查看: 289|回复: 2
树莓派更换清华源,安装aptitude报错:Unable to correct problems, you have held...
发表于 2020-8-4 13:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用清华源,然后安装了一下aptitude,各种问题,具体错误信息如下:
: v" K$ l% a' R[size=1em]0 N6 K+ E& d: t2 m
[size=1em]1
( f7 w' S6 W0 k) p5 ?4 f
[size=1em]2
. {9 m* S6 @3 x
[size=1em]3
3 v# Y2 Y; L4 p
[size=1em]4
: |) X3 l2 s- Z1 t' x3 g& \  f
[size=1em]5
; S$ @+ O+ s# x2 l
[size=1em]6
) c7 Z: p8 {% X, ~
[size=1em]7
3 V3 R% h! p( v0 _+ b+ }
[size=1em]8
# q5 h4 b0 t* f4 s( |
[size=1em]9
* H. p0 ~# h$ [& B. h
[size=1em]10
/ U" D: K) i+ ^# {5 e' Y" W; F
[size=1em]11
# Z7 L! N7 K1 l  F0 w
[size=1em]12
2 \+ L+ ~7 X+ S; b! O& @, j; X& @
[size=1em]13
: f5 A& K5 `6 K, I2 O0 F
[size=1em]14
, I- i, B3 h6 G  Z
[size=1em][size=1em]pi@raspberrypi:~ $ sudo apt-get install aptitude2 y% R3 o1 k9 W9 o7 |# t
[size=1em]Reading package lists... Done5 Y1 p0 V* B$ j; F4 y
[size=1em]Building dependency tree
6 H7 f7 }& Q5 z7 l2 E. S) K[size=1em]Reading state information... Done
2 p; L" f) I8 _* D8 q8 l  _; W[size=1em]Some packages could not be installed. This may mean that you have/ V( ?. c4 c: l$ p% ~! r
[size=1em]requested an impossible situation or if you are using the unstable. e# V' \- e2 n( l, B6 X! d8 [* t
[size=1em]distribution that some required packages have not yet been created1 M& A* w8 y. Q' Q6 b, m
[size=1em]or been moved out of Incoming.
; ]$ U. }1 ?  b! f[size=1em]The following information may help to resolve the situation:
, f. R4 z6 D; a. R7 H$ j5 r* i1 U2 n  G; m+ X
[size=1em]The following packages have unmet dependencies:
: \4 n( C3 A) i% U( t[size=1em] aptitude : Depends: libapt-pkg5.0 (>= 1.1) but it is not going to be installed
. X% b; o. a( ]3 X[size=1em]            Recommends: libparse-debianchangelog-perl but it is not going to be installed/ d1 l5 ~* y. I& z& _4 {9 V7 n
[size=1em]E: Unable to correct problems, you have held broken packages.3 q9 t2 e$ o: a% `" p3 K
( o+ E+ K; i7 N' N/ l* R- ]/ g, [
$ U; ~# ^7 D/ F  L( {: y
+ L* t8 U) L% J8 {6 Q
4 Y" h+ g3 T& J, K# i) {. q  ^3 u3 }  X/ M" g1 H6 B1 ~) \
这个问题百度了很多,但都没有一个合适的,希望各位大佬帮助啊,谢谢
 楼主| 发表于 2020-8-4 16:11 | 只看该作者
1、经过查找,发现原因为树莓派 Linux 系统版本为 buster ,但是使用的镜像源版本却为 stretch ,后来将树莓派使用的镜像源修改为与系统版本一致的源即可。; _% i7 O4 U1 f$ r# P2 X
2、修改完镜像源后,不要忘了使用命令:sudo apt-get update,sudo apt-get upgrade。
5 B$ r7 j* N" v) \8 _$ Q' ^' I; _3、更新完毕后,即可再次安装想要的软件;这里推荐使用:aptitude 安装所需软件,此工具可以有效地解决软件依赖包等问题。
GMT+8, 2025-11-25 00:27 , Processed in 0.156250 second(s), 24 queries , Gzip On.
