会出现这样的问题 ( S7 N. Q- J% W! ~2 m( h* q WARNING(SPMHA1-299): Create symbol multiple text lines are not supported on a single component type subclass. : m8 g, x5 w/ ? C8 n
WARNING(SPMHA1-299): Create symbol multiple text lines are not supported on a single component type subclass. ) D) _0 p- I& T0 p% J' W# r& |: h
ERROR(SPMHA1-291): Create symbol has been aborted.7 Z R' Y1 H: {" h3 \1 k
发现生成了两个 Assembly_Top的Ref Des,把其中一个删掉就可以生成symbol,不知大家怎么解决这个问题
