查看: 946|回复: 5
[allegro16.6][16层] altera原厂参考板(EP4S100G2KF1517+EPM1270+LTM4616EV)原...
发表于 2020-3-30 16:50 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
+ Q1 F% Z& o- ^* }' A+ o# Q/ T% B) t[allegro16.6][16层] altera原厂参考板(EP4S100G2KF1517+EPM1270+LTM4616EV)原理图和pcb文件( b- G% d, o  H4 O
6 x) H4 b1 p7 M. f
文件描述:
7 B& W/ O0 b1 e( W& X5 ~, i# Q2 O
( x) k) S; a6 x) s, s; M5 f1. 作品用途: altera原厂参考板
# C3 ^* C1 I- v" D" t2. 软件版本:allegro16.6
  T; F; S  p# H* D1 x& \3. 层数:16层6 r0 N. j; E9 c/ W' }# T9 _" T
4. 用到的主要芯片:EP4S100G2KF1517+EPM1270+LTM4616EV
1 u! L- g3 k2 K6 T  C5 d0 X1 j5. pcb尺寸: 10950*5250 MIL( w0 {/ x5 ~7 @# q8 ^
3 E7 h" S, T, `. B* B作品截图如下:
, ]* s5 V) F+ |# m% A! B$ z+ G3 i6 h2 c+ H% U( h; ~* S
顶层截图:
  v' ?. Q$ @1 B4 x- y, S9 \# H( k1 A
; z% k) K5 I: ?底层截图:
1 R( N; O7 V" E7 G$ @+ R
( j, V' W7 l0 q( K1 d+ S) ~* z8 ~" c/ n' }. n( ]( I
全层截图:. P6 l1 C& g( [5 m. n% M9 y
9 x! ]$ F! v' b* z) V. [2 U
+ U- _0 l; j: l: ]7 ]5 B% {4 G5 g叠层阻抗信息如下:, D1 r8 a* P) O! ]( [5 V
( N! ?. [8 l4 c# C* R4 s* nBOM:
5 ~' v% G9 {! `( W
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
2X4VH2X4_2X4VH_2X4HEADER2x4HeaderIC1J25
2X5VH2X5_2X5VH_2X5HEADER2x5HeaderIC1J63
3X3MMDFNLT3080EDD_0_3X3MMDFN_LT3080EDD-LT3080EDD-1IC8U4; U6; U7; U8; U9; U10; U12; U25
256FBGAEPM1270_5_256FBGA_EPM1270_256FBEPM1270_256FBGAIC1U32
402CAP_0402_100PF100pFIC2C2; C22
402CAP_0402_47NF47nFIC3C10; C19; C29
402CAP_0402_1.0NF1.0nFIC5C11; C12; C20; C21; C30
402CAP_0402_1UF1uFIC20C31; C40; C42; C44; C45; C46; C48; C51; C52; C55; C56; C80; C83; C91; C315; C325; C372; C373; C374; C375
402CAP_0402_18PF18pFIC1C33
402CAP_0402_0.1UF0.1uFDISCRETE95C50; C54; C59; C76; C77; C78; C79; C82; C85; C87; C88; C92; C93; C94; C99; C100; C101; C103; C107; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C120; C140; C141; C142; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C153; C154; C155; C242; C243; C244; C245; C246; C247; C258; C261; C314; C316; C317; C319; C327; C328; C329; C330; C331; C332; C333; C334; C335; C346; C347; C348; C349; C358; C359; C360; C361; C362; C363; C364; C365; C366; C367; C368; C369; C370; C376; C377; C378; C379; C380; C381; C387; C388; C389
402CAP_NP_0402_2.2NF2.2nFIC1C75
402CAP_0402_0.01UF0.01uFIC18C84; C102; C104; C350; C351; C352; C353; C354; C355; C356; C357; C382; C383; C384; C385; C390; C391; C392
402CAP_0402_33NF33nFIC1C86
402CAP_0402_0.22UF0.22uFIC4C95; C96; C97; C98
402CAP_NP_0402_16PF16pFIC2C105; C106
402CAP_0402_DNIDNIIC1C318
402CAP_0402_.01UF, DNI.01uF, DNIIC1C322
402CAP_0402_0.1UF, DNI0.1uF, DNIIC3C343; C344; C345
402RESISTOR_0402_100K100KIC3R1; R10; R54
