查看: 569|回复: 2
CENTOS7.4 执行ifconfig后获得 enp1s0 lo ppp0 virbr0 这4项有什么区别
    2019-11-19 15:32
    发表于 2020-7-17 14:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    CENTOS7.4   执行ifconfig后获得  enp1s0 lo  ppp0 virbr0 这4项有什么区别,* Q3 o/ o* v( r% C
    , K; B( M' |2 ?
    [root@localhost ~]# ifconfig
    7 @8 X3 E% {( J3 s# }enp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
    / \& R) c$ Z9 O        ether 8c:16:45:36:8e:c2  txqueuelen 1000  (Ethernet)
    2 L5 v0 [* p/ X4 Z        RX packets 694300  bytes 396595988 (378.2 MiB)
    8 H' ]- F& `( ]0 ~        RX errors 0  dropped 0  overruns 0  frame 02 K3 f5 {2 G! P6 z2 ?) H
            TX packets 373601  bytes 75343069 (71.8 MiB)% ]$ L" ^( `4 M0 N
            TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0$ a; G: d( q7 c4 l, z' {9 n
    ; f' O; s. h9 W# Vlo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
    ( i5 l( l: A9 _/ V% _        inet 127.0.0.1  netmask 255.0.0.0
    ' s6 x+ D  I4 w9 o        inet6 ::1  prefixlen 128  scopeid 0x10<host>
    & @# q- _% N, E, M! a. a        loop  txqueuelen 1  (Local Loopback)1 @9 w. T$ W* i, q# q7 H& o
            RX packets 1366700  bytes 394641685 (376.3 MiB)- Q* e) l" ]3 C8 Z8 P9 v
    9 l5 r: ~# _" a        TX packets 1366700  bytes 394641685 (376.3 MiB)- t; g6 ~: F; z6 ~! P: X
    $ _2 @6 c* m% `* y6 M0 Z8 C
    " S# P, ]( ]1 Zppp0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1492
    3 |5 e3 I$ b1 U( z+ S        inet 61.179.97.139  netmask 255.255.255.255  destination 61.179.96.1! Q( F1 ]. u2 D4 U7 I) b  P, B
            ppp  txqueuelen 3  (Point-to-Point Protocol)
    3 \& v# E! l" X        RX packets 410543  bytes 351742597 (335.4 MiB), m7 p  H3 o+ q& u! M8 ^
            RX errors 0  dropped 0  overruns 0  frame 0; u5 a/ O: n: v, ?; r8 f
            TX packets 349719  bytes 66932743 (63.8 MiB)$ {$ |/ ?1 @. C- S8 o! i; z5 ?& ?- S; \
    : V/ |, S1 b; }9 a0 ?
      B+ c4 T9 Y0 X1 W! {virbr0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
    - t& {% G& v5 P3 Q* j* e3 E% Q# k        inet 192.168.122.1  netmask 255.255.255.0  broadcast 192.168.122.255
    , F# F, Y0 f# U& |        ether 52:54:00:09:d9:2f  txqueuelen 1000  (Ethernet)
    " h9 ~- x3 l+ @7 y1 Z        RX packets 0  bytes 0 (0.0 B)
    $ `4 Q; V; a# C4 y2 G5 T& _        RX errors 0  dropped 0  overruns 0  frame 09 C) K- o; U" c9 Q6 g9 V+ r+ {
            TX packets 0  bytes 0 (0.0 B)3 i0 }7 C' S6 S, w3 m* e* B
    6 d6 S& J2 P3 |
    2019-11-20 15:22
    发表于 2020-7-17 15:35 | 只看该作者
    不同的网络接口4 ~1 h0 D% s, Z. T
    # G$ A: ]2 \- O+ H第一个是无线网卡接口,第二个是环回接口,第三个是经以太网接口PPP拨号时创建的链路接口,第四个是你虚拟机的虚拟网卡接口
    ; d3 c+ j6 s& B  M1 F( ~+ }* c3 j. U; A+ h
    详细的一查就查得到
    发表于 2020-7-17 15:36 | 只看该作者
    看看啥问题
    GMT+8, 2025-11-25 01:22 , Processed in 0.171875 second(s), 23 queries , Gzip On.
