查看: 4731|回复: 3
pads2007环境变量出错,有提示如图
发表于 2010-11-30 13:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
 楼主| 发表于 2010-11-30 13:09 | 只看该作者
如图
 楼主| 发表于 2010-11-30 13:45 | 只看该作者
The following FLEXlm errors were found:7 U, n: g( g7 N  y
    Server C:\flexlm\license.dat: Invalid host.9 L  T6 ~, [. T1 S
The hostid of this system does not match the hostid: I2 t2 b2 B" q
specified in the license file.( u0 f+ X" C* n; V+ d" g
Feature:       mgc_s
; V9 f' {- {. k, ~* x6 r3 BHostid:        0000000000009 W" n% l: n1 L' j1 [8 n3 V7 [
License path:  C:\flexlm\license.dat) v* R: G' u* R& n
FLEXnet Licensing error:-9,57) Q3 Z0 Y% d! {' Z
For further information, refer to the FLEXnet Licensing End User Guide,1 F& h& |1 k: `
available at "www.macrovision.com"., k; x6 S8 N4 Q7 E* e, j- q% ?0 p
* q( M7 f: I$ V. j6 C    Server C:\flexlm\license.dat: Invalid host.7 Y. z' x! L* B8 ~& g
  A- w2 @/ C/ y specified in the license file.
% C$ I% ?% q5 {Feature:       mentorall_s2 ^0 j5 [( Q4 O  T' q, _' P# ]
Hostid:        000000000000' r# |, w! y3 {! s. ?2 \. l! L
& i. Z. E3 P% w7 W1 Y( L/ i* SFLEXnet Licensing error:-9,57/ y, N9 e9 h* f) G9 T
0 i8 B# {& Q: c1 F% uavailable at "www.macrovision.com".
# `! j( F; M# s3 e5 Q* \* d$ X3 n+ \7 P. o7 a* O  P4 @/ S
/ O9 x/ H. B) Z4 Q! M  Z, I The hostid of this system does not match the hostid
) M) a9 f# ~; a( d specified in the license file.
% V, P9 e" k' N- O4 g6 d: JFeature:       bsdall_c6 a4 K/ L1 R' r
Hostid:        000000000000, k  R# ?" a, Q* c7 k" y4 {% D
  a/ E4 ^2 L$ N2 z- D: B. M$ xFLEXnet Licensing error:-9,57( S* g5 G4 P1 N5 I4 S/ i1 t
For further information, refer to the FLEXnet Licensing End User Guide," b( @. G# Y' Y2 N* v1 \& B* g
3 V& s2 i; C) [: B" b6 t: @8 [; W: F+ h5 u( T- [; o
    Server c:\flexlm\license.dat: Invalid host.6 A# n/ Q! j0 w" D" m+ w
The hostid of this system does not match the hostid$ G* M# H, `/ j+ c+ [
+ I- s3 G! H" {8 z4 k) jFeature:       mgc_s% \1 k3 _7 A  X1 e6 \* ^  D1 U
; j) Y! A6 f* ]+ b; K4 `License path:  c:\flexlm\license.dat
7 }2 G$ p% M* [( V( J: @FLEXnet Licensing error:-9,57) a4 h3 v" H+ U- k% u" G" z: i
For further information, refer to the FLEXnet Licensing End User Guide," R" z3 {% Q+ }( r3 Q
available at "www.macrovision.com".9 C" I( Z: l$ f; ^  X6 d! N* f2 D4 y( F
% m  W/ l& N; X2 B    Server c:\flexlm\license.dat: Invalid host.% f1 h. o! l' @7 |3 _
5 X! \5 q. H- {* F7 E specified in the license file.. J$ F$ }2 L1 F9 q" K& K6 F2 |3 B
  `: g9 V6 v3 Q2 @/ I6 T. y- EHostid:        000000000000
+ ~7 U  l: G/ o" QLicense path:  c:\flexlm\license.dat7 R* s/ w7 U: ]: m
FLEXnet Licensing error:-9,57% P' Z% M: U' p$ \% W! g
: ~  f3 a, J/ ^  t' q$ [available at "www.macrovision.com".
" ?) C% C; M% b/ C, W  w: V/ O+ f
    Server c:\flexlm\license.dat: Invalid host.% G! M* o/ b; a
' L* A5 l- a+ |. M2 k/ A6 ?% M specified in the license file.
6 y7 {* ^! {& b- _5 ]' U/ l! u) v$ bFeature:       bsdall_c
0 o6 v( r: d) B8 I3 D* ^Hostid:        000000000000& Q0 ]: V3 r3 C* I! l" [! U
0 {+ y8 m8 T4 o* c  O, jFLEXnet Licensing error:-9,57- n- }! D- g- |- F! Q% G
$ _1 G4 W# R$ _% pavailable at "www.macrovision.com".5 t2 S; c) C0 A2 m5 W& `
; V) O& g2 s5 I
    Server C:\Cadence\SPB_15.5.1\IntelliCAD 4\\cadopia.dat: No such feature exists.
