FPGA' b1 ~0 U: ]2 ]
| Xilinx Artix-7 XC7A100T-2FGG484I,兼容XC7A200T-2FBG484I
9 e6 C h4 b7 \. A- ` |
ROM
" o" K3 z* S9 g( L | 256Mbit SPI NOR FLASH- e* z T+ T V, i0 ~
RAM
5 P4 g7 J8 B m- k) j/ x5 ~ | 512M/1GByte DDR37 k, l3 v1 m0 r$ [4 r4 H5 f/ X
EEPROM
" B; {+ L |) x5 N; y2 r$ \ | 256Kbit
1 I$ a! w* `, G% S |
B2B
' `- H! b3 C: V RConnector
% H; Y) i& N2 `6 e* w% a | 2x 180pin高速B2B连接器,间距0.5mm,合高5mm,共360pin,信号率可达18GBaud
3 j4 e- C7 d2 j& F) a' r |
: t; q. r* D" P+ [# |) L | 2x电源指示灯(底板1个,核心板1个)& p7 G6 D7 l1 f5 U* ]3 D+ ~' y$ Y
6x用户指示灯(底板4个,核心板2个)
! n6 C s8 V, D& H+ M |
KEY4 V3 C' `3 `2 q- w) G- D+ [7 S. z
| 3x用户按键
4 ~" R3 z% X, C0 L |
1x复位按键
! p( v7 f3 D, ~% _9 u+ K6 c7 G$ K |
PCIe0 C7 B# X! p* y" K5 r
| 1x PCIe Gen2,单端口四通道,每通道最高通信速率5GBaud
( d$ S) I6 \5 o/ k! V; f4 d |
IO) M) [) H. N& F4 [
| 2x FPGA ExPORT,48pin欧式端子
2 I& }' h$ N4 M% _ r: T |
1x FPGA ExPORT,50pin牛角座
; `( N$ d1 T! s: S; n' k: X+ L |
UART* H$ K# k- i) t! x
| 1x UART1,Micro USB接口,提供4针TTL电平测试端口
5 e% p- |8 C$ g1 Y |
1x RS485,半双工模式
$ X" r6 A& d+ [7 z/ Y |
XADC
6 E. s Q! F( k | 1x 4pin XADC,双通道,12bit,1MHz,1.0Vp-p,间距3.81mm
+ C& z- V* S8 }* v7 Q |
SD8 J/ z) ^6 I$ h, y4 y, q2 v
| 1x Micro SD接口9 h9 U# V& G, r" C! I
PMOD0 N* E9 u5 W% U2 ?7 f
| 2x 12pin PMOD
6 b4 I7 c: e! N5 {7 T |
JTAG& c% A X$ a( q( v& \, E
| 1x 14pin JTAG接口,间距2.00mm
+ Y3 B! ?* g/ ^1 {9 H |
BOOT SET* m: f. w! c v% B+ H9 `. S
| 1x 2bit拨码开关* N( A) n5 f& t" [2 _' A
SWITCH
/ u7 J3 z9 o5 i8 R; P, j | 1x电源开关$ y# V- ?* v" S* O
POWER
7 L/ n* A4 M. L3 c9 n9 Q | 1x 12V 2A直流输入DC417电源接口,外径4.4mm,内径1.65mm, d# R; Q- `; c1 u4 n
环境参数7 k. g0 n. X* R( i6 B/ e) Z
| 最小值
# p) z7 k- S" G9 I- w2 ^ | 典型值
% W- y3 W! d# y# p, T | 最大值" e3 K* I7 h5 p6 P0 F1 e, q5 m" X
工作温度(工业级)6 |) l q/ B/ n
| -40°C3 C& z( J" g2 T# I* M( G
1 g3 R4 d. F+ n+ e2 M | 85°C* f% j& R1 K7 h1 ~
工作电压3 { {6 g( G7 a( o4 c2 F$ ^; v6 D# v$ \
6 }, |3 E4 U, ]+ Z I I | 12V/ n$ i- D' [4 R
0 Y$ i1 k7 \, [- H' B' r6 x: H, G1 L |