402R_0402_10.0K10.0KIC44R2; R17; R44; R45; R46; R47; R57; R110; R111; R112; R113; R114; R115; R116; R117; R122; R124; R150; R151; R161; R162; R163; R164; R191; R192; R201; R202; R209; R210; R227; R232; R233; R234; R235; R236; R237; R238; R239; R240; R262; R263; R264; R265; R267
402RESISTOR_0402_51.1K51.1KIC1R4
402RESISTOR_0402_787K787KIC3R5; R7; R9
402R_0402_150150DISCRETE3R6; R72; R73
402RESISTOR_0402_8.25K8.25KIC1R8
402R_0402_330K330KIC1R15
402RESISTOR_0402_3.09K3.09KIC2R18; R19
402RESISTOR_0402_61.9K61.9KIC2R22; R23
402RESISTOR_0402_78.7K78.7KIC1R26
402RESISTOR_0402_39K39KIC2R27; R29
402RESISTOR_0402_107K107KIC2R28; R229
402R_0402_71.5K71.5KIC1R30
402RESISTOR_0402_127K127KIC1R32
402R_0402_160160IC18R48; R98; R103; R104; R105; R106; R107; R108; R109; R157; R158; R159; R256; R257; R258; R259; R260; R261
402RESISTOR_0402_200200IC1R49
402RESISTOR_0402_0402_470470IC1R50
402RESISTOR_0402_0402_2727DISCRETE2R51; R52
402RESISTOR_0402_0402_1.5K1.5KIC1R53
402RESISTOR_0402_8282IC1R56
402RESISTOR_0402_0402_3333DISCRETE3R58; R60; R61
402RESISTOR_0402_0402_2.2K2.2KIC1R59
402R_0402_1K1KIC17R62; R66; R74; R80; R86; R118; R119; R120; R121; R160; R165; R166; R171; R200; R217; R218; R219
402RESISTOR_0402_49.949.9DISCRETE31R63; R65; R70; R71; R79; R85; R91; R167; R168; R169; R170; R172; R173; R174; R175; R176; R177; R178; R179; R180; R181; R189; R190; R245; R246; R247; R248; R249; R250; R251; R252
402RESISTOR_0402_DNIDNIIC1R64
402RESISTOR_0402_100100DISCRETE8R67; R68; R224; R225; R226; R271; R272; R273
402RES 475 OHM 1/16W 1% 0402 SMD475IC1R69
402RESISTOR_0402_124124IC6R75; R76; R81; R82; R87; R88
402R_0402_84.584.5IC6R77; R78; R83; R84; R89; R90
402R_0402_NO STUFFNo StuffIC4R92; R93; R94; R95
402RESISTOR_0402_0402_DNIDNIIC3R193; R194; R221
402R_0402_DNIDNIIC8R195; R196; R203; R204; R214; R215; R216; R231
402RESISTOR_0402_100, DNI100, DNIIC3R211; R212; R213
402RESISTOR_0402_0402_00IC2R220; R222
402RESISTOR_0402_49.9, DNI49.9, DNIIC1R223
402R_0402_5.9K5.9KIC1R228
402RESISTOR_0402_30.1K30.1KIC1R230
402RESISTOR_0402_4.7K4.7KIC5R241; R242; R243; R244; R255
402RESISTOR_0402_10.0K10.0KIC1R253
402RESISTOR_0402_4.99K4.99KIC1R254
603CAP_0603_56PF56pFIC2C89; C90
603CAP_NP_603_2.2UF2.2uFIC10C393; C394; C395; C396; C397; C398; C399; C400; C401; C402
603RESISTOR_603_2.21K2.21KIC1R16
603R_0603_2K2KIC4R182; R183; R184; R185
805CAP_0805_4.7UF4.7uFIC9C32; C323; C324; C386; C403; C404; C405; C406; C407
805INDUCTOR_805_120OHM, 800MA120ohm, 800mAIC6FB1; FB2; FB9; FB16; FB17; FB18
1206CAP_1206_100UF100uFIC23C1; C3; C13; C15; C23; C24; C36; C38; C156; C188; C189; C190; C191; C193; C194; C196; C198; C199; C200; C201; C205; C206; C207
