查看: 270|回复: 2
Cortex-M/R 内核启动流程之执行阶段
发表于 2020-9-17 14:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
执行阶段
  The software of an embedded application is typically implemented as a loop which is either interrupt-driven or uses polling for controlling external interaction or internal events. For an interrupt-driven system, the interrupts are typically initialized at the beginning of the main function.嵌入式应用程序的软件通常实现为循环,该循环可以是中断驱动的,也可以使用轮询来控制外部交互或内部事件。 对于中断驱动的系统,中断通常在主函数的开头初始化。
, o1 \7 t% m3 N0 L. x0 j4 b) ^: T6 x/ M  In a system with real-time behavior and where responsiveness is critical, a multi-task system might be required. This means that your application software should be complemented with a real-time operating system. In this case, the RTOS and the different tasks must also be initialized at the beginning of the main function. 在具有实时行为且响应性至关重要的系统中,可能需要多任务系统。 这意味着您的应用程序软件应该配备实时操作系统。 在这种情况下,还必须在main函数的开头初始化RTOS和不同的任务。
% f; [7 d: R. V7 N  J3 G
发表于 2020-9-17 15:46 | 只看该作者
发表于 2020-9-18 13:39 | 只看该作者
GMT+8, 2025-11-24 23:49 , Processed in 0.140625 second(s), 23 queries , Gzip On.
