ h: P" ?#./configure --prefix=/usr/local/apr
' ]& J! y1 w6 R4 P5 Q" K5 i#make
5 K8 J; e+ P4 e% I4 z8 \#make install
. v7 W. B `8 {$ ?3 ]9 P9 `3 \# X% `
编译和安装apr-util
+ M, w1 e- @0 L0 v- W6 R#cd ../apr-util
X6 _+ t+ P7 [! `#./configure --with-apr=/usr/local/apr
: @8 S! ]; z: Z0 A1 o# T#make
) G3 n* w/ O. j2 p2 Z. K/ |#make install
( k1 L8 F3 H4 ^- V
. h% D# @# j& l! r最后编译和安装apache
6 s6 H3 |$ C0 l: X( @#cd ../../
. q7 Z* ]# h) b# V#./configure --enable-so
0 a0 \2 f& J/ r4 M& Q' z#make
9 M9 @8 @" M7 E: u. |4 C#make install; l3 B( S* H2 r3 F' c; B" j
0 x) f1 }0 }0 z: e% w启动Apache服务# W$ q- k6 j: n/ }* M
3 n L7 O* s F& Y0 u
& i( W* I, h* \8 n$ d p; t最后在IE中访问http://localhost。
- n5 W; x+ E) P$ d* B C2 O9 G" k! T4 N
将Apache设置为系统自启动项 o# d2 v& v8 Q! M
: A9 \/ U, A6 m修改etc/rc.d/rc.local文件如下:(红色字体部分)
5 F" p& ?0 N$ M+ t( r7 M; J R
# F5 k0 d; u9 ]5 ?, s/ [#!/bin/sh
, z& s0 y/ e% I2 v' Y* l: E* i#" a# x- m- j' A
# This script will be executed *after* all the other init scripts.1 c! E3 I/ f5 S+ E$ K! w5 I
# You can put your own initialization stuff in here if you don't0 k5 K/ b& _1 z" E! A
# want to do the full Sys V style init stuff.0 i- ~" K/ S$ k! u
: |! u& {- ^: e5 b# b1 j) f, X
touch /var/lock/subsys/local
/ Z7 n! T- R0 u/root/firewall3 @, }" L" ?; w+ ?: b# y: l+ h
startup.sh
$ b* C* \/ o7 H& Y& V3 m/usr/local/apache2/bin/apachectl start |