1210CAP_1210_10UF10uFIC28C6; C7; C8; C9; C17; C18; C27; C28; C35; C41; C43; C47; C49; C53; C57; C60; C81; C174; C259; C260; C262; C274; C290; C291; C300; C320; C326; C371
7343PCAP_SMD_POL_7343P_470UF470uFIC5C4; C14; C25; C37; C39
10037909GUIDE_PIN_RECEPTACLE_10037909_GGUIDE_PIN_RECEPTACLEIC2J72; J73
AIRMAX_10057041-101LFAIRMAX_10057041-101LF_AIRMAX_10AIRMAX_10057041-101LFIC1J70
AIRMAX_10057041-101LF_1AIRMAX_10057041-101LF_AIRMAX_10AIRMAX_10057041-101LFIC1J71
BANANA_JACKBANANA_JACK_RED_BANANA_JACK_BANBANANA_JACK_REDIC6J2; J3; J7; J8; J9; J10
BANANA_JACKBANANA_JACK_BLACK_BANANA_JACK_BBANANA_JACK_BLACKIC1J4
BCC9688E1111_BCC96_88E111188E1111IC1U40
CAP_SMD_8MMPCAP_CAP_SMD_8MM_150UF150uFIC4C5; C16; C26; C34
CONN_39_26_710870247-1051_CONN_39_26_7108_702470247-1051IC1J28
CONN_FANCON3_CONN_FAN_3X13X1IC1J12
DCUTXS0102_DCU_TXS0102TXS0102IC1U35
DIPSWITCH16SPST8_DIPSWITCH16_DIP_SW_8DIP_SW_8IC1SW7
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1IC1SW2
DO-214AB_RECTRONDIODE_DO-214AB_RECTRON_FM540FM540IC1D1
EG2201ASW SLIDE-DPDT_EG2201A_EG2201AEG2201AIC1SW1
EXB8PRPAK4_EXB8P_10K10KIC3RP1; RP2; RP3
F64_10X13PC28FXXXP30B85_0_F64_10X13_PC48PC48F4400P0VB00IC1U39
FBGA1517EP4S100G2KF1517_FBGA1517_EP4S10EP4S100G2KF1517IC1U33
FUSE_BOXFUSE_FUSE_BOX_FUSE 5AFUSE 5AIC1F6
FUSE_SMTFUSE_FUSE_SMT_10 AMPS10 AMPSIC2F1; F2
FUSE_SMTFUSE_FUSE_SMT_2 AMPS2 AMPSIC4F3; F4; F5; F7
GNDVIA10T POINT R_GNDVIA10_VIAVIAIC47TP1; TP2; TP3; TP4; TP5; TP6; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP51
HDR2X1_100MILCON2_HDR2X1_100MIL_CON2CON2IC5J26; J65; J66; J67; J69
HDR2X7_100MILHDR2X7_HDR2X7_100MIL_HDR2X7HDR2X7IC1J24
HEADER031X3_HEADER03_1X3HEADER1x3HeaderIC2J62; J64
LGA118LTM4601_0_LGA118_LTM4601LTM4601IC3U1; U2; U3
LGA-15X15-144PLTM4616_0_LGA-15X15-144P_LTM461LTM4616EVIC1U5
LQFP-32FT245BL_LQFP-32_FT245BLFT245BLIC1U16
LTC3025EDCLTC3025EDC_0_LTC3025EDC_LTC3025LTC3025EDCIC3U11; U13; U38
LUMEX_LED1206LED_LUMEX_LED1206_BLUE_LEDBlue_LedIC1D3
LUMEX_LED1206LED_LUMEX_LED1206_AMBER_LEDAmber_LEDIC1D6
LUMEX_LED1206LED_LUMEX_LED1206_GREEN_LEDGreen_LEDIC17D7; D8; D9; D10; D11; D12; D13; D14; D15; D17; D18; D19; D20; D21; D22; D23; D24
LUMEX_LED1206LED_LUMEX_LED1206_RED_LEDRed_LEDIC1D16
MSOP-10TS5A23157_MSOP-10_TS5A23157TS5A23157IC1U26
MTH250R125MNT HOLE_MTH250R125_LCD MNT HOLLCD MNT HOLEIC2MNT1; MNT2
MTH250R125MNT HOLE_MTH250R125_BRD MNT HOLBRD MNT HOLEIC9MNT3; MNT4; MNT5; MNT6; MNT7; MNT8; MNT9; MNT10; MNT11
OSC4PSMTCTS_CB3LV_OSC4PSMT_CTS_CB3LVCTS_CB3LVIC1Y2
OSCSMD_SG8002OSCSMD_OSCSMD_SG8002_24MHZ24MHzIC1Y1
OSC_SMD_4PIN_25X2CRYSTAL 4PIN_OSC_SMD_4PIN_25X2_ABM10-25MHzIC1X2
OSC_SMD_6PIN_7X5OSC_SMT_PECL_OSC_SMD_6PIN_7X5_OOSC_100.00MIC1Y4
