[url=]CPU[/url]7 `& M$ l, b! g0 z7 W( J$ C
| TI 双核TMS320F28377D/单核TMS320F28377S,主频200MHz,pin to pin兼容双核TMS320F28379D/单核TMS320F28379S
! E& B" I$ N$ `9 z6 v" c3 a, z |
ROM
" o- U: _: S; U | 单核:32Kx 16bit Boot-Rom/Secure-Rom,双核:2x 32Kx 16bit Boot-Rom/Secure-Rom
' {/ B) c6 U4 m& |% ~; S+ b9 ~ |
NOR FLASH( r+ T' ?) [ x
| 片内1MByte,外扩512Kx 16bit NOR FLASH
: t1 T- n( q: B4 `, g2 j5 _0 A! Z |
RAM9 J/ {; P: z, {/ _
| 单核:片内164KByte,外扩256Kx 16bit SRAM, N, `' d9 A# K( _+ |9 f) |/ S
双核:片内204KByte,外扩256Kx 16bit SRAM
' p& V [6 ?. @2 p |
8 y' x' L k6 } | 1x电源指示灯
6 I9 ^: ]2 c: D |
2x用户LED- _! _9 Z" q* A
B2B 8 C+ ~! j" D1 Z; l$ d
Connector
6 l' \9 J9 j# m& @+ n | 2x 60pin公座B2B,2x 60pin母座B2B,间距0.5mm,合高4.0mm,共240pin
' R: ?+ h+ p& o- l4 w9 B/ O |
Hardware resources8 Y# ]: s7 N5 T$ {# g/ A% A
| 单核:1x 6 DMA双核:2x 6 DMA; x* q4 o# d3 K. J
2x EMIF
8 r ?$ O5 c1 z2 a! C |
1x USB 2.05 `' G9 ]( f5 _& D6 V
1x uPP,8bit
" M% D1 Z9 N, q |
24x ePWM; x: ^7 Z b) u& p. [* q" f/ [. O
16x HRPWM
, l& r( T8 }* U3 c, E* v1 R |
6x eCAP4 W" K8 s! [+ k8 ]/ K8 ?4 h8 S
3x eQEP
! g: C9 M1 t5 T9 Y5 u" m( x |
8x SDFM
0 O. w) v- B9 w! ]. ? H) n |
12路差分(16bit,1.1MSPS)/24路单端(12bit,3.5MSPS)ADC
" u4 _( q5 m- d4 i( p! E: \ |
3路12 bit DAC
# J' H' K9 i6 o; o& a) }8 Q2 E |
2x CAN8 v# C- X( h9 C; O# f4 d/ B) ?- R$ {
1x ePIE
2 C$ _" f1 G' w. {/ O |
2x McBSP
0 d5 t: b5 c r! p0 `" X |
4x SCI
' {5 o9 ^& y2 }; K |
2x I2C, _- z, I& ]' n6 @# @
1x Watchdog0 t" a6 L: _, k" `- N: t. p1 z6 @
3x SPI
- b: N" l, ?2 Q# f |
169x GPIO, d0 f+ e1 Z# Q% v7 v m; a2 L
2位启动模式选择信号
5 {( V3 I7 {) q o( _$ {1 N4 L) D |
备注:单/双核型号在硬件上pin to pin兼容。环境参数
6 G1 o7 d2 Y* b* E7 k | 最小值7 `* y/ @3 a( l7 e, K, `/ K
| 典型值 _8 t1 ]; @. i! [9 a
| 最大值5 G9 \+ N: S4 ?& ?9 k3 e6 I
工业级温度8 }4 ?4 h5 U$ m/ a1 i
| -40°C
. B" v1 ^" r7 J* l" _ n6 G9 e4 V | /
! m* W0 z# E4 b( |( L4 o4 ~ | 85°C t" s- l* s& Z( C& v
工作电压# G0 J, w9 f% Z; _* `( m8 h8 w
| /: g4 z% a2 {& e) R+ R. y
| 5V
3 }3 [1 k4 g0 @( g8 G b | /9 q5 A: }3 [# b& J& h6 F2 ]