( |7 V& q5 }$ ~3 aFeature:       pwrshell' x" m: `5 w. O$ F0 h
License path:  C:\Cadence\SPB_15.5.1\IntelliCAD 4\\cadopia.dat
" {7 [' t2 f4 G0 ?! e1 kFLEXnet Licensing error:-5,357
, G8 F. o( x1 Z6 s* r* lFor further information, refer to the FLEXnet Licensing End User Guide,. f' l0 \# J  f9 f2 b& G5 u
available at "www.macrovision.com".  H- g9 \# n4 ~0 Q
9 M' `. h; J) B4 d3 F
    Server c:\flexlm\license.dat: Invalid host.! |& a1 c/ R0 Q2 t
The hostid of this system does not match the hostid* T+ i# a; q9 {
specified in the license file.( v8 i6 _) y' H" J- Z5 s( p& H  c1 u5 P
Feature:       mgc_s/ T% o; N6 v5 u2 J
Hostid:        000000000000$ E6 e/ A6 U4 f! G% J* F
License path:  c:\flexlm\license.dat6 {) P/ p3 p$ v: D
8 A; |3 G2 F& w9 N7 L8 O! s/ eFor further information, refer to the FLEXnet Licensing End User Guide,$ W* u: d3 A( q( F0 M6 t
/ e# N5 l5 K3 \/ f
6 E# Y# a9 A: _" h/ I. s5 Q    Server c:\flexlm\license.dat: Invalid host.7 b) D$ F" t7 B  o$ a
1 X5 O, R; ]1 Z0 h" |5 V0 c specified in the license file.
6 a8 L; ~( A3 w+ e* iFeature:       mentorall_s- C% W8 a0 S; C3 T0 E4 @% i
2 D- l# N4 ?4 W% ]5 d5 bLicense path:  c:\flexlm\license.dat
/ h0 P3 k! t0 Q% \FLEXnet Licensing error:-9,57
# K7 i. A9 J' SFor further information, refer to the FLEXnet Licensing End User Guide,! B* z( e6 D7 m
available at "www.macrovision.com".- y+ L* e+ g  f+ \: M% A6 e
5 y+ ^7 e5 F& P0 l
    Server c:\flexlm\license.dat: Invalid host./ r! D% a8 h! ~0 F
The hostid of this system does not match the hostid; l7 @: R' x& s
- i( ]+ r) M" }- {3 m0 zFeature:       bsdall_c6 c; r7 Y4 `. m; l, q5 B) ~
Hostid:        000000000000/ K* S2 h; M4 T- z
7 C) s! }5 {& Y5 `* J* k: `7 bFLEXnet Licensing error:-9,57
/ B' b5 ?/ w$ E$ j; [# e& ^For further information, refer to the FLEXnet Licensing End User Guide,& O9 {+ v6 X8 q$ F4 G2 D
available at "www.macrovision.com".: j% G+ ]9 L2 h2 u" Q" i* q
8 s) ?/ q; x& x    Server C:\flexlm\license.dat: Invalid host.7 B& A6 N" \) t, r; E- B
The hostid of this system does not match the hostid: S7 B3 z2 r' S/ B7 B
( T; D7 K8 o6 B9 U, Z- \) OFeature:       mgc_s6 M, Y% q# R& g" I* Z; R
( w2 a* ^+ `, U% {6 K* [License path:  C:\flexlm\license.dat% J2 i$ @* D1 I) h2 V
FLEXnet Licensing error:-9,57- O! N  I6 k- }( z: k* y3 N
For further information, refer to the FLEXnet Licensing End User Guide,( `& ]( G5 @3 U8 S. X
  u5 f7 t5 }& P+ O  {; n* Y. b1 k7 }. I  F' ?! W) u
: [- C& T  i0 C. I The hostid of this system does not match the hostid
2 T: ]& R# V5 U$ C2 G% \9 K specified in the license file.
' h. [4 `$ _2 C# [  K7 @5 \Feature:       mentorall_s( H1 Q: Q: [. V  ~& f
Hostid:        000000000000( P. e, J3 k# U" ]7 Q' x
# `+ L) u% ^: Q. M) Z: Y  yFLEXnet Licensing error:-9,57
5 M1 O/ }- M2 p: \+ M0 vFor further information, refer to the FLEXnet Licensing End User Guide,
* E) K' a7 [- G% c# Y, `- x5 javailable at "www.macrovision.com".' K( Q3 o0 m, O* f4 Y4 v
* F2 q% [, m2 F0 W, m    Server C:\flexlm\license.dat: Invalid host.  y7 p% c; B3 I, W; \# l
. z& ]) S" `  Z. l2 W# n' w% v specified in the license file.; i( h, z7 j& j; z
Feature:       bsdall_c
' y' w, D' O* ~3 I4 b4 K, w* WHostid:        000000000000! I/ S5 Q) q  W
License path:  C:\flexlm\license.dat9 F* I" j+ s" _
3 y2 t7 b; K/ P4 M. E% {4 aFor further information, refer to the FLEXnet Licensing End User Guide,
/ q' }8 f5 Z/ V/ f( bavailable at "www.macrovision.com".
' y& Q! ?, G1 P: l! L' U. i! p" Z, V, R: r
发表于 2019-11-12 10:24 | 只看该作者
WIN10也是提示这样的错误!
GMT+8, 2025-8-21 19:17 , Processed in 0.140625 second(s), 26 queries , Gzip On.