OSC_SMD_8PIN_7X5SI370_OSC_SMD_8PIN_7X5_SI370Si370IC1Y5
OSC_SOCKET_6PIN_5X7OSC_SMT_PECL_OSC_SOCKET_6PIN_5XOSC_644.53MIC1Y3
PUSHBUTTON_EVQEVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchIC8SW8; SW9; SW10; SW11; SW12; SW13; SW14; SW15
QSOP16MAX1619_QSOP16_MAX1619MAX1619IC1U15
RAPC712CONN_JACK_PWR_RAPC712_RAPC712XRAPC712XIC1J1
RJ45HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02EIC1J68
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1IC34J14; J15; J16; J17; J18; J19; J20; J21; J22; J23; J30; J31; J32; J33; J34; J35; J36; J37; J38; J39; J40; J41; J42; J43; J44; J45; J54; J55; J56; J57; J58; J59; J60; J61
SMB403A_03ZENERDIODE_SMB403A_03_20V ZENER20V ZenerIC3D2; D4; D5
SO8M95128_SO8_AT25128AT25128IC1U31
SOIC8P150W93LC46B_SO_0_SOIC8P150W_93LC64B93LC64B_SOIC1U19
SOIC-8ICS8304_SOIC-8_ICS8304ICS8304IC1U20
SOIC-8ICS85411_SOIC-8_ICS85411ICS85411IC1U23
SOT23-5LT1761_SOT23-5_LT1761LT1761IC1U37
SOT23-6SN65220_SOT23-6_SN65220SN65220IC1U18
SOT-323DIODE_DUAL_CK_AAJ_SOT-323_CMSSHCMSSH-3CIC1DN1
SSOP28_NARLTC2418_SSOP28_NAR_LTC2418LTC2418IC1U14
SW_ROTARY_94HSW_ROTARY_SW_ROTARY_94H_94HCB1694HCB16WTIC1SW16
TP_060SQ040T_POINT_R_TP_060SQ040_54101-G0554101-G05-01LFIC2TP39; TP40
TQFP44PEPM7064AETC44_0_TQFP44P_EPM7064EPM7064AEIC1U17
TSMT3MOSFET_N_TSMT3_FDV305NFDV305NIC1Q1
TSSOP14PMAX3378_0_TSSOP14P_MAX3378MAX3378IC2U34; U36
TSSOP16ICS557-03_TSSOP16_ICS557-03ICS557-03IC1U21
TSSOP20ICS8543_0_TSSOP20_ICS8543ICS8543IC2U22; U24
USB-67068-8001CN-USB_USB-67068-8001_CN-USBCN-USBIC1CN1
WSL2010RESISTOR_WSL2010_.0010.001IC1R3
WSL2010RESISTOR_WSL2010_.0090.009IC5R11; R20; R21; R24; R25
X2Y_0603CAP_X2Y_X2Y_0603_100NF100nFIC5C158; C159; C160; C163; C175
X2Y_0603CAP_X2Y_X2Y_0603_10NF10nFIC6C164; C165; C167; C168; C176; C177
X2Y_0603CAP_X2Y_X2Y_0603_4.7NF4.7nFIC2C178; C179
X2Y_0603CAP_X2Y_X2Y_0603_1000PF1000pFIC4C180; C181; C182; C183
X2Y_1210CAP_X2Y_X2Y_1210_1UF1uFIC1C157
XTAL_PACK_DXTAL_XTAL_PACK_D_25MHZ25MHzIC1X3
XTLSMD_CSM7CRYSTAL_XTLSMD_CSM7_6MHZ6MHZIC1X1
3 U' B& n; V% T1 [1 J: z8 |* U6 Z附件:! y$ x/ ~3 h# l7 {. U- a
原理图和PCB文件如下:7 [/ `8 m: P+ H1 t$ i7 ^, p
( `8 D: a+ a) a6 i  Z( v5 _
游客,如果您要查看本帖隐藏内容请回复
3 O  M' g8 o8 i: Y, n2 P
, {/ y# {2 \/ \& G5 K5 v$ j+ }
发表于 2020-4-2 17:15 | 只看该作者
楼主分享的这个干货很不错,让我可以用来练练手。
发表于 2020-4-2 23:17 | 只看该作者
ddddddddddddddddddddddddd, g; H. ^6 a# E/ K
    2021-10-7 15:37
  • 签到天数: 44 天
    [LV.5]常住居民I
    发表于 2020-4-15 17:52 | 只看该作者
    谢谢楼主的分享
    “来自电巢APP”
    发表于 2020-7-9 09:17 | 只看该作者
    精华帖子必须顶
    发表于 2020-7-10 09:08 | 只看该作者
    谢谢楼主的分享
    ; H( ~5 `, w9 l7 u' A2 Z
    GMT+8, 2025-7-28 19:02 , Processed in 0.140625 second(s), 27 queries , Gzip On.
